Removing carpet from headliner - SailNet Community
post #1 of 10 Old 06-10-2013 Thread Starter
QuickMick's Avatar
My new to me Macgregor Venture 222 has this really funky grey carpet on 1/2 of the headliner. It has to go. Why anyone would put a dark color ceiling in a small boat is beyond me.
Anyone do this before? Any tips? Any idea of how much adhesive gunk I may be revealing?
thanks
How inappropriate to call this planet Earth when it is quite clearly Ocean ~ Arthur C. Clarke
Quinn McColly
Macgregor Venture
QuickMick is offline
post #2 of 10 Old 06-10-2013
Tartan 27' owner
CalebD's Avatar
Re: Removing carpet from headliner
Quinn,
Seems as though you have downsized your boat! did I miss that story somehow?
I've never had to remove carpet glued to the inside of a cabin but it will take some experimenting to figure out the best way, and you will be an expert in this by the time you have finished the job.
Start with the less invasive methods and work your way up to TNT.
Mechanical methods of removal involving razor blades, chisels may prove most effective.
Once only the adhesive remains try different solvents to see what works best.
Again, start with the least invasive stuff: goo-gone, goof off and work your way up to stuff like gasoline/lacquer thinner.
do you plan to put another fabric or covering up, or leave it as bare fiberglass?
Good luck.
Everybody has one:
CalebD is online now
post #3 of 10 Old 06-10-2013 Thread Starter
QuickMick's Avatar
yeah now I am married the trailer sailor is better for us. lots of great sailing just a couple of hours away, huntington lake, monterey bay etc. Actually she found the boat and encouraged me to put an offer in on it! which means as for any design choices while I may be the captain, she is the admiral. She is thinking of cloth or maybe paint.
Quinn McColly
Macgregor Venture
post #4 of 10 Old 06-10-2013
Sea Sprite 23 #110 (20)
mad_machine's Avatar
ugh carpet. I remember when my parents bought their grampian, the carpeting around the quarterberth was so moldy that going down there to even clean would make your eyes water and your lungs spasm.
Paint is the way to go
The good news is.. as the carpet is probably older.. it should come off fairly easily as the glue should be dried out and brittle
Art Haberland
In the end all that matters is how fully you loved, how gently you lived, and how gracefully you let go of things that did not belong to you -Buddha
mad_machine is offline
post #5 of 10 Old 06-10-2013
Barquito
Barquito's Avatar
Unless the glue doesn't come off easily. Then the headliner will be a mess. It may be difficult to get it smooth enough to paint. Then, maybe a vinyl liner would cover up the mess.
Valiant 32
Barquito is offline
post #6 of 10 Old 06-13-2013
I had something similar on the inside cabin walls of my Edel 665. Ugly, grassy foam backed wallpaper glued on.
I pulled it off and then wire brushed off the foam. Then I used my multi-tool scraper to physically pry off the clumps of glue.
I then glued cork panels on with construction adhesive.
i_amcdn is offline
post #7 of 10 Old 06-13-2013 Thread Starter
QuickMick's Avatar
HA my last boat was a G30 and I had to deal with the same stuff! It was so mottled and disgusting. Mine had that yellowish stuff that kinda felt like dirty old sheeps wool or something. I ruined three shirts getting that stuff out.
Q
Quinn McColly
Macgregor Venture
post #8 of 10 Old 06-13-2013
I grew up in a carpet store. Did nothing but carpet for 15 years. I've taken carpet glue off of everything.
Forget solvents.
is the surface smooth or rough glass? If smooth a wallpaper scraper (like a hyde) with an insertable blade. If it's rough, it'll be tough scraping with a blade. then use a 4" putty knife. Get it as close as you can then try either very course sandpaper of a wire brush (probably sandpaper).
What do you plan to finish with? Paint. If so you can prep the rough surface by fairing with epoxy or resin.
one great thing to re-cover with would be cork. It comes in 4' wide running lengths. Anti microbial, insulation, and cork repels insects. glue it up with an anti-microbial adhesive like 5200 or hydroment ultra set. Be good forever.
daledog is offline
post #9 of 10 Old 06-13-2013
Barquito
Barquito's Avatar
5200 would be forever.
Valiant 32
Barquito is offline
post #10 of 10 Old 06-13-2013
yes it would...so would cork. Either adhesive would seal from the inside against leaks. I planned on cutting out the area around any nuts for fittings and doubling cork over the access. You can sand it, round edges, stain it, epoxy it, oil it or leave it raw (which would be best for the anti-insect properties). It would seam well, last forever and be beautiful and functional. The Toledo Ohio Museum of Art has cork flooring, it's been down for a hundred years....
daledog is offline
Removing original headliner jaschrumpf Gear & Maintenance 3 01-05-2010 05:50 PM
Carpet in the cabin wintermute11 Gear & Maintenance 14 01-16-2009 11:01 AM
replacing carpet marinesniper Gear & Maintenance 5 02-15-2008 07:28 PM
removing O'day 32' headliner jknappsax O'Day 1 09-04-2006 07:00 PM
Cabin Carpet rcibul Gear & Maintenance 4 08-15-2006 09:55 PM
