Need help with rolling and tipping - Page 2 - SailNet Community
 8Likes
post #11 of 20 Old 06-01-2013
bljones's Avatar
Re: Need help with rolling and tipping
Apoparently Mr. Oman needs to spend more money on better searchbots, since Mr. "Too cheap to buy an ad or do R&D," the cheap epoxy king, is replying to a PAINT post.
It's 5 o'clock somewhere:
bljones is offline
post #12 of 20 Old 06-01-2013
TQA
Bombay Explorer 44
TQA's Avatar
Originally Posted by kjzerr View Post
Hello all:
I am repainting my boat by rolling and tipping. I am using Petit EZpoxy2 two-part epoxy finish. I'm having trouble getting the finish to flatten out. Also, the areas where the tipping overlaps is visible after the finish dries.
The past couple of days the temps have been 85-90 degrees with low humidity. Petit recommends 50-90 degrees for application, so it seems all is in order. I've been adding 8oz of Petit brushing thinner to 32oz of finish. I tipped the first coat with a badger hair brush and the second with a foam brush. Both left visible brush marks. I sanded down the first coat to remove the marks, switched to the foam brush, and ended with the same look.
Should I be thinning it more? Should I not thin at all? Any thoughts would be helpful. Tomorrow's supposed to be a few degrees cooler. Could the temp be the issue?
I have attached a couple of pics. You can see that the shine is good. The one of the transom shows the reflection of the rudder, but notice the brush marks at the right side of the transom. The other is my reflection. All would be fine if I was looking for some abstract artist look, but that's not what I'm going for. ;-)
Again, any assistance would be greatly appreciated.
Get a piece of glass and set it at about 70 degree from the vertical. Roll and tip and see if the brush strokes disappear, if not add more thinner, if it sags and runs add more paint.
Wipe the paint off the glass with thinners let it flash off and try again. This worked for me with International 2 pack and the finish was near a perfect spray job.
bljones likes this.
TQA is offline
post #13 of 20 Old 06-02-2013
Use a quality foam brush from Lowes. Do not cheap out on the foam. I switched to foam for my second coat and the finish was much better. This fall I will sand out the remaining brush strokes and re-do with only foam.
i_amcdn is offline
post #14 of 20 Old 06-02-2013
KJZ,
It takes 2 people to roll & tip so if you're trying to do this alone....
If you need an extra hand send me an email, we're practically neighbors. I'll be painting my boat this year so maybe we can help each other out.
Bob
jimgo likes this.
I'm not happy unless I'm complaining about something.
I'm having a very good day!
misfits is offline
post #15 of 20 Old 06-02-2013
tommays's Avatar
It really does not matter that much what you tip the paint with as the most important thing tipping does is pop air bubbles from the roller
The roller really DOES matter as its job is to lay down and even film of paint and understanding how much paint you can load on it and how far that goes is the KEY
You must tip ONE TIME AND FAST then you must leave it alone to do its thing and roll the next section ASAP before you lose the window to tip the joint between sections
AS TAQ explained the paint viscosity and the drying time the thinner provides must be at the point the paint can self level
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #16 of 20 Old 06-06-2013 Thread Starter
kjzerr's Avatar
Thanks for the offer, Bob. My wife has been helping, and we put the final coats on over the past couple of days. It came out acceptable, but not what I expected. Of course, my expectations are very high. In the water it will look great, I believe.
I would gladly assist you with your boat when you get around to refinishing it. My schedule is very flexible. Just drop me a line.
K
p.s. Thanks again to everyone who responded. Each one of you had something valuable to offer. I am always amazed at the response on this forum and the quality of the information. As a newbie, this forum has been a valuable tool to help me get started with sailboat ownership.
S/V "Spirit" - 1971 C&C 36R
kjzerr is offline
post #17 of 20 Old 06-07-2013
I painted my hull with petit easypoxy and had GREAT result. The key was the between coat sanding. Did 5 coats and sanded between coats with progressively finer sand paper and between the 4th and 5th coat I used a scotchbrite pad. I'm probably telling you something you already know....
seafrontiersman is offline
post #18 of 20 Old 06-07-2013
Thank you!
misfits is offline
post #19 of 20 Old 06-08-2013
Over Hill Sailing Club
smurphny's Avatar
Originally Posted by Barquito View Post
I have been having trouble with my two part paint, too. I'm using Interlux Perfection. I think my trouble is that on the days that I have had to paint there has been too much wind. I can't build a cover over the boat in my boat yard. My solution is going to be to lower my expectations. These modern paints are optical illusions. A few people in the yard have been blown away by what an awesome paint job I have until they get a closer look. The shine makes you think it is perfect until proven otherwise... That is my theory, and I am sticking with it.
If it's any consolation, I have not been able to get Perfection to lose brush marks although I've tried a few times. It's always disappointing when waiting for brush marks to flatten and it doesn't happen. Must be doing something wrong or not using the right thinner. It seems difficult to work with.
smurphny is offline
post #20 of 20 Old 06-08-2013
S/V Wyndwitch - Morgan 24
oysterman23's Avatar
Well might as well jump in here...Im doing the same job on decks cockpit and cabin with System Three Ws LPU which is a water based poly finish. It likes humidity but not wind or high temps. I wont even try it over 80 or if the surface has been cooking in the sun for most of the day. Strictly mornings or overcast days. The suggestions on thinning are right on but watch how you wet the tipping brush....pure thinner or pure water principle and effects the same...dilution is the idea but not too much or you have a problem again.
doesnt hurt to have a small bit thinned in a covered container for the tipping brush and to remind you of the approx "viscosity" or your working liquid prior to any exposure. Petro or water both are remarkably volatile in these conditions of wind or heat.
Anyway mines beginning to look good at 10 ft...just wet sanded with 320 for the next campaign!!! Good luck all!
oysterman23 is online now
Tipping? labatt Chartering 114 03-26-2016 10:01 PM
Rolling and tipping - the reality chrisncate Gear & Maintenance 9 09-20-2011 10:32 PM
Tipping at Marinas Donna_F General Discussion (sailing related) 62 07-16-2011 09:46 AM
tipping Loualfr General Discussion (sailing related) 4 07-03-2008 08:12 AM
Tipping ianl General Discussion (sailing related) 4 01-20-2003 09:07 AM
