Interior Lighting Upgrades - SailNet Community
 7Likes
post #1 of 59 Old 06-03-2013 Thread Starter
MMR
MMR's Avatar
Send a message via AIM to MMR
Our 1987 Irwin 38cc has a multitude of original interior light fixtures (13 to be exact) that have sun / heat aged plastic lenses that we are replacing. We've found a source with the original molds and are expecting to get these some time this week. (At the same time we ordered two replacement LED bulbs specifically for these fixtures to see if we like the light color, before going the full LED route)
You can see the original fixtures are pretty brown:
Also, note the PO's version of LED upgrade
Notice the light switches in the lenses (centered on the square ones, on one end on the rectangular ones). The new lenses do NOT have a hole drilled for the switches - so I'm thinking why not take the opportunity to rethink the switches rather than just reuse what is there.
I'm wondering if a rocker type switch on the side of the fiberglass "pad" would work. I've been trying to source mini rocker switches and have come up with some sources (mostly automotive and black w LED indicator lights) but would love some feedback on feasibility of this plan and other switch ideas.
Here's the insides of one of the square fixtures. You can see the fiberglass lip that the fixture sits inside.
My ideal would be little cream colored rocker switches on the side of that lip.
Thoughts? Suggestions?
MMR is offline
post #2 of 59 Old 06-03-2013
Learning the HARD way...
eherlihy's Avatar
Re: Interior Lighting Upgrades
This seems you have the plan fully worked out. Good luck and post pics!
It looks like you may have some water intrusion (probably through the hole for the wiring) in the fixture. You should look into that.
Amazing how the original plastic discolored over time. The PO did not smoke, or did he?
eherlihy is offline
post #3 of 59 Old 06-03-2013 Thread Starter
MMR
MMR's Avatar
I think it's old, but will double check!
PO did not smoke...I can't wait to get the new white lenses and LEDs in. I think the interior will be MUCH brighter - hence the need to individually control the lights with switches!
MMR is offline
post #4 of 59 Old 06-03-2013 Thread Starter
MMR
MMR's Avatar
I've found "white" switches!
Rocker Switches
So, the question is, are the specs right for boat usage?
Is it weird to be so excited about a rocker switch?
MMR is offline
post #5 of 59 Old 06-03-2013
blutoyz's Avatar
Rocker Switches
Yup...
But considering that your "upgrade" from the PO would suffice for me I have to say you should not give my opinion any weight
MMR likes this.
blutoyz is offline
post #6 of 59 Old 06-03-2013 Thread Starter
MMR
MMR's Avatar
MMR is offline
post #7 of 59 Old 06-03-2013
s/v Tiger Lily
dvuyxx's Avatar
At the same time we ordered two replacement LED bulbs specifically for these fixtures to see if we like the light color, before going the full LED route.
Be sure to get "warm" vs. "cool" LEDs. If it doesn't specify, I always assume it is the cool blue. The warm feels a lot like incandescent.
Severna Park, MD
Pearson 35 - s/v Tiger Lily
dvuyxx is offline
post #8 of 59 Old 06-03-2013 Thread Starter
MMR
MMR's Avatar
I'm concerned about the light quality, for sure. Here's our source:
Irwin LED replacements
They offer Natural and Warm White. We're getting one of each to see how the colors compare, and work in the various areas in the boat. Not cheap, but since about 1/2 the interior fixtures have non working bulbs we have to replace them anyway. We may go florescent in the low use areas (Vberth) and LED in the salon...still working it!
MMR is offline
post #9 of 59 Old 06-03-2013
eherlihy's Avatar
That minimum order quantity of 500 will assure that you have spares.
eherlihy is offline
post #10 of 59 Old 06-03-2013
Asleep at the wheel
jimgo's Avatar
I would be careful about flourescent. I know the CFL's contain mercury. If one should break (I know, what are the odds since it's on a rolling, pitching boat?), you'll have a HazMat scene on your hands, and mercury poisoning isn't fun (only do the online search if you have a strong stomach). The tube lights may not be as bad. But in the end, the LED's will give you longer life and lower power use. If you have to, put them behind a diffuser to give you a slightly different color.
- Jim
Home: Western Philly 'burbs
1980 Allmand 31
1975 Albacore 15
jimgo is offline
The Following User Says Thank You to jimgo For This Useful Post:
Familycruisers (06-05-2013)
Interior Lighting bradway5 Gear & Maintenance 12 10-12-2012 11:44 AM
Planned interior upgrades for Oh Joy CharlieCobra General Discussion (sailing related) 25 12-12-2009 10:03 AM
Interior Lighting 1970Columbia34 Gear & Maintenance 29 06-25-2008 06:26 PM
Interior LED Lighting jlubimir Gear & Maintenance 6 05-23-2005 10:32 AM
Lighting Up the Interior Sue & Larry Gear and Maintenance Articles 0 01-27-2002 07:00 PM
