Opening Port/Window Identification help? - SailNet Community
post #1 of 3 Old 06-10-2013 Thread Starter
Asleep at the wheel
jimgo's Avatar
When I went to the boat this weekend, I saw signs of water intrusion. I rebedded the chainplates a few weekends ago, and while I'm not 100% convinced that I did everything perfectly, I tend to think that the water is probably coming from somewhere else. There are three opening ports on either side of the boat, and one is almost directly above the area where I'm seeing water. I'd bet that the gaskets haven't been replaced since the ports were installed, so I'm inclined to order new ones (and new screens since many of the current ones are torn). To that end, I need help identifying the ports. I know they are Beckson, and are the Rain Drain style (see Opening Ports by Beckson). But I can't tell whether these are the 410, 414, or 512's. Can anyone help positively ID them? I'd like to order the gaskets and screens so I have them for my next trip to the boat.
Thanks in advance for any help!
- Jim
Home: Western Philly 'burbs
1980 Allmand 31
1975 Albacore 15
jimgo is offline
post #2 of 3 Old 06-10-2013
no longer reading SailNet
Alex W's Avatar
Re: Opening Port/Window Identification help?
Those are Beckson Ports as you thought. Parts are easily available for them. Beckson's website has everything that you need to measure them.
If I had to guess I'd say they are 5x12.
The nice thing is that gaskets are cheap.
Alex W is offline
post #3 of 3 Old 06-10-2013
Jim,
I had a similar situation and I started from the bottom up..Genoa tracks, chainplates, window gaskets... The leak persisted and ended up coming from the handrails. Lesson learned for me, best to start from the top down and eliminate sources. Just a thought.
tempest is offline
Opening port seal replacement Ajax_MD Gear & Maintenance 3 09-26-2012 12:49 PM
MD7A Exhaust Manifold Port identification sweeneyman Diesel 7 06-07-2012 09:11 PM
leaking Lewmar opening port sails7plj Announcements and Suggestions Box 0 03-07-2010 11:13 AM
Opening port Replacement AES1691 Morgan 1 07-16-2008 11:56 AM
Lewmar opening port leak ref_123 Gear & Maintenance 4 09-29-2003 09:36 AM
