Shipmate Model 885G 3-burner Stove - SailNet Community
post #1 of 2 Old 05-30-2013 Thread Starter
In the process of determining feasibility of refurbishing my late '60s Shipmate Model 885G 3-burner and oven. It is structurally sound and SS finish is still good. However, I need to replace or refurbish some of the rusted burner and valve assemblies, plus I'm missing one of the stove burners. My questions are:
1) Does anyone have a discarded or extra burner similar to the ones in my photo? My burners are not in bad shape as the cast units are clean and orifices are intact, just a bit of rust on the plate metal parts.
2) The oven door springs are okay, except for what appears to be worn areas on the tips of the springs that fit into the hinges and oven case. Does anyone have experience with these? They appear to be worn from use, but also are so uniform in appearance, that I wondered if that is simply the original condition.
3) Oven Burners (top/bottom) are not in terrible shape, but I would like to find replacements if I can.
4) The valve manifold is pretty rusty and can be cleaned, but I would replace if I could.
5) Lastly, the 2 valves that regulate gas flow and sit in the top of the stove - I will need to disassemble and clean, but if I can find replacements I might prefer that instead.
btw - I have read all the posts I could find on this subject (most are dated somewhat), and have been to the Shipmate Stove Company, GearBusters on eBay, and Sailorman without any success.
Any assistance or advice that anyone would like to share would be appreciated.
Stove Disassembly (32) 2013-0530.JPG   Stove Disassembly (34) 2013-0530.JPG   Stove Disassembly (35) 2013-0530.JPG   Stove Disassembly (36) 2013-0530.JPG   Stove Disassembly (37) 2013-0530.JPG
FineKetch is offline
post #2 of 2 Old 05-30-2013
Re: Shipmate Model 885G 3-burner Stove
There is an eBay store that had spare parts for Shipmates, but I haven't see much lately. Looks like you may need to replace those burners, they are the same as mine, and I bought new ones, a different kind.
Try Sure Marine, I am sure that some parts are interchangeable bt Hillerange, Shipmate, Princess and Seaward stoves.
Here is the link:
Sure Marine
and
Sure Marine Service Inc.
+ the Gearbusters eBay store, get in touch with John:
http://stores.ebay.ca/GEARBUSTERS
Good luck
SVTatia is offline
Tags
burners , shipmate stove
Gimbling one Burner Stove! Capt.aaron Provisioning 10 04-13-2013 01:06 AM
Shipmate Kerosene Burner Replacement rjg23 Gear & Maintenance 1 10-08-2010 08:48 PM
Shipmate stove JESTER458 Gear & Maintenance 18 10-07-2009 02:32 PM
shipmate kerosene stove Borvaprops Gear & Maintenance 0 10-01-2008 01:05 PM
