Lowrance HDS8m route ransfer - SailNet Community
post #1 of 3 Old 06-14-2013 Thread Starter
Sootydan's Avatar
Anyone ever use a Lowrance HDS8m? I'm trying to load routes Ive made in Nvionics webpage to my Lowrance. I've made the routes and downloaded them to an SD card but I can't seem to figure out how to transfer and then find the route on the unit itself. I have Navionics Platinum card for my charts. I'm using a second SD cards to download my routes. No matter here i look it seems i can copy from the Lowrance or make the routes on the Lowrance but cant get the routes from the sd card on my Lowrance unit itself. It shows the two cards as memory card 1 and 2. join nuts here
Sootydan is offline
post #2 of 3 Old 06-15-2013
Sailor
Gladrags1's Avatar
Re: Lowrance HDS8m route ransfer
I have a Raymarine MFD and have had lots of frustration attempting the same. I do my chartwork on Voyage Planner Software from Fugawi / Raymarine. You are able to do the chartwork on-line? I don't know if my problems were similar to yours but mine seem to stem from how the software copies the routes on to the sd card. I need to copy a few at a time on to the card and then the unit sees them and copies them on to the MFD. If I screw it up, the unit simply doesn't see any data on the card. It is NOT user friendly and I miss the ease of my old Garmin unit. That simply worked...
From your description, it seems like the 2 units (your and mine) have some similarities. I have 2 usb ports: 1 for the charts and the second to transfer data (waypoints and routes). My data has to be in the Raymarine format for the unit to read (.fsh) but the software can translate from the universal format (.gpx) to .fsh format and visa versa. Good luck!
Mandolin
Bayfield 36
Sailing out of Rock Creek, Chesapeake Bay
Gladrags1 is offline
post #3 of 3 Old 06-15-2013
tommays's Avatar
I have A GARMIN on which its easy to do everything and a Lowrance 3500C which is a bit of a red headed stepchild when you do things off the unit
Among the many issues is there are so many data formats now even the common N40į55'00.0" VS N40 55.862 makes the units angry
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
Lowrance AIS Confusion.... GrahamO Electronics 6 12-14-2012 08:53 AM
Lowrance XOG Redux SEMIJim Gear & Maintenance 14 06-26-2009 06:14 PM
Lowrance XOG svey Gear & Maintenance 9 08-24-2008 12:01 AM
Lowrance PalmettoSailor Gear & Maintenance 16 07-02-2008 09:47 AM
Lowrance GPS' and Chartplotters SEMIJim Gear & Maintenance 9 06-27-2007 09:38 AM
