Sticking morse cable - SailNet Community
 3Likes
post #1 of 13 Old 06-11-2013 Thread Starter
Once known as Hartley18
Classic30's Avatar
Dock
Gearshift cable is getting harder to move by the day.. it's not all that old (~5 years I guess) and is otherwise in good nick.
What do you guys recommend to keep it from seizing up entirely??
Classic30 is offline
post #2 of 13 Old 06-11-2013
Re: Sticking morse cable
motorcycle cable lube.
desert rat is offline
post #3 of 13 Old 06-12-2013
Senior Slacker
SlowButSteady's Avatar
Or graphite?
Never forget them. Do something to prevent it from happening again.
Charlotte Bacon, Daniel Barden, Rachel Davino, Olivia Josephine Gay, Ana M. Marquez-Greene, Dylan Hockley, Dawn Hochsprung, Madeleine F. Hsu, Catherine V. Hubbard, Chase Kowalski, Jesse Lewis, James Mattioli , Grace McDonnell, Anne Marie Murphy, Emilie Parker, Jack Pinto, Noah Pozner, Caroline Previdi, Jessica Rekos, Avielle Richman, Lauren Rousseau, Mary Sherlach, Victoria Soto, Benjamin Wheeler, Allison N. Wyatt
SlowButSteady is offline
post #4 of 13 Old 06-12-2013
Like desert rat said:Go to a motorcycle store and get a cable lube kit. I have done it and it really does work. Another, and probably better solution: buy a new cable, no matter how old the existing one is.
jgeissinger is offline
post #5 of 13 Old 06-12-2013
HANUMAN
RobGallagher's Avatar
I'm sure the lube will get you through the short term. What you need to worry about is failure. That could be catastrophic for both life and property.
Motorcycles have an off button and brakes that work independently of their engine. I'm gonna go out on a limb here and guess that your boat does not have that feature.
Backing out of a marina 200 miles from home on a windy day is no time to get stuck in reverse (due to a broken cable) with the only option being to unintentionally ground yourself attempting to reach something to tie up to. Don't ask me how I know. One thing I was sure of is that the cable was just stiff, I lubed it and planned to replace it when I got home.
HANUMAN
'88 C&C 30 MKII
NOANK, CT
RobGallagher is offline
post #6 of 13 Old 06-12-2013
Check to see where it's pinched.
Hudsonian is offline
post #7 of 13 Old 06-12-2013
Group9's Avatar
It probably just needs lubrication. Shot up into the cable. Something like WD-40, but with a cool marine name.
On the northern Gulf of Mexico.
"Best thing to do is get her out on the ocean. If anything's gonna happen, it's gonna happen out there." Captain Ron Rico
Group9 is offline
post #8 of 13 Old 06-12-2013
Have a go and DIY .....
Buy a new one and replace it.
Just in case a single strand has parted and is restricting the cables inner movement.
If after replacing it you get the time to inspect the old cable's inside cable and it seems ok then just grease it up and set it aside as a spare...
SVTatia likes this.
macwester26 is offline
post #9 of 13 Old 06-12-2013
another option would be to put cable in bucket, tie it in circle, and fill the bucket with marvel mystery oil to cover it completely and let it soak for 24 hours and see it looses ups. I hope this help, otherwise you might have to replace the albe.
ironhors42 is offline
post #10 of 13 Old 06-12-2013
poopdeckpappy's Avatar
Replace it, they're inexpensive enough in comparison to what will happen and when it will happen
RobGallagher and Leither like this.
1955 Blanchard 51 Custom ( I got a woody )
1974 Ranger 33
Friends don't let friends do stupid things alone
poopdeckpappy is offline
M1 Morse control jamesjle Diesel 3 03-30-2013 12:38 AM
Windless cable size, cable manufacture and battery type? SanDiegoChip Gear & Maintenance 25 02-19-2010 10:44 AM
Pearson Throttle Cable Sticking RocktheBoat Diesel 6 11-04-2009 10:13 AM
flipping a Morse controller richrand Gear & Maintenance 9 05-26-2008 04:58 PM
replacing morse cables? admiraltyr General Discussion (sailing related) 1 07-16-2001 04:52 AM
