Kicker motor mount problem - SailNet Community
post #1 of 3 Old 06-12-2013 Thread Starter
budvar's Avatar
Thanks all for your continued assistance. Almost finished with the raised chainplates. Will post the pictures. They look great.
I have a 9.9 Mercury attached to Chinook (US Yacht 25), via motor mount, not the transom. You raise and lower the motor by way of a stainless steel lever on the left side of the mount. The lever is cracked, needs a good bead of weld, which I think I can do.
The boat is in a slip. I'd like to support the motor with straps in the raised position, and remove this lever. Looks like it will come off by loosening a nut.
I did look online for a comparable model, found something similar, but not exact. They recommend leaving the job to experts, that you need a jig and other equipment due to springs involved.
Anyone have a similar problem? Thanks for any help.
Chris
US Yacht 25
Tri-Cities area, Wa.
budvar is offline
post #2 of 3 Old 06-12-2013
Re: Kicker motor mount problem
Chris
US Yacht 25
I have done some welding, mostly on mild steel. I believe stainless can be somewhat tricky, special rod, heat control, and so on. Can't quite picture your set up but if the lever carries much of a load, maybe having a pro do it would be safer. If something is "spring loaded" be careful when taking it apart
Paul T
dabnis is offline
post #3 of 3 Old 06-12-2013
Brewgyver's Avatar
There are quite a few different designs. A picture of the mount would help.
s/v My Sweet Girl!
Catalina 30 (Mark I)
Atomic 4
Brewgyver is offline
Escape- how to add a motor mount? Bando Gear & Maintenance 10 11-27-2012 12:00 PM
Kicker Mount on Ladder GMC Gear & Maintenance 10 04-13-2012 06:07 PM
4 stroke motor mount cal30 Gear & Maintenance 4 03-03-2009 01:46 PM
motor mount help hubbardsw Gear & Maintenance 1 11-12-2007 08:07 AM
Motor mount replacement? bread316 Gear & Maintenance 4 11-07-2006 12:17 AM
