Compression post shifted - SailNet Community
 1Likes
  • 1 Post By SloopJonB
post #1 of 6 Old 06-08-2013 Thread Starter
Hey all,
I'm new to the forum and was hoping to get anybody's thoughts on a small question. I recently came across an E35 (Ericson 35') that had gotten a little too close to the shoreline. The fibreglass repair required is within my realm of expertise, but the other problem is the compression post for the desk stepped mast. It's off about 1/2-3/4" due to the collision. Any thoughts on whether this boat is salvageable? Any naval architects that can talk to the complications of a misaligned compression post? I've attached a pic for more info. Any thoughts or suggestions are helpful. Thanks!
Ymir is offline
post #2 of 6 Old 06-08-2013
Re: Compression post shifted
GREETINGS EARTHLINGS ; Looks like a bump to the bow has moved thing off centre quite a bit what other flexing or shearing, delamination has occered that you cannot see or detect by eye, only to fail when it is needed for next time. THING FAIL WHEN YOUR DEPENDING ON THEM, IT HAPPENS ON BOATS, AS ALWAYS GO SAFE
captflood is offline
post #3 of 6 Old 06-09-2013
If you haven't done o already, you should post this question on the Ericson Owners' site. EricsonYachts.org: The Starting Point on Ericson Yachts!
Good Luck
newpbs is offline
post #4 of 6 Old 06-09-2013
TQA
Bombay Explorer 44
TQA's Avatar
Use a 3 ton + lorry jack.
Brace both floor and roof against damage.
Ideally remove mast but at least slacken off all shrouds and stays.
Jack up roof. Reset post.
Not an uncommon procedure in the charter boat repair world.
TQA is offline
post #5 of 6 Old 06-09-2013
Senior Moment Member
SloopJonB's Avatar
Is that the one that went up on Sunset Beach? If so, have you noticed that the bulkhead split through the chainplate mounting holes on the port bulkhead? That's the reason the post is misaligned - the whole assembly shifted over that 1/2".
When I checked that boat out with an eye to bidding on it no-one seemed to have noticed that fact - it's quite hidden away and it wasn't noted on the insurance survey. You can see it from inside the head. I figured removing the chainplate, jacking the post & bulkhead over and building up a wide, solid tab of glass - a glass knee - for the chainplate would be the best solution. The bulkhead tabbing to the hull looked intact, it appeared the lack of tabbing to the deck was what allowed the torsion that cracked the bulkhead and let it shift.
Would be a nasty job due to the limited access but very do-able.
I passed on bidding due to all the regular maintenance issues rather than the accident damage - the glass work would be pretty simple but the sloppy rudder bearings, poor access to many systems etc. put me off. Getting that bent strut off looked like it would be a nightmare.
It was a pretty nice boat otherwise and the bid $ I heard the other viewers tossing about meant it was going to go for next to nothing - good luck with it.
If I can offer any observations or advice, PM me.
Faster likes this.
SloopJonB is offline
post #6 of 6 Old 06-09-2013
snake charmer, cat herder
zeehag's Avatar
you will need to replace the dish under the mast (mast step), as that is probably from where the leak making all this happen is coming from--my ericson 35mII had similar problems bu ti caught them before the compression post as affected.
you will need to inspect the bilge end of the compression post to check for rot.
merely jacking it all up is not going to fix anything on these boats. must be dealt with on a basic level to prevent from further damage.
the areas affected by this mast step problem include the base of compression post, deck sag, and corrosion making the deck swell and crack.
please fix it correctly as these are sweet sailing boats and deserve to be done correctly.
the estimate from a reliably expensive sd yard was 1925 usd to replace the dish and correct the deck problem and reskin coach house under mast...that was 6 yrs ago.
formosa 41, cruising tropics
zeehag is offline
Catalina 27 compression post MarkusM Gear & Maintenance 22 11-20-2014 07:25 AM
PSC 34 compression post cvsheppard Pacific Seacraft 13 04-13-2014 03:41 PM
Need ideas for a new compression post SailingWebGuy Gear & Maintenance 12 10-23-2010 05:21 PM
Compression Post? SailOntario Gear & Maintenance 11 08-24-2006 10:03 AM
C&C25 compression post jimgre Gear & Maintenance 2 03-28-2001 08:03 AM
