New deck stepped mast for Trintella 42 /USA - SailNet Community
post #1 of 14 Old 06-18-2013 Thread Starter
The new mast is ready to be shipped but I am delaying delivery(and final payment) as I am not happy with the rigger telling me that I need to move the mast 6" further forward to align the shrouds with the center of the mast (twin spreaders)Not only was the old mast in the same position for 20 odd years,it would place the mast support right up against the forward bulkhead and the plate on the top through the bulhead into the forward cabin?? Then I was advised to have swept back spreaders and finally everything is OK as is. There are 3 chainplates on both sides in the original position, now I am hesitant and would worry on passage that the stick might fall down,heaven forbid!
Any comments would be appreciated
Yawlcat
yawlcat is offline
post #2 of 14 Old 06-19-2013
mitiempo's Avatar
Re: New deck stepped mast for Trintella 42 /USA
We need more information. Why a new mast? Why farther forward if it is just a replacement or is it a rig re-design, by a qualified designer I hope?
Brian
mitiempo is offline
post #3 of 14 Old 06-19-2013
Kind of difficult to believe that E. G. van de Stadt made an error in the rig design; after all these years I wonder who would be qualified to say that he was wrong. (?)
BTW, Nice looking yacht!
olson34 is offline
post #4 of 14 Old 06-19-2013 Thread Starter
Thumbs up Re: New deck stepped mast for Trintella 42 /USA
Bought the boat without a mast which the previous owner trashed.The rigger insisted that the cap shroud should be in line with one of the chainplates of which there are 3 either side hence he insited I move the chain plate or move the mast! Neither of which seems a good option. I apparently could have running backstays but thats something I do not want as I will be sailing solo.
This is a new Selden mast and although I got assurances from Selden that everything is OK, because of the previously raised issues wanted to get opinions from the great sailing fraternity. I would hate it falling overboard in the middle of the Atlantic!!
yawlcat
yawlcat is offline
post #5 of 14 Old 06-19-2013 Thread Starter
No, the mast lived for 20 odd years in the boat so was obviously correct, please see previous explanation as to my concerns.
Nice but very costly !!
yawlcat
yawlcat is offline
post #6 of 14 Old 06-19-2013
overbored's Avatar
the cap shrouds or uppers should line up with the center of the mast more or less. on more modern rigs the caps are set way back and they use swept back spreader. the position of the chain plates and mast base on your boat will be almost inline and uses straight spreaders. the straightness or sweep of the spreaders does depend on the rake of the mast. you will have a back stay on that rig. seems like you might want to consult another rigger if does not understand how your boat was rigged.
"GOLD RUSH" PRINDLE 16
overbored is online now
The Following User Says Thank You to overbored For This Useful Post:
yawlcat (06-20-2013)
post #7 of 14 Old 06-19-2013
overbored's Avatar
check out this video as he turns around 360 degrees and you can see the spreaders and the alignment of the shrouds
that is good looking boat
post #8 of 14 Old 06-19-2013
One of None
deniseO30's Avatar
Seems to me, moving foward would actually give you more tension from shrouds and less on the back stay but what do I know. How did this "order" get this far before you found out the rigger wants to move it fwd?
My last project!
deniseO30 is offline
post #9 of 14 Old 06-19-2013
4KSB driver.
SHNOOL's Avatar
...PAGING BOB PERRY...
Wow, very sleek boat.
1983 WD Schock Wavelength 24. Production boat limit tester, blue-water bucket owner, with wine taste on a beer budget.
SHNOOL is offline
post #10 of 14 Old 06-19-2013
"To any white lobby phone"
olson34 is offline
Deck-stepped vs. keel-stepped mast psemme Seamanship & Navigation 7 11-16-2010 09:23 AM
What is a Deck-stepped mast and keel-stepped mast djr3203 General Discussion (sailing related) 11 12-25-2009 08:24 PM
Deck Stepped Mast mman30 General Discussion (sailing related) 6 09-14-2008 06:55 PM
Deck Stepped Mast or Keel Steeped Mast??? tbeargladd General Discussion (sailing related) 36 11-14-2007 08:07 AM
Deck Stepped Mast thinredmohican Gear & Maintenance 1 11-05-2002 03:46 PM
