Very Large Hull Indentation - Page 3 - SailNet Community
 3Likes
post #21 of 22 Old 06-08-2013
pauloman's Avatar
Re: Very Large Hull Indentation
sometimes this sort of damage goes away when the boat is back in the water for a while. You need to adjust your trailer so that the weight ins along the 'keel' line and not on the hull itself. This will also make it easier to get the boat on and off the trailer.
epoxy supplier
pauloman is offline
post #22 of 22 Old 06-09-2013
midlife crisis member
AllThumbs's Avatar
Go sailing. It will pop out slowly over the sailing season. When you say "soft" what you mean is "flexes" this is common of large flat areas (similar to a car hood!). It's no problem at all.
AllThumbs is offline
Tags
hull indents oil can soft
THru-Hull Conversion Large to Small DrB Gear & Maintenance 1 05-03-2013 09:39 AM
Repairing soft spot/indentation in Fiberglass sailboat hull - Rigsy Gear & Maintenance 4 03-05-2013 04:07 PM
Repair hull indentation/flat spot? jameswilson29 Gear & Maintenance 20 12-19-2011 01:48 PM
New large PSC? rwatkis1 Pacific Seacraft 6 11-09-2010 12:49 PM
large main or large headsail? jbarros Boat Review and Purchase Forum 2 09-29-2003 06:13 PM
