Power Battery Set up for 27ft sailboat - Page 2 - SailNet Community
post #11 of 23 Old 06-05-2013
chucklesR's Avatar
Re: Power Battery Set up for 27ft sailboat
Originally Posted by FirstCandC View Post
Ok I will ask a dumb, somewhat related question. One starting and one deep cycle battery on a Perko battery switch. Ok to start on the starting battery, and then switch to "both" on the selector switch, so that the batteries can charge via the alternator? Will this harm the anodes??
Leave it in 'both' anytime the engine is running or you are plugged into a charging source, put it to the house bank when not or at night if you have solar.
That keeps the start charged and takes the load where designed whilst hanging about and draining.
No need to be anal about it, switch the setting whenever you first go below after shutting down the engine. If you forget it for a day while on the hook you should be able to start using both as well.
chucklesR is offline
post #12 of 23 Old 06-05-2013
chef2sail's Avatar
Originally Posted by SlowButSteady View Post
That's true if the wet cell and AGM batteries are hard wired together. However...
The only connection between the two banks (unless I select "BOTH" on the main switch, which I don't) is via the battery combiner. The combiner only connects the banks together when it senses a charging voltage ( >13.3V, I think), and the combiner limits the charging voltage to the AGM to about 14.2V (just below the recommended max charging voltage of 14.4V for a nominal 12V AGM).
The "acid test" (pun intended) is that everything seems OK with the AGM battery in this configuration for over three years now.
So you don't have a dedicated battery charger hooked into the batteries?
I was under the impression the float charge is different between the two types. Also how do you equalize and desulfate unlike batteries?
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is online now
post #13 of 23 Old 06-05-2013
"Be sure to mount whatever you get with the cells running fore and aft, ie. the row of caps running port/starboard".
Why? First I've heard of this but then there is a lot I've not heard of
jimkyle99 is offline
post #14 of 23 Old 06-05-2013
Senior Slacker
SlowButSteady's Avatar
As I said above, both the solar panel and the shore power charger are wired to the main (golf cart battery) bank. The Yandina combiner limits the voltage to the AGM battery (bank). I rarely use the shore power charger, and the charge controller on the solar panel limits the voltage once the main bank is charged. The controller does have an "equalize" mode that kicks in once a month, but this doesn't matter to the AGM because it's "shielded" behind the combiner. I suppose that the AGM does experience higher voltages than it probably should for short periods, but this doesn't seem to have much of an effect, since the AGM is six-years-old now and seems to be fine (although the entire system has only been in place for two or three years). In any case, the AGM shouldn't need desulfonating since it's almost always fully charged.
Never forget them. Do something to prevent it from happening again.
Charlotte Bacon, Daniel Barden, Rachel Davino, Olivia Josephine Gay, Ana M. Marquez-Greene, Dylan Hockley, Dawn Hochsprung, Madeleine F. Hsu, Catherine V. Hubbard, Chase Kowalski, Jesse Lewis, James Mattioli , Grace McDonnell, Anne Marie Murphy, Emilie Parker, Jack Pinto, Noah Pozner, Caroline Previdi, Jessica Rekos, Avielle Richman, Lauren Rousseau, Mary Sherlach, Victoria Soto, Benjamin Wheeler, Allison N. Wyatt
SlowButSteady is offline
post #15 of 23 Old 06-05-2013
no longer reading SailNet
Alex W's Avatar
Is the OP's 27ft boat inboard or outboard? If it is an outboard boat then there is no reason to have the complication of a starter vs house battery bank. Just have a single bank (or maybe even just a single group 27 battery if electrical needs are low). If the battery dies you can always pull start the motor.
Alex W is offline
post #16 of 23 Old 06-05-2013
Originally Posted by Alex W View Post
Is the OP's 27ft boat inboard or outboard? .
Outboard... unknown if a charging coil/alternator is part of the picture.
Faster is online now
post #17 of 23 Old 06-05-2013 Thread Starter
I am running a 8hp 4 stroke electric start outboard, depth/fish finder, stereo and running lights.
We rarely use interior lights as we are afraid to have no battery left. Sounds as if my deep cycle is dead. I am thinking of buying 2 6v trojans running parallel and 1 12v deep cycle for engine with a built in charger as our boat is docked at a marina with power each night.
Will this work?
mbaillie is offline
post #18 of 23 Old 06-05-2013
Alex W's Avatar
That will work, but that is extreme overkill for what you've described as your needs.
On my Catalina 25 we had two group 24 batteries in parallel (for a combined 150AH). They've never been plugged into shore power and charge off of solar and the tiny inboard alternator. Even with 12 days of cruising we never got below 80% state of charge.
I'd start with a single group 27 battery (about $100). If you find yourself needing more than get a second. 3 batteries with no fridge is overkill for an outboard boat.
Alex W is offline
post #19 of 23 Old 06-05-2013 Thread Starter
im running a single group 24 and it keeps dying. I have a second group 24 that dies also. Time for new batteries. I want the most economical reliable battery setup for over night - 3 day trips so we can run stereo depth finder and running lights the whole time.
mbaillie is offline
post #20 of 23 Old 06-05-2013
Alex W's Avatar
More batteries is not cheaper.
What is the power consumption of your running lights and depth fnder? You can then figure out the battery capacity needed.
You can probably upgrade your running lights to LED for less than the cost of adding a second or third battery. LEDs are approximately 10x more efficient, it's a big deal.
Alex W is offline
Tags
agm , batteries , chargers , charging , deep cycle
Dauphin Island power cut when sailboat hits power line - Press-Register - al.com (blo NewsReader News Feeds 0 08-28-2012 04:00 PM
Computer battery heat and power use SteveInMD Gear & Maintenance 1 09-26-2008 07:13 AM
How much battery power / capacity Petar Gear & Maintenance 3 02-18-2008 04:26 PM
Mooring and Battery Power MSam General Discussion (sailing related) 11 04-04-2002 06:52 PM
Boat Battery Power East Penn Manufr. Gear and Maintenance Articles 0 01-18-1999 07:00 PM
