Anchor Riding Sail vs Split Backstay - SailNet Community
 3Likes
  • 1 Post By chef2sail
  • 1 Post By adki110
  • 1 Post By svHyLyte
post #1 of 4 Old 06-02-2013 Thread Starter
HANUMAN
RobGallagher's Avatar
I have an anchor riding sail from my old boat. Just re-discovered it in storage.
My new boat, of similar size/weight, but sails even more at anchor, has a split backstay.
Is there a way to rig this sail that is effective? I seem to remember that it required a high degree of tension and I don't know how I could rig it so it would work properly.
Help?
HANUMAN
'88 C&C 30 MKII
NOANK, CT
RobGallagher is offline
post #2 of 4 Old 06-03-2013
chef2sail's Avatar
Re: Anchor Riding Sail vs Split Backstay
Try and shift your traveler over to one side about half way first and see if that helps dampen your sailing motion at anchor.
Dave
RobGallagher likes this.
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is offline
post #3 of 4 Old 06-03-2013
I used to run the riding sail up the toppling lift with the main halyard then tie it forward.
adki110 is offline
post #4 of 4 Old 06-03-2013
Old as Dirt!
svHyLyte's Avatar
A riding sail does not need to be hanked to a stay to be effective. It will work quite well set flying with a halyard, two lines, one to each stern quarter from the clew, and a forward line from the tack to a point near the base of the mast. Set the clew just above the level of the boom. BTDT
svHyLyte is offline
Double VS. Split Backstay cas8100 Gear & Maintenance 3 06-03-2013 09:20 AM
Catalina 25 split backstay tension davidpm Gear & Maintenance 3 09-15-2011 09:02 PM
How do you affix your anchor sail to your backstay? Bene505 General Discussion (sailing related) 8 08-23-2010 07:06 PM
Dual Backstays or Split Backstay CodeZero Gear & Maintenance 9 08-06-2009 10:41 PM
Split Backstay + and -s brianontheroad Gear & Maintenance 26 09-12-2008 12:10 PM
