Anchor weight for 1650 Ib boat... - Page 2 - SailNet Community
 1Likes
post #11 of 16 Old 06-20-2013 Thread Starter
G20
G20's Avatar
Re: Anchor weight for 1650 Ib boat...
I have a 7 pound-ish danforth now that I plan to keep as a backup/stern anchor. It fits OK in one of my rear lockers but as noted above, they can (and I think so) be a pain to store, move to the bow etc.
My sister made me a beautiful bow pulpit/anchor roller out of solid teak, installation the current project. I tend to put the pull of the anchor on the bow eye vs the platform so the wood platform will only be used to store and launch the anchor.
I originally designed the pulpit to hold a bruce/claw style so I that's why I was most interested in them. I think I am kinda committed at this point. ; )
I also trailer my boat to areas with sandy bottoms, rock, grass etc so I want a good general purpose anchor. Potomac and lower Chesapeake is just primary area.
-Chris
G20 is offline
post #12 of 16 Old 06-20-2013
Chastened
Ajax_MD's Avatar
500lb. minimum.
G20 likes this.
Alacrity, 1981 Tartan 33 #168
Ajax_MD is offline
post #13 of 16 Old 06-21-2013
blt2ski's Avatar
An 11 lb claw, 9 lb fast set with 20-30' of 1/4" chain would probably hold your boat just fine thru 40-50 mph winds generally speaking. Altho since you are in mud, one size larger might be better so you have more surface to hold you. As in mud, that is usually the key over weight. Hence why some like the fortress over a steel danforth.
I do not like danforths, I seem to have a hard time setting them. Once I do, the do ok until a tide or wind shift sends me a 180. Then over half the time the anchor does not reset. Hence why I personally prefer something like a claw, spade or equal style newer design setup, they more than likely will reset.
I have used a 9lb fstset in up to 15knot winds with 6' of 3/8bbb chain on my 30OA 6500 lbs sailboat, it sets and does fine. My 7.5KG/16.5lb genuine Bruce has held me just fine in winds to the mid 20's. I have about 20' of 1/4" chain on that setup. Rope is 5/8 vs 7/16 for the fastset. Both serve a purpose, ie lighter is min needed per race rules to throw out, heavier is the prefered if anchoring out, sleeping etc. It is below, other is on the bow.
Marty
She drives me boat,
I drives me dinghy!
blt2ski is offline
post #14 of 16 Old 06-21-2013
pdqaltair's Avatar
As a longtime Chesapeake sailor that cruised thousands of miles in a 1400-pound catamaran....
* Don't get the Bruce. Unless dramatically oversize it will just drag in many coves with deep mud.
* Do get a 10 pound Danforth. Should hold through anything.
* Deltas are good, better than the Bruce in mud, but must be considerably heavier than the Danforth. About 16 pounds for you.
Manson is very good, but perhaps too pricy for your budget. Best choise, perhaps.
* Do get a second smaller Danforth-type. Always good to have 2. This will only need ~ 6 feet of chain.
Sail Delmarva: The Stiletto 27 - You Can Actually Sleep in That?
Writing full-time since 2014
"Keeping a Cruising Boat for Peanuts"
"Faster Cruising for the Coastal Sailor"
"Singlehanded Sailing for the Coastal Sailor"
pdqaltair is offline
post #15 of 16 Old 06-21-2013
Lightbulb Re: Anchor weight for 1650 Ib boat...
Given your stated anchoring parameters, I would suggest the venerable Danforth 8-S.
I used one for the only anchor on our prior boat, a 4000# 26 footer, for ten years of summer cruising. We anchor in a sand/mud combo. It Never failed us.
Equally important is the chain. For a general "rule of thumb" go with a chain length equal to your boat length.
With a nylon three-strand rode, you should be OK. Since our '81 model boat did not have an anchor locker, the whole anchor setup lived in a sturdy mesh bag that we kept in a cockpit locker and carried forward for anchoring - not fun, but it worked for us.
There are probably quite a few "correct" answers to your inquiry... pick the one that meets the graphical intersection of confidence and acceptable inconvenience.
FWIW, on our prior boat, a 1550# Ranger 20, we used a similar size anchor setup, but did not anchor out often enough to really "test" it.
Our current boat is a 11K# 34 footer that uses a Danforth 13H. Same area and bottom compostion. Never dragged in over 15 summers. We have had to occasionally power it out (!) the morning we departed, though, from under an est. two feet of bury!
olson34 is offline
post #16 of 16 Old 06-21-2013
Just use 100 ft of garden hose. It's guaranteed to catch on anything and everything and is almost impossible to break loose
Enhydras is offline
Advise on Weight & Type of Anchor for Islander 37 HighFly_27 General Discussion (sailing related) 29 10-28-2012 07:15 AM
Anchor Size/Weight? parttimesailor Gear & Maintenance 80 06-29-2010 11:24 AM
Anchor and chain weight Danjcon Gear & Maintenance 16 12-16-2008 01:59 AM
ratio of keel weight to total weight mightyhorton General Discussion (sailing related) 7 07-11-2007 03:37 PM
boat weight? sailorman_10 General Discussion (sailing related) 1 07-30-2002 02:49 PM
