Can sails shrink? - Page 3 - SailNet Community
 1Likes
post #21 of 29 Old 06-16-2013 Thread Starter
blackflagsailor's Avatar
Re: Can sails shrink?
Okay, learned how to use the clew outhaul. The rigging instructions in my paperwork did mention it and it was easy to do. The new problem I now have is that the boom sits high at the gooseneck and low at the clew end. Is there supposed to be some kind of downhaul to level it? The gooseneck fitting just slides into the track for the main sail. I think I've finally posted enough to attached photos so I may set her up and take some pics.
blackflagsailor is offline
post #22 of 29 Old 06-16-2013
If you mean when the mainsail is up... yes there should be a downhaul for a gooseneck in a track. If will also tighten the luff of the main. If you mean when the mainsail is down, the topping lift will lift the boom end.
tempest is offline
post #23 of 29 Old 06-16-2013
4KSB driver.
Sail repair by Sail Care can make old sails like new
Sailcare can get you there (as can many others)... but they have a way to get more life out of it. I've seen people recommend cutting some of the strands in the boltrope, but honestly I don't think I'd be comfortable with that.
Look towards the bottom of their descriptions. It basically describes your issue to the letter.
By the way sailcare does a decent job of getting more life out of old sails. There is however, no substitute for a new sail (I know, I am/have been, in the same boat, pardon the pun - sails are stupid expensive).
Again a shrunken bolt rope will do as you describe... but you can also check the leech line (tensioning will cup the leech up some, shortening the leech, and raising the aft end of the boom, tightening too much will CUP the main to windward - bad - and cause a stall)...
I find getting shape out of a bagged old main harder than getting usefulness out of a bagged old jib... but with some tweaks it's doable. Again, sails are expensive, and I get that, but they are also one of the single largest improvements you can do to get your sailboat sailing better (along with fixing/fairing/smoothing the bottom).
1983 WD Schock Wavelength 24. Production boat limit tester, blue-water bucket owner, with wine taste on a beer budget.
SHNOOL is offline
post #24 of 29 Old 06-16-2013
overbored's Avatar
is you boat a C-lark by clark boats? http://sailboatdata.com/viewrecord.asp?class_id=7682
a sail on that size boat will not shrink enough to prevent you from sailing with it. the foot of the mainsail on a 14' dingy should not be tight. and the boom will be longer then the sail. on many dingys the aft end of the boom will be lower then the goose neck depending on the rake of the mast. tighten the outhaul with a little tension, just enough to hold the sail out near the end of the boom . pull the downhaul down just tight enough to remove the horizontals wrinkles on the sail. go sailing
http://wyctelltale.blogspot.com/2012...part-1_16.html
"GOLD RUSH" PRINDLE 16
overbored is offline
post #25 of 29 Old 06-23-2013 Thread Starter
Indeed it is a C-Lark by Clark Boats of Seattle, WA. I have learned how to use the clew outhaul properly, however, the boom sits with the clew end low when the main is raised. I was going to send pics, however, while raising the sail to take the pics last week, the steel halyard broke free at a swage sleeve where two pieces of line were spliced together. Ugh... Well not I gotta fix that. Does anyway know what those swaged ball end fittings are called? I can't find them anywhere.
Something like this:
Also, there is a vertical track with some sort of adjustable cleat type on the side of the mast near the bottom of the mast. What is this used for?
post #26 of 29 Old 06-27-2013 Thread Starter
Ran up my older patched sail today to take some photos.
I should try it with the better sail as well since that is the sail I was first talking about, not the one in these pics.
post #27 of 29 Old 06-27-2013
overbored's Avatar
the halyard lock on the mast track is what you put the ball swage in when you hoist the sail all the way to the top and then you tighten the luff with the down haul. tied off on the lower horn cleat
amain sail with the lower clew was a fad in the late 70's early 80's. in the pic you need more down haul to pull the luff a lot tighter. this will level out the boom some
post #28 of 29 Old 07-02-2013
All sails with any type of fiber shrink. It's a common problem.
Monofilm windsurfer sails are probably the only ones that don't.
I am a sail designer and it's something we are constantly fighting with. In the America's Cup (back when they were real boats) were constantly remeasuring and adding sail area to keep the sails at target area for each round robin.
They shrink with general use. This is why a good sailmaker will crush a piece of cloth before inserting it in an old sail for a repair. The idea is to pre-shrink it to better match the existing cloth. You get some weird looks from customers when doing it, but it's the best thing you can do.
Also temperature and humidity are big factors. We used to heat AC spinnakers in a dehumidified room in vacuum bags right up until a few minutes before measurement. We make the sails over size by about 1-2% and shrink it down for measurement.
The tapes and bolt ropes shrink at a greater pace usually, this is why sails end up short on hoist. Easy thing to do is unpick the hand sewing that seizes off the bolt ropes at the tack of the sail.
Options409 is offline
post #29 of 29 Old 07-02-2013
Looking at the pic... It seems the sail is very old and the bolt ropes are sewn to the sail rather than inside a tape. This is probably the worst for shrinkage. You could cut the ropes off and ask a sailmaker to sew a new luff and foot tape on with a bolt rope inside the tape.
Or just soak the sail in water, then hoist and load it up to stretch it back out.
To Shrink or not to Shrink??? ujk Cruising & Liveaboard Forum 16 12-15-2011 11:10 PM
Shrink wrap Dougblowboat SailNet FAQ 8 05-06-2011 12:22 AM
shrink wrap NewsReader Mass Bay Sailors 2 05-06-2011 12:10 AM
would it be possible to reuse "shrink wrap" / shrink wrapping yourself q's purvisgs Gear & Maintenance 8 04-11-2008 11:35 PM
Shrink Wrapping...or Not T37Chef General Discussion (sailing related) 27 12-21-2006 09:41 AM
