Yanmar 3gm30f secondary filter - SailNet Community
 1Likes
  • 1 Post By sailak
post #1 of 10 Old 06-13-2013 Thread Starter
I want to replace the secondary fuel filter on our yanmar 3gm30f.
I am stuck on how to unscrew the box. Are there any good tips and tricks or do I really need to take of the hoses to be able to use a wrench
carlager is offline
post #2 of 10 Old 06-13-2013
JimsCAL's Avatar
Re: Yanmar 3gm30f secondary filter
The ring with the steps on it is threaded. Just turn with a wrench or large pair of pliers and the bowl will come off. Make sure you have an O-ring as well as a new filter element to put in.
JimsCAL is offline
post #3 of 10 Old 06-13-2013 Thread Starter
Problem is there is no space for a wrench. Should I start by loosening the screw on the top ?
carlager is offline
post #4 of 10 Old 06-13-2013
I use large jaw channel lock pliers and am able to loosen the flange nut without removing the hoses. You will need to bleed the air out by adding fuel to the filter sump and pumping fuel in with the air bleed screw on top open. Careful to not strip and overtighten the bleed screw. Priming the air out is slow using the hand pump lever on the fuel pump is slow so I added a hand squeeze bulb in the fuel line, which makes it quick and easy.
1973Ericson35 is offline
post #5 of 10 Old 06-13-2013
Can also put a flat screw driver against a nub on the screw thread and tap lightly.
Ed Reiss
Being There
Freedom F38 #154
out of Marion, MA
ereiss is offline
post #6 of 10 Old 06-13-2013
cheoah's Avatar
Channel locks, or use some grippy rubber and really lay your paws to it....
cheoah is offline
post #7 of 10 Old 06-14-2013 Thread Starter
Do I have to remove the screw before trying to turn the ring
carlager is offline
post #8 of 10 Old 06-14-2013
Crealock 37
sailak's Avatar
Dock
No, you don't have to loosen the screws.
Dale
S/V Elnora
Pacific Seacraft "Crealock" 37 #312
sailak is offline
post #9 of 10 Old 06-14-2013
bigdogandy's Avatar
Dock
I have found that it helps to squirt some PB Blaster on the ring and let it soak in for a few minutes and then use the flat head screw driver / tapping lightly method to loosen the ring.
Andy
Key Largo
S/V Everlasting Moon
1981 Endeavour 32
Be joyful though you have considered all the facts.
- Wendell Berry
bigdogandy is online now
post #10 of 10 Old 06-14-2013
Crealock 37
sailak's Avatar
Dock
Hey, how are you going to bleed with those nice covers over the ends of the hose clamps?!
rikhall likes this.
Dale
S/V Elnora
sailak is offline
Yanmar YSE8 no secondary filter - 2 micron racor in primary? OneidaLakeSailor Diesel 1 06-23-2012 03:22 PM
Replacing secondary filter on Yanmar 1GM10 diesel dgililov Gear & Maintenance 3 02-09-2012 12:54 PM
Yanmar 3GM30F Primary fuel filter thaeni Diesel 3 08-10-2010 01:00 PM
Yanmar 3gm30f - filter bleed screw ereiss Diesel 0 03-21-2010 07:51 PM
Fuel filter replacement on Yanmar 3GM30F gsyversen Gear & Maintenance 7 06-13-2008 03:18 AM
