Blown outboard prop shaft seal? - Page 2 - SailNet Community
post #11 of 16 Old 06-11-2013 Thread Starter
GrahamO's Avatar
I'm afraid I got it into the shop before I read the last few posts.... Too busy to mess with it at the moment anyway but I fully agree with the 'learn to be self sufficient' philosophy - oh well. I
suspect I will end up paying for a new seal that I probably did not need. Mind you, that pales into insignificance compared with the cost of my poor choice of yards this winter. Learning about looking after a large boat can be a VERY expensive process....
Thanks as ever for the support and advice.
Graham
Graham and Janaki
Bristol 38.8
GrahamO is offline
post #12 of 16 Old 10-18-2013
美國佬
willyd's Avatar
Re: Blown outboard prop shaft seal?
Originally Posted by Sea Dawg View Post
You need to remove the prop and prop bearing carrier. It's not hard, and you'll be pleased with the confidence that you get. Look at a picture on Boat.net for your motor and you'll see it's a simple piece of machinery. Here's how it likely looks. Drain the oil. Careful removal and observation with a few pictures from a digital camera and you'll have it back together in a day. Order your parts ahead of time... anything rubber. Don't lose track of any shims or the order they came out. Good luck. 2002 And Earlier MFS6A Tohatsu Outboard GEAR CASE (PROPELLER SHAFT) Diagram and Parts
Sea Dawg, how do you get parts 10-14 in the diagram off of the shaft? My manual seems to skip this part, saying they all just slip off the shaft. I assume I need to use a puller, but not sure what to do here. Any help would be appreciated.
1964 Whitby 25
Severna Park, Maryland
willyd is offline
post #13 of 16 Old 10-19-2013
Place in forward gear. Drain gearcase oil. Spray Croil or PB Blaster in the gearcase where salt crust builds and holds carrier from sliding out. Make a J-hook pulling tool out of flatbar by grinding a notch on a bench grinder. Grab the other end with vice grips to give you something to hammer against. There's openings on the inside of the carrier you can hook onto for pulling. Move from side to side a little at a time. 10 11 12 13 14 will be coming out. Don't lose track of orientation of pc's 2 3 5 6 7 8 9. Take notes. Note seal 11 and bearing 13 orientation before removal as compared to your new ones. A wooden or teflon dowel will be used to knock them out or a flat screwdriver for the seal. The gear oil is either leaking along the shaft from the seal or oring 12 along the gear housing. The new seal needs a smooth surface to run on at the shaft. Strap lap the shaft with fine emory cloth. The oring needs a smooth surface in the gear housing. Hand smooth any rough areas, but don't remove too much metal. Marine grease running areas at assembly so these don't tear your new parts. Pay close attention that you don't leave out the shifting parts and as you slide it back together rotate shaft until you get the reverse gear and splines lined up and don't force it until it starts into the bearing. Alternate taps with a mallet on the carrier should get you there. Lastly, use marine anti seize on the bolts.
Sea Dawg is offline
post #14 of 16 Old 10-19-2013
Sea Dawg is offline
The Following User Says Thank You to Sea Dawg For This Useful Post:
willyd (10-20-2013)
post #15 of 16 Old 10-23-2013
美國佬
willyd's Avatar
Thanks for all the help so far. I got it apart, removed the prop seal, replaced the O ring, greased things up, and got it back together last night, but I'm not sure I got the thrust bearing (part 17) down all the way on the shaft - the bevel gear can still move a bit, maybe 3/16", back and forth on the shaft.
1964 Whitby 25
willyd is offline
post #16 of 16 Old 11-10-2013
I can't see how pc 17 controls the bevel gear movement. I'm thinking maybe the bearing or seal didn't go all the way home. THey have an interference fit. To push the seal home protect it with a piece of hard wood and smack it nice and square to drive it home. Hoping by now you got it finished, but try that if not.
Sea Dawg is offline
Prop Shaft Seal issue please help DulceSuerna Gear & Maintenance 8 01-23-2011 06:57 AM
Pss Shaft Seal Magic1 Gear & Maintenance 16 10-07-2010 02:03 AM
PSS shaft seal Windborn Gear & Maintenance 26 02-01-2009 11:10 PM
PSS Shaft Seal Question danielgoldberg Gear & Maintenance 16 03-24-2008 12:53 PM
Shaft seal Edo Kazumichi Gear & Maintenance 9 11-23-2006 12:03 PM
