Spring Commissioning Checklist - SailNet Community
Blogs
Go Back   SailNet Community > Featured Articles > Gear and Maintenance Articles
Old 03-02-2010
administrator's Avatar
Administrator
administrator has disabled reputation
To help boaters have a trouble-free summer boating season, BoatU.S., the nation’s largest recreational boating association, has a spring commissioning checklist. Whether you have a power or sailboat, inboard or outboard, following this checklist is an easy way to get ready for the season.
BEFORE YOU LAUNCH:
Inspect and lubricate seacocks. Hoses and hose clamps should be inspected and replaced as necessary.
Replace deteriorated zincs.
Inspect prop(s) for dings, pitting and distortion. Make sure cotter pins are secure. Grip the prop and try moving the shaft - if it’s loose, the cutlass bearing may need to be replaced.
Check to make sure the rudderstock hasn’t been bent.
Inspect the hull for blisters, distortions and stress cracks.
Make sure your engine intake sea strainer is free of corrosion and properly secured.
Check the engine shaft and rudder stuffing boxes for looseness. After the boat is launched, be sure to check these as well as through-hulls for leaks.
Use a hose to check for deck leaks at ports and hatches. Renew caulk or gaskets as necessary.
OUTDRIVES and OUTBOARD ENGINES:
Inspect rubber outdrive bellows for cracked, dried and/or deteriorated spots (look especially in the folds), and replace if suspect.
Check power steering and power trim oil levels. Replace worn-out zincs.
Inspect outer jacket of control cables. Cracks or swelling indicate corrosion and mean that the cable has to be replaced.
ENGINES AND FUEL SYSTEMS:
Inspect fuel lines, including fill and vent hoses, for softness, brittleness or cracking. Check all joints for leaks and make sure all lines are well supported with non-combustible clips or straps with smooth edges.
Inspect fuel tanks, fuel pumps and filters for leaks. Clamps should be snug and free of rust. Clean fuel filters.
Inspect cooling hoses and fittings for stiffness, rot, leaks and/or cracking. Make sure they fit snugly and are double-clamped.
Every few years, remove and inspect exhaust manifold for corrosion.
Clean and tighten electrical connections, especially both ends of battery cables. Wire-brush battery terminals and fill cells with distilled water.
Inspect bilge blower hose for leaks.
SAILBOAT RIGGING:
Inspect fittings for cracks and rust. Inspect wire halyards and running backstays for "fishhooks" and rust.
Remove tape on turnbuckles and lubricate threads, preferably with Teflon. Replace old tape with fresh tape.
Recaulk through-deck chainplates as necessary (generally, once a decade).
TRAILERS:
Inspect tire treads and sidewalls for cracks or lack of tread and replace as necessary. Check air pressure. Don’t forget the spare!
Inspect bearings and repack as necessary.
Test tail and back-up lights. Test winch to make sure it’s working properly.
Inspect trailer frame for rust. Sand and paint to prevent further deterioration.
MISCELLANEOUS:
Check expiration dates on flares and fire extinguishers.
Check stove and remote tanks for loose fittings and leaking hoses.
Inspect bilge pump and float switch to make sure it’s working properly.
Inspect dock and anchor lines for chafing.
Update or replace old charts, waterway guides.
Check shore power cable connections for burns, which indicates the cable needs to be replaced.
Make sure your boating license and/or registration is up to date. Don’t forget your trailer tags.
Review your boat insurance policy and update coverage if needed. Be sure you have fuel spill insurance coverage.
Make sure you have a properly sized and wearable life jackets in good condition for each passenger, including kids and pets.
See:
on how to add a country flag and an avatar to your posts and how to update your forum title.
Old 09-28-2011
shanlv3033 is on a distinguished road
[QUOTE=;][/QUOTE]
More in Lycos: About Lycos | Privacy Policy | Terms of Service | Careers | Advertise With Us | Help,[url=http://www.longchampssacpascher.com]sac longchamp pliage[/url]
Lycos Classifieds International: Classifieds United States Classifieds United Kingdom Classifieds New Zealand Classifieds India Classifieds Canada Classifieds Australia
Listing information on Lycos Classifieds is provided by third-party data provider - Oodle.com. Click here to learn more safety and security tips to protect yourself
online while using classifieds. You can also report an illegal or inappropriate listing,[url=http://www.longchampssacpascher.com]sac longchamp[/url], or identify common scams by visiting this page.
Lycos Home | Lycos Mail
We're Mobile,[url=http://www.moncler-oulet-it.com]moncler vendita[/url]!
More in Classifieds: Post an Ad | Browse Classified Ads by Category and Location | Mobile Classifieds | Site Map
Have anything to sell or services to offer? Post your ads here for free. It's quick, easy and immediately accessible to all Lycos classifieds users, as well as users on the entire Oodle network, including Facebook,[url=http://www.longchampssacpascher.com]sac longchamp pas cher[/url], MySpace, Twitter,[url=http://www.moncler-oulet-it.com]piumini moncler[/url], AOL, Walmart, and more.
classifieds.lycos.com
Cars & Vehicles | Items For Sale | Housing for Rent | Housing for Sale | Jobs | Pets | Personals | Services | Tickets
Post your ads for free.
Copyright © 2011 Lycos,[url=http://www.longchampssacpascher.com]sac longchamp moins cher[/url], Inc. All Rights Reserved.
Old 09-30-2011
mgphl52 is on a distinguished road
re: Spring Commissioning Checklist
Just saw this today. Rather surprising having no mention of running and/or anchor lights... ;-)
BB code is Off
Re: Spring Commissioning Help? NewsReader Mass Bay Sailors 0 04-19-2006 10:15 PM
Spring Commissioning Help? NewsReader Mass Bay Sailors 0 04-14-2006 09:16 PM
commissioning checklist? laproch Gear & Maintenance 3 05-20-2003 09:39 AM
The Spring Launch Bruce Caldwell Gear and Maintenance Articles 0 04-30-2002 09:00 PM
The Spring Launch Bruce Caldwell Cruising Articles 0 04-30-2002 09:00 PM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
