Bottom paint on prop - Page 3 - SailNet Community
 8Likes
post #21 of 48 Old 06-17-2013
Courtney the Dancer
jrd22's Avatar
Re: Bottom paint on prop
Paul- I've been using Trilux spray antifouling designed for outboards and sterndrives for several years now and it lasts for 2-3 years with only an occasional barnacle. My brother's boat, kept in the same marina was covered with growth in a year and a half. I initially prime the prop and shaft (tape off any zincs) with zinc chromate spray and then two coats of the Trilux.
Interlux Paint Interlux Trilux Boat Prop & Drive Antifouling Spray Paint
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
jrd22 is offline
post #22 of 48 Old 06-17-2013
I don't discuss my member
Fstbttms's Avatar
So you're saying that nobody had a look at your brother's boat below the waterline for a year and half?
I don't care where your boat lives or what the fouling conditions are- that's playing with fire. You at least want to check your zincs a couple times a year. Not to mention cleaning the running gear, even if the hull doesn't need it. Wow.
Fstbttms is offline
post #23 of 48 Old 06-17-2013
chef2sail's Avatar
We use the Petit Product on the marine rich Chesapeake Bay and it works well for two years
Pettit Zinc Coat Barnacle Barrier
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is offline
post #24 of 48 Old 06-17-2013
Omatako's Avatar
Originally Posted by JimsCAL View Post
Here's what WM charges. I would call that "really expensive"!
Yep, I would call that expensive too.
In New Zealand things are done a bit different. Here the product is not available off the shelf. It is only available through "registered applicators" who do the whole job and do not sell the product. On the face of it that sounds like a bad idea. But it isn't, at least it seems to work, here's why.
The owner cleans the prop as best he can, the better you do it the less it costs. Then the contractor comes along and does a final prep, primes the running gear and then does the Propspeed application and top coat. Where is the advantage? Well, they only use as much product as is required and generally that is far less expensive than buying the product in tins. And the applicator provides a limited liability warranty on durability.
As an example, to do my boat with an 18" 3 blade prop including labour product and consumables the estimate of what it will cost me is about NZ$220 - that's about US$175. For the peace of mind that I believe it will give me I reckon that's not too expensive.
Also from what I have heard the durability of the product is totally dependent on the quality of the application - if it is applied badly you may as well just pour it into a bin somewhere. Which is why in NZ they won't sell the product - they had DIY jobs go bad and it was ruining the products cred so they stopped selling it for DIY use.
We'll see, my boat comes out next week - the proof of the pudding is in the eating.
Arthur C. Clarke
Omatako is offline
post #25 of 48 Old 06-17-2013
Omatako's Avatar
FWIW my experience with Trilux is that it probably did as much good as leaving the prop naked. And that stuff is not that much less expensive that Propspeed - in NZ we pay around $100 a litre.
I've been told by the "experts" that Trilux is intended for aluminium and isn't expected to work on bronze components. Seemingly their ad appears to confirm:
"specially formulated with Biolux to be the safest & most effective product for use on aluminum outdrives & outboards."
YMMV
Arthur C. Clarke
Omatako is offline
post #26 of 48 Old 06-17-2013
Been thinking for some time about what might work on my prop. Toying with having it teflon coated. Good idea or bad??
dfreer is offline
post #27 of 48 Old 06-18-2013
Courtney the Dancer
jrd22's Avatar
Yep, it normally spends six months of the year in fresh water but he left it in the salt that year and it didn't get used much. The Autoprop was a big ball, I couldn't see the blades when I dove it. We don't have a lot of hard growth problems here in the cold water but that was pushing it for sure.
John
SV Laurie Anne
jrd22 is offline
post #28 of 48 Old 06-18-2013
Courtney the Dancer
jrd22's Avatar
YMMV
It is designed for aluminum props and drives, I've used it on the sterndrive of the power boat for years, decided to give it a try on the stainless shaft and bronze prop on the sailboat and it works like a champ. I've used it for a total of about 4 years now (I re- apply every two years when I do the bottom paint) and the prop and shaft stay almost totally clean (we don't get a lot of growth here, only need to clean the hull once a year) Are you sure you are talking about the same stuff Om? This is a spray can, not a litre can that you brush on.
John
SV Laurie Anne
jrd22 is offline
post #29 of 48 Old 06-18-2013
blt2ski's Avatar
Trilux can be found in a brush on, or a spray can. I use the spray can, IIRC maybe $20 and barely use but 1/2 to maybe 3/4 of a can. Its pretty well worn off after 2 seasons, but seems to keep the barnacles off in that time frame.
Marty
She drives me boat,
I drives me dinghy!
blt2ski is offline
post #30 of 48 Old 06-19-2013
Omatako's Avatar
No the stuff I used is brush-on but the spec appears to be the same. The can even looks the same but obviously not aerosol.
Your description in your reply to Fstbttms is exactly what I found under my boat after about 8 months of Trilux - "The Autoprop was a big ball, I couldn't see the blades when I dove it."
I can't recall seeing Trilux in the chandlers here in aerosol - whatever the case I'm going the Propspeed route this time round and will see how it goes.
Thanks
Arthur C. Clarke
Omatako is offline
Don Casey: Paint Waterline Stripe with Bottom Paint asdf38 Gear & Maintenance 23 03-05-2016 07:50 PM
Paint thinner for soft ablative bottom paint jameswilson29 Gear & Maintenance 7 11-26-2012 01:56 PM
Bottom paint prep, chipped paint josrulz Gear & Maintenance 16 02-14-2010 09:24 PM
proposing to paint prop tappers Gear & Maintenance 16 04-06-2008 12:40 PM
Paint Prop & Shaft nauticalrich Gear & Maintenance 3 04-04-2003 05:13 PM
