Rudder seal coming loose - SailNet Community
 1Likes
  • 1 Post By Faster
post #1 of 8 Old 06-16-2013 Thread Starter
postwarcomet27's Avatar
Hey guys, just bought a '75 Catalina 27. Has tiller steering, everything moves free and feels solid, but I noticed a loose seal on top of the rudder? Is this anything I need to be worried about before it goes in the water. It's under the waterline, so just checking to make sure water doesn't come through. If it needs to be replaced, whats the easiest way to go about doing it?
Thanks
postwarcomet27 is offline
post #2 of 8 Old 06-16-2013
Re: Rudder seal coming loose
There should be a rudder post tube that goes above the waterline.. leakage should not be a major issue.
Catalina Direct is a continuing supply for many Catalina parts.. one of the big pluses for owning one.
Catalina Direct: Catalina 27
Jgbrown likes this.
Faster is offline
post #3 of 8 Old 06-16-2013
JimsCAL's Avatar
Not clear what you are talking about. Since you say its under the water, do you mean where the rudder post exits the rudder? If so, that needs to be taken care of to avoid water getting into the rudder (if it already hasn't).
JimsCAL is offline
post #4 of 8 Old 06-16-2013 Thread Starter
It's a little post seal that is laying in top of the rudder. It looks like it came loose from the hull, where it should sit. The seal doesn't look dry rotted or anything, just came loose. What could I use to adhere the seal back in place? Any ideas? Ill see if I can post pics.
Thanks
post #5 of 8 Old 06-16-2013
JimsCAL's Avatar
That's probably just a spacer, not a seal. No need to do anything if that's the situation.
JimsCAL is offline
post #6 of 8 Old 06-16-2013
rbyham's Avatar
A pic might help but it does sound like something on the top end of the rudder where water penerratoon becomes much less of an issue.
rbyham is offline
post #7 of 8 Old 06-16-2013
Dog Ship's Avatar
It sounds like it might be a piece of the bushing in the rudder tube that may have broken off. A picture would be very helpful.
We have three rules;
No screaming.
No bleeding on the sails.
No slobbering on the charts.
Dog Ship is offline
post #8 of 8 Old 06-16-2013
4KSB driver.
SHNOOL's Avatar
I just replaced these on my CP-25.. this makes a huge difference to stiffen up the rudder... no wobble.
Catalina Direct: Rudder Washer C-27, CP-25, CP-26
1983 WD Schock Wavelength 24. Production boat limit tester, blue-water bucket owner, with wine taste on a beer budget.
SHNOOL is offline
Pearson 31-2 Rudder's Loose pccogsdill Gear & Maintenance 3 03-07-2010 08:22 PM
Loose Headstay trpopman Gear & Maintenance 2 08-28-2005 04:49 PM
Packing gland coming out of top of rudder tube! duffer1960 Gear & Maintenance 2 08-25-2005 08:26 PM
leaking and loose rudder tube ndsailor Gear & Maintenance 0 08-30-2002 05:06 AM
Loose screws bmcald Gear & Maintenance 13 05-29-2002 11:57 AM
