Bad news, composite propane tank recall - Page 3 - SailNet Community
 1Likes
post #21 of 27 Old 06-19-2013
Re: Bad news, composite propane tank recall
Originally Posted by DRFerron View Post
Thanks. The standard backyard grill size tank won't fit in my propane locker. By the time I remove and redesign the locker I'm back up to the price for a tank that will fit without doing all that work.
That's why I referenced the 20lb tank, which can be purchased for $25-$30. The math doesn't work on odd sizes.
To other posters replies...... Sure the steel tanks rust. Not horrifically, but I toss them every 5-10 yrs and buy new. I never repaint them. Therefore, the three standard tanks I can buy for the price of one composite have a combined life span that seems a lot longer than a single composite.
Someone mentioned that their propane locker gets wet. That would be a deal killer, I'm sure.
Jeanneau 54DS
Minnewaska is offline
post #22 of 27 Old 06-20-2013
rbrasi's Avatar
Originally Posted by mitiempo View Post
Biggest problem (except for dollars) is finding tanks that fit the locker.
Welcome to my world. Not because of recall- because There are not tanks in existence that will fit my current locker. I'm putting off building a new one because I know it will look like sh*$ when I'm done.
1968 Cal 2-30
Sandpiper 2
MDR
rbrasi is offline
post #23 of 27 Old 06-20-2013 Thread Starter
Puget Sound Pounder
kellysails's Avatar
In the PNW, everything gets wet, or maybe at best in a permanent state of dampness. I would think steel would be completely out here, although if painted a bit once a year it might be fine. The cost differential is huge. Worth a thought.
kellysails is offline
post #24 of 27 Old 06-20-2013
tommays's Avatar
I leave tanks out on the backyard deck in year round weather without much issue I would think saltwater a bit worse but could be controlled
I would think the weight and correct size are the big reasons as well as the visible fuel level
mitiempo likes this.
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #25 of 27 Old 07-28-2013
The Trident 10 lb. tank will not fit the Trident 10 lb. locker. Huh?
hooligan6a is offline
post #26 of 27 Old 08-04-2013
djodenda's Avatar
Well.. I finally got around to checking, ( I was reminded in this month's Practical Sailor)
and.....
I have the bad ones...
They are coming off the boat ASAP..
Fortunately, I still have the old steel ones until I get a replacement.
Thanks for letting me know
David
1987 CS 36 Merlin "Kyrie"
djodenda is offline
post #27 of 27 Old 08-04-2013
MarkofSeaLife's Avatar
Dock
I wish I was where you guys are throwing those cylinders away.
I only want two.
Pity about it is I was in the USA 12 months ago. If the recall had happened then I could have stocked up.
Oh well.
Sea Life
Notes on a Circumnavigation:
MarkofSeaLife is offline
propane tank brokesailor Gear & Maintenance 18 04-15-2013 10:20 AM
propane tank gregreinhard Gear & Maintenance 5 03-04-2013 01:09 PM
Composite propane tanks rmeador Gear & Maintenance 11 02-24-2013 01:55 PM
Composite LP Tank - Can you get them filled? KindOfBlue Gear & Maintenance 4 06-16-2009 11:09 AM
