Outboard engine lift - SailNet Community
 2Likes
post #1 of 12 Old 06-04-2013 Thread Starter
I am looking where to purchase a breeze industries engine lift. The company seems to be no longer. Any suggestions where to find one or someone who can fabricate one in the vancouver area?
mbaillie is offline
post #2 of 12 Old 06-04-2013
Re: Outboard engine lift
Is your boom long enough to use it along with your topping lift or halyard? I've never done that but I've seen photos of it being done and it seems feasible. My outboard is about 80 lbs so I just pick it up into place. I once had to lower it onto the bracket with one hand while holding to the pulpit with the other all the while getting slammed by 4 foot waves. I have witnesses but no negatives. Or is it the other way around?
DonScribner is offline
post #3 of 12 Old 06-04-2013
I don't know, but last year I installed the Garhauer engine hoist. No complaints, and the price is reasonable.
chef2sail and bljones like this.
MarkSF is offline
post #4 of 12 Old 06-04-2013 Thread Starter
I am looking for a engine mount lift for an outboard motor on a c27. One so the motor can be pulled vertical out of the water when sailing or in rough seas.
Something that works with a transom mounted outboard.
mbaillie is offline
post #5 of 12 Old 06-04-2013
Asleep at the wheel
jimgo's Avatar
I'm sure others will correct me if I have the wrong one, but the Garelick lifts are generally considered to be top-notch:
Garelick Outboard Bracket
- Jim
Home: Western Philly 'burbs
1980 Allmand 31
1975 Albacore 15
jimgo is offline
post #6 of 12 Old 06-04-2013
Lots of options here, a small sampling here:
Adjustable Outboard Motor Mounts - iboats
I think the trick for ease of use is to get one rated for a bigger engine than you have. A 9.9 ob usually weighs close to 100 lbs and is often marginal for the basic bracket.
There are other brands that are more elaborate to install but have a longer lift travel, using rope tackle to assist.
You want page 578 of this catalogue:
Plastimo
Once you pick a model you might be able to get Steveston, Martin, Nikka, or -gasp- West Marine to order one in for you.
Faster is offline
post #7 of 12 Old 06-04-2013 Thread Starter
The breeze industries design was a lift that traveled on 2 stainless steal rods directly up and down. They fit perfectly for transom wells with a cut out.
mbaillie is offline
post #8 of 12 Old 06-04-2013
Do you have the normal C27 outboard transom setup? of was it formerly inboard powered?
Faster is offline
post #9 of 12 Old 06-04-2013 Thread Starter
I have a normal c27 outboard transom setup
mbaillie is offline
post #10 of 12 Old 06-04-2013
Does the engine not tilt free into the lazarette? Do you want to modify it to lift straight up the transom then?
Faster is offline
Tags
breeze industries , engine lift , vertical lift
Outboard Motor Lift Bracket: 1 Me : 0 i_amcdn Gear & Maintenance 7 05-21-2013 03:18 PM
outboard motor lift seapony2 Gear & Maintenance 2 10-02-2012 03:17 PM
Outboard lift davit for dinghy motor on 27' cal lans0012 Gear & Maintenance 8 08-19-2011 10:01 PM
Looks like I need a new outboard engine Albie Gear & Maintenance 2 09-11-2007 07:10 PM
Help w/ outboard lift NomadPa General Discussion (sailing related) 3 09-11-2006 02:55 PM
