Screw on the mast, Mast Steps - SailNet Community
 1Likes
post #1 of 26 Old 06-05-2013 Thread Starter
old guy :)
rikhall's Avatar
OK - Opinions please. I am considering:
sold by Defender.
All polite suggestions welcome. 34 foot boat, mast is 41 feet high
I currently use a BlackDiamond climbing harness and a pair of Jumar Ascenders.
Thanks
Rik
Irwin Citation 34
Mystery
rikhall is offline
post #2 of 26 Old 06-05-2013
marcusc130's Avatar
Seems like a ton of stuff for sheets, halyards, sails etc. to get caught on. I'd stick with the harness personally.
marcusc130 is offline
post #3 of 26 Old 06-05-2013
Seņor Member
PorFin's Avatar
Re: Screw on the mast, Mast Steps
Rik,
The ones you are considering are the same (or nearly so) ones I have on our mast.
I too use a harness and ascender set up; when we first got the boat I was even more Neanderthal, using old Army techniques (a swiss seat made from a sling rope and a Prussik knot in lieu of the ascender.)
Overall, I'm happy with the set up. I can safely ascend and descend without relying on another kind soul for assistance (which makes the wife happy.)
When you are figuring out how many you will need, remember that you'll want two parallel ones at the very top -- that makes longer periods standing at the masthead more comfortable.
The only thing that tickles those little hairs on the back of my neck is the lack of a positive stop on the outboard end of the steps.
________
'85 BYB Vagabond 39
PorFin is offline
post #4 of 26 Old 06-05-2013
S/V Lilo, Islander 32
I used the aluminum ones (here) and love them. Never get sheets or halyards caught, and it's so simple to climb up the mask to check something out. (Although I still use a harness and safety line) If a already had ascenders they might not be as useful, but having the ability or climb the mast without needing someone else to winch you up is huge, but you already have that with the ascenders...
S/V Lilo
1964 Islander 32
Saint Helens, OR
IslanderGuy is offline
post #5 of 26 Old 06-05-2013 Thread Starter
old guy :)
rikhall's Avatar
Were they on the boat when you got her or did you install them. If you installed them, I presume you drilled and tapped all the holes. What size bolt? And what about SS bolts on an aluminum mast?
Thanks
Rik
Irwin Citation 34
Mystery
rikhall is offline
post #6 of 26 Old 06-05-2013
Sea Sprite 23 #110 (20)
mad_machine's Avatar
I have wondered about these. Do all the holes weaken the mast?
Art Haberland
In the end all that matters is how fully you loved, how gently you lived, and how gracefully you let go of things that did not belong to you -Buddha
mad_machine is offline
post #7 of 26 Old 06-05-2013
How about stainless rivets sized appropriately to the wall thickness of the mast?
benesailor is offline
post #8 of 26 Old 06-05-2013
Seņor Member
PorFin's Avatar
Thanks
Rik
They were already installed when we took ownership. They are indeed mounted with s/s machine screws, although the exact size escapes me at the moment (I'll check next time I do a boat check.) They are sized to fit the mounting holes in the steps.
Whoever installed them used a sealant on them; not sure if it was TefGel but it could very well be. I've never found corrosion (knock on wood.)
I think with TelGel you'll be fine. A nylon washer between the screw head and the step probably wouldn't hurt either.
________
'85 BYB Vagabond 39
PorFin is offline
post #9 of 26 Old 06-05-2013
Seņor Member
PorFin's Avatar
Rik,
I just realized that the steps you are citing are composite -- ours are aluminum. So not the same, but of a similar design. Disregard the earlier nylon washer advice
________
'85 BYB Vagabond 39
PorFin is offline
post #10 of 26 Old 06-06-2013
Rik,
The mast vibrates quite a bit under some circumstances, wouldn't those folded aluminum steps cause a lot of noise?
SVTatia is offline
Installing aluminium mast steps on steel mast asivesind Gear & Maintenance 10 01-29-2012 10:05 AM
Mast Steps - what to put at the top? bernardmitchell Gear & Maintenance 13 05-10-2011 12:37 PM
Mast steps Atkinsericjr808 Gear & Maintenance 2 08-22-2010 09:27 PM
ABI Mast Steps waltzingmatilda Gear & Maintenance 24 09-18-2007 09:44 PM
mast steps egregerson General Discussion (sailing related) 1 08-21-2006 01:04 PM
