New to sailing...rigging question - SailNet Community
post #1 of 10 Old 06-05-2013 Thread Starter
Why is the rum gone?
Staredge's Avatar
After a 30+ year wait, I finally bought my first boat. 8' Eli Scout sailing dinghy. Yeah, she's small but I figure she'll do to learn on. Really convenient as I have a good sized lake nearby that I can sail her on.
Have a couple of rigging questions, however. I'm trying to figure out how to attach the clew to the boom. A picture of the end of the boom is attached.
The clew was tied to the top loop. There isn't room for an outhaul. Am I ok in just doing the same??? What knots would be best for doing so? It was a mess, and the cord was in pretty bad shape, hence the reason I cut it. Is there a way to do it with hardware instead??
Second question is about the mainsheet. I'm thinking tie it to the bottom eye on the boom, down to the traveler block, then up through the two blocks (one you see in the picture) on the boom. Am I on the right track with that???
Thanks in advance for any help you can give.
Staredge is offline
post #2 of 10 Old 06-05-2013
davidpm's Avatar
Re: New to sailing...rigging question
On a little boat like that I usually just use a short length of line and put a bowline in one end.
Thread it through the clue and the boom fitting, put the bitter end through the bowline and cinch it up.
Secure with a couple half hitches.
Not pretty but fast and simple.
There are a dozen ways to lash it with a piece of light line.
Anything that works.
davidpm is offline
post #3 of 10 Old 06-06-2013
Asleep at the wheel
jimgo's Avatar
Congratulations! Did you see the thread about the Chesapeake SN meet-up? You might consider bringing the boat there to get some advice.
Harken has some great information on rigging:
Harken
Both the Systems and One Design sections may be of interest.
- Jim
Home: Western Philly 'burbs
1980 Allmand 31
1975 Albacore 15
jimgo is offline
post #4 of 10 Old 06-06-2013 Thread Starter
Staredge's Avatar
Might be a bit more involved than what I need, although it opens up another question. I don't have anywhere to cleat off the mainsheet. How big a problem will it be to handhold it while I sail??? Previous owner added some cleats, but nothing near the center of the boat.
Staredge is offline
post #5 of 10 Old 06-06-2013
deltaten's Avatar
Send a message via Yahoo to deltaten
Hand held will work...until ya get tired of it ! Any common garden variety cleat will work. Lotsa small clam cleats available for dinks on E-bay or marina stores fer cheapish. I prefer a clam to horn; as it's quicker to douse the sail in a gust.
Best,
Paul
S/V Chrysalis
'80 Watkins 27
North East, MD
deltaten is offline
post #6 of 10 Old 06-06-2013
Asleep at the wheel
jimgo's Avatar
Something like this might work:
Garhauer Marine Hardware -6283487
- Jim
1980 Allmand 31
1975 Albacore 15
jimgo is offline
post #7 of 10 Old 06-07-2013
On an 8 ft boat it should be no problem holding the sheet. It also really helps you to get a feel for the boat - the force on the main sheet is telling you a lot about wind strength and sail trim. Lastly, having a main sheet you hold makes it quite hard to capsize the boat.
MarkSF is offline
post #8 of 10 Old 06-07-2013 Thread Starter
Staredge's Avatar
Yeah, not capsizing is always a good goal. I'm a bit concerned about getting back in, should I end up in the drink.
Staredge is offline
post #9 of 10 Old 06-08-2013
STARBOARD!!
KeelHaulin's Avatar
In a sailing dinghy your teeth make a good clam cleat
Your description about how to rig the mainsheet was probably the correct way to rig it.
KeelHaulin is offline
post #10 of 10 Old 06-08-2013 Thread Starter
Staredge's Avatar
Having a chance to look a little more closely at the spars, the boom has a cleat on one side. I guess it is set up for an outhaul, unless there's something else I'm missing. I'm figuring a buntline hitch at the clew, run through the loop on the end, and then cleat it off.
Staredge is offline
Rigging question - What's this for? pjsmith Learning to Sail 17 05-29-2013 06:10 PM
rigging question hazel02 General Discussion (sailing related) 7 08-15-2012 12:18 AM
rigging question sailingtime Gear & Maintenance 6 10-18-2010 11:35 AM
Another Rigging Question S/V Delphinus Gear & Maintenance 6 06-21-2007 10:06 PM
Question about my rigging l0keman Gear & Maintenance 26 05-02-2007 03:48 PM
