Bridles: splicings, siezings and other options - SailNet Community
post #1 of 2 Old 06-18-2013 Thread Starter
pdqaltair's Avatar
I'm reviewing some manufactured anchor bridles, with a focus on catamarans, but certainly they are applicable to all boats and towing. Specifically, I'm intested in araingments that terminate in a hook or shackle at the apex, not a rolling hitch or something similar, chain plates (like hooks but with 2 eyes), since they use 2 separate legs and do not require and eye splice, and likewise not the possiblity of using 2 legs joined with a shackle. All of these are legitamate alternatives, but not what I'm curious about.
3-strand.
Typically an eye with thimble is used, with a y-splice attaching the 2nd leg, all covered with serving or webbing chafe gear. While I sure this is near line strength when the angle between the legs is shallow, what happens as the angle grows? At anchor the angle would certainly be less than 60 degrees; however, when tying to a mooring the angle could be as much as 120 degrees, to prevent the ball from striking the hulls.
Double braid.
The same sequence of splices is possible. I have seen them seized, either with heavy tread/cord or metal ferrels. Same question; what happens to strength at 60 degrees and 120 degrees?
Knots are also possible. A figure-8 is about 80% straight pull and about 65% 180 degree pull. Though a thimble is not practical, other chafe gear is.
2 legs joined with a shackle is very prone to failure as the angle becomes too wide' I'm sure many of us have destroyed a shackle when it shifted such that the load cam on cross-wise and the threads stripped. 2 legs to a plate is tough on the plate but can be designed for, like this one:
http://sail-delmarva.blogspot.com/20...catmarans.html
So, what is the best y-splice option?
I've looked for test data on-line and not found this specific item; a Y-splice or seizing tested to destruction at angle. I suspect the failure point at smaller angles will be near the eye and not in the legs, but as the angle grows that cannot remain true.
While I'm sure the vast majority fail due to chafe and all of this is academic, I need to be diligent in my investigation.
(when asked how he reached the starting holds on a difficult rock climbing problem that clearly favored taller climbers - he was perhaps 5'5")
"Well, I just climb up to them."
by Joe Brown, English rock climber
Writing full-time since 2014
pdqaltair is offline
post #2 of 2 Old 06-18-2013
Re: Bridles: splicings, siezings and other options
I've used the alpine butterfly loop for making a loop in the middle of my long bridle line for securing the anchor rode. An intermediate line is needed to then attach the alpine loop to the rode.
lancelot9898 is offline
Mantus Bridles Are Finally Here!!! Mantus Anchors Gear & Maintenance 1 05-29-2013 10:55 AM
rope bridles vs rope travelers allergic1 Gear & Maintenance 1 05-25-2011 04:18 PM
sabre 38 and options bradphoto Boat Review and Purchase Forum 6 02-17-2011 07:51 AM
dinghy options davidpm General Discussion (sailing related) 12 07-01-2009 09:39 AM
What are my options? AbelCasillas1 Boat Review and Purchase Forum 0 08-10-2004 12:27 PM
