Self Tailing Winches - Page 3 - SailNet Community
 5Likes
post #21 of 31 Old 06-04-2013
mbetter's Avatar
Re: Self Tailing Winches
Originally Posted by SchockT View Post
In my mind if you were going to the expense of replacing your primary winches with new ones, why would you get anything BUT self tailing? It would be silly to buy brand new winches and then put those Winchers on them!
I can get a pair of used two-speed, oversized primaries for $300-400. One self-tailer will be at least twice that, and it will probably be barely big enough. So it would be four times more expensive to get self tailers, and possibly more.
That's the kind of price difference that makes you think twice.
mbetter is offline
post #22 of 31 Old 06-04-2013
Sabreman's Avatar
I'd also suggest buying used. I picked up a really nice Lewmar 40ST on eBay for $400. It's going to replace my Lewmar 30ST mainsheet winch which will replace my Lewmar 30 non-selftailing main halyard winch.
A winch is virtually indestructible, so used is very viable.
Sabre 38 "Victoria"
Sabreman is offline
post #23 of 31 Old 06-04-2013
No question if I was re-winching it would be Andersens.
Beautiful winches, no doubt.
Recently while sailing with friends they mentioned they needed to rebuild their LM's but were a little apprehensive about disassembly. So I took one apart quickly with my bare hands to show them the main assemblies. There's a special place in my heart for that kind of engineering design.
capttb is online now
post #24 of 31 Old 06-08-2013
STARBOARD!!
KeelHaulin's Avatar
For those who say ST winches are slow for racing, I suggest you use the ST head only when cleating off. Lots of people also don't know how to use an ST winch; they put the line over the tailer before pulling the slack up. use the line over the drum only when sheeting the slack; then put it over the ST and trim the sail. It's much faster and reduces wear on the tailer. Also make sure there are at least 3 wraps on the drum because the finger on the tailer can get broken off with too much load on it.
As for the cost; well it's the difference between having to struggle to grind with one hand and tail with the other, or just grinding the winch. much easier so the price of the new units and resale value of the older ones reflect that.
KeelHaulin is offline
post #25 of 31 Old 06-08-2013
I have some of the older Lewmar Alum. racing STlers. (<1985)
They aren't bad but the self tailing mechanism doesn't work as well with smaller diameter lines as the newer models (by Lewmar and others.). If you buy used, you might check out this factor.
Randy Browning
Norwalk, CT USA
sonosail is offline
post #26 of 31 Old 06-08-2013
SchockT's Avatar
Yes used is an option, but winches certainly are NOT indestructible if they are not maintained. I wouldn't buy a used winch without taking it apart and inspecting it very closely. Pawl sockets get worn and sloppy, teeth get worn and damaged, bearings wear. People replace winches for a reason!
1979 Santana 30 Tall Rig
Hull#101
SchockT is offline
post #27 of 31 Old 07-14-2013
Does anyone know how to get the self trailer off a variety winch? I see two openings with rounded brass (no place to place screwdriver or Allen wrench). I was told to pry of the top but the rim is to narrow to get a screwdriver blade under. Btw, I am a bit of an idiot mechanically, but was able to take apart the non self tailers and put them back together. Thanks!
Sanitie is offline
post #28 of 31 Old 07-14-2013
4KSB driver.
SHNOOL's Avatar
Ok, my boat is MUCH smaller than your folks at 25 feet.
I've considered ST winches for it... I solo sail a lot (even race solo some times)...
I cross sheet even as the winds come up so that I can just grab the sheet, sweat it, and take up the slack. Because of this though my elbow is a mess, but that's another story.
The statement that you need 3 wraps to use the ST function bothers me... I am assuming I can continue to use them as I describe (without the ST function)... but if I want more on them and wanna spare my elbow, I'd need to wrap the leeward side 3 times?
This is my typical "cross sheeting" in action. From the helmsman position, I lean back and pull in the center. Obviously none of this was necessary during THIS sail (6mph winds)... but I've used it successfully solo sailing to 25 knots with the 155 up.
1983 WD Schock Wavelength 24. Production boat limit tester, blue-water bucket owner, with wine taste on a beer budget.
SHNOOL is offline
post #29 of 31 Old 07-14-2013
SchockT's Avatar
What is a variety winch?
When people talk about prying off the top of a winch what they are referring to is the retaining ring that goes around the center drive hub. Once you take that ring off, the top plate comes off and usually the drum lifts off. (that is typical on standard non-ST winches) That being said, not all winches work that way. It helps to know the make and model of winch, and perhaps even post a pic.
Hull#101
SchockT is offline
post #30 of 31 Old 07-14-2013
SchockT's Avatar
The number of wraps really depends on the winch, the type of rope, and the amount of load, but I am not clear on how more wraps is a problem for your elbow! There is no reason you couldn't use self tailers when you cross sheet. You could just put one or two wraps on the leeward winch, haul as much sheet as you can by hand, then put a couple of wraps on the windward winch and tailer, and then you are free to grind with one hand and steer with the other.
If you have an issue with strain on your elbow, the best remedy would probably be to upgrade to more powerful winches.
Hull#101
SchockT is offline
Barlow Self Tailing Winches - not tailing properly meganvt01 Gear & Maintenance 2 04-17-2012 06:44 AM
Lewmar wavegrip Self Tailing winches lj2sailing Gear & Maintenance 10 04-04-2009 05:15 AM
Enko self-tailing winches klubko Gear & Maintenance 4 09-18-2007 02:45 PM
Non self tailing winches: A cheap fix? LWinters Gear & Maintenance 8 09-17-2007 11:09 AM
self tailing winches but what size saurav16 Gear & Maintenance 24 07-11-2007 09:06 PM
