My new little tub needs a motor (so says my wife) and for the inland lakes around here I thought a 40-50lb thrust MinnKota would problaby push my boat around if there is no wind (disp 1800 pounds), probably creep along but I really dont plan on using it much. 45w solar to keep the battery charged is what I am thinking.
I would just stick a 4-10hp on the existing mount, but I would really rather not fiddle with the gas unless we end up heading out to monterey bay or something.
it works okay, as long as you understand the limitations. You should have/will need 2 batteries, one in use and one on charge, and don't expect to get the range or speed the manual says you will get. You're pushing almost a ton of displacement hull, which is different from pushing a lightweight dinghy or planing hull.
Add up the cost of a 50 lb thrust trolling motor, solar panel, solar panel mounting system,two batteries, wiring, charge controller etc., and you are damn close to, if not more than, the cost of a 2.5 hp Lehr outboard...
which strikes me as being a much, much better auxiliary solution, with easier-to-stow fuel that still works reliably no matter how overcast, and no gas or oil onboard- it's the same fuel you use for your bbq grille, and can be stored in a pvc pipe propane locker clamped to the stern rail.
If the stars align properly I'll be testing one soon, but all indicators are that this is a great little outboard.
That LEHR looks really cool. The benefit of solar is my wife can pull a little juice from the batt for accessories so the panels could be multi functional. On these lakes I really would be fine without a motor, but she is worried about getting becalmed.
You can get reliable used outboards for a lot less cash outlay.
My 44 lb thrust moved my friends 4500 pound boat at 2.3 kts in flat water - for 30 minutes on a 80ah battery. I charged the battery via a shore connection.
I was gonna suggest the Lehr that BLJ did, pretty cook little engines and they burn clean. I don't know anything about them except that meet a lot of your requirements I would think. The other option are the pricey Torquedos electric motors. Very nice motors but you pay for it
As Chuckles mentions you can find some good used on craigslist & pennysavers but you have to the gas issue you mentioned
I have a 32 lb. Mini Kota on the back of a 14 ft. aluminum jon boat and last week I used it when the gas engine wouldn't start. I was pushing straight into perhaps 10-12 mph wind and waves. I was really surprised at how little speed I made. In my opinion, you would be better served with a gas engine in the 6 hp range (as aggravating and messy as they are). Assuming that you will always be using it when there is no wind might not be a good assumption. The 2.5 hp propane engine would be a better bet than the trolling motor, but I'm not sure that it will be enough if you really, really need to make headway directly into any significant wind or waves, even on a lake (thunderstorms and associated wind for example). Just my opinion.
When I was sailing on Rutland Water, which is Europe's largest man made freshwater reservoir, combustion engines were not allowed. I installed a Yamaha M26 (55 lb thrust) which is made by Minn Kota. Loved it. Pushed my 26 footer with ease around with plenty of juice left in my leisure battery. I also had two batteries, one for the outboard and one that was being charged on land for the next day. As long as you don't have to deal with tides and streams electric outboards are fine. Actually, I had to relearn when I switched later to a petrol outboard. They are just not as responsive as an electric, I find. If you are looking for a Minn, see if you can get them branded as Yamaha. When I bought mine, it was quite a lot cheaper then the same sold as Minn Kota (but had only a two year and not three year warranty).
That is not the particular one. He is sending photos tonight so I can decide. Runs ok, needs a tune up. I am hoping he is an old farmer/fisherman that really maintains his gear. I will have a better idea later today.
If things get bad, can you wave to a passing boat and bum a spare battery? I can run for 12 hours straight on my 8HP kicker with the gas I carry. That's good insurance. I do, however, carry a trolling motor for my dinghy. I think it's the bomb for that.
I have a minn kota 55lb thrust for a 9 n a half foot punt. Works pretty good, even in some wind. I use a small tractor battery, and it will get me to and fro the boat about 3 to 4 times on a single charge. I dislike toting the battery around however, and still prefer the tried and true oars... But my oarlock is broken at moment.
That LEHR motor looks nifty, if I had the bread id spring for one of those.
Two things about those old eskas-
1. because they are air-cooled, they are loud.
2. Some of the smaller HP models had no reverse, and no clutch. Make sure you are pointed in the direction in which you wish to travel when you light it up, because that is the direction you are travelling when lit.
My Catalina had an old Ted Williams 7.5 that seemed to have a mind of its own, would run fine one day, hit and miss the next, not at allnthe time after that. Rather than sailing every third day, who says sailors aren't problem solvers, I traded my neighbor an old 4.5 Johnson for a 75 lb thrust Minn Kota, fashioned a bracket to fit the motor mount, bought a new battery, solar charger and never had a problem with power. I sold the Catalina with the Ted Williams but kept the Minn Kota as a back up on the new boat.
On my Venture 17 I have two deep cycle marine batteries and a 55# thrust Minn Kota. The boat with all the stuff in it weighs around 1,200 pounds. The electric motor will push the boat around 3.5 to 4 mph for almost 4 hours on a full charge. A nice thing about electrics is the strong torque and immediate "on" nature of them. Just throw a switch or turn a knob and you're on. I really like that there is no noise, or smoke, or rattle, or exhaust. Just the gurgle of the water behind the boat.
I made a video of the set up on my YouTube channel but since I'm a newbie here I can't post links.
The YouTube channel is: drez20001 The trolling motor set up is one of the newer videos.
JT/Dan
Related Threads
1.7M posts
173.8K members
Since 1990
