Pumps do not do what you think - Page 3 - SailNet Community
 4Likes
post #21 of 22 Old 06-22-2013
Senior Slacker
SlowButSteady's Avatar
Re: Pumps do not do what you think
A couple of observations:
1) As MarineSail indicated most centrifugal pumps don't deal with back pressure very well. So the length and nature exit pipe makes a big difference with such set-ups. Smooth hose, as large a diameter hose as practicable, large radius bends, NO valves, and as short as possible is the way to go. Also, if the exit is on the transom, and well above the waterline, you shouldn't need an siphon break (it's just another tight radius turn anyway). A one-inch corrugated hose with lots of twists and turns, and a check valve, and maybe a couple of elbows here and there, is going to pose a serious challenge for any small centrifugal pump relative to a smooth, large diameter hose without unnecessary fittings.
2) Your video is something of a "worse-case" test as far as the pump is concerned. As the bilge fills the pump has less "head" against which it has to work. In other words, the last five gallons should take the longest. If the bilge is filled to the sole it doesn't matter if the hole is at the bottom of the bilge (as far as the rate of water ingress is concerned) -- the water will come into the boat as if the hole were right at the surface of the rising water. The difference can be as much as a meter, or more, on some boats (it's close to a meter on my little 27-foot boat); AND the pump won't have as much head pressure to work against.
You are right to point out that the "rated capacity" of a bilge pump is rather deceiving. It's as if car manufactures advertised the milage that their cars get just cruising on the freeway at 45 mph, without factoring in real freeway speeds, or the gas it takes to accelerate to speed, or hills, et cetera. However, you can improve the capacity of a bilge pump, sometimes pretty dramatically, with a little large diameter hose and some common sense. Also, realize that while your pump(s) might not be able to completely keep up with a hole, or busted thru-hull, or whatever, they could well buy you enough time to get a handle on the problem, or get to shore, or for the CG to get to you.
Never forget them. Do something to prevent it from happening again.
Charlotte Bacon, Daniel Barden, Rachel Davino, Olivia Josephine Gay, Ana M. Marquez-Greene, Dylan Hockley, Dawn Hochsprung, Madeleine F. Hsu, Catherine V. Hubbard, Chase Kowalski, Jesse Lewis, James Mattioli , Grace McDonnell, Anne Marie Murphy, Emilie Parker, Jack Pinto, Noah Pozner, Caroline Previdi, Jessica Rekos, Avielle Richman, Lauren Rousseau, Mary Sherlach, Victoria Soto, Benjamin Wheeler, Allison N. Wyatt
SlowButSteady is offline
post #22 of 22 Old 06-23-2013
my boat, 40' 9tons relatively shallow bilge, has a pisser (800gph rule) for the minor drips and drabs and occasional wash down of the cabin sole. set about 6" above that is a 2400gph electronic (with a siren alarm thatll wake the dead) mostly in case the pisser fails and a deck hatch is left open during monsoon season. then theres the beast - 8000gph rule - i picked up at a marine swapmeet brand new for $75. its not on auto, you have to throw that switch intentionally. ive got a huge manual whale i can work vertically from the cockpit and a y-valve on the head pump so it can be pressed into service if need be. they all discharge to the COCKPIT and not a throughhull , where ive got more than enough drainage out the transom above the waterline. if your cockpit drains arent up to that kind of flow then thats where you put a scared crew with a bucket. and youve got a visual warning that your pumping when you are at the helm.
next, im essentially double-hulled from the bow to midships about 6" above the waterline as all the v-bearth, settee, and stowage lockers have secure latches and gasketed lids. this isnt as hard to do as one might think, and itll at least dramatically slow or even stop and compartmentalize flooding from a collision until a repair or patch can be well thought out.
lastly, carry several sizes and shapes of 1/2" ply pre-drilled around the perimeters and some truss head self drilling sheet metal screws, and a cordless drill. think it through and when youve calmed down some splooch on some sealant and just drive the screws into the hull.
and of coarse tapered plugs at all the seacocks.
robwilk37 is offline
Bildge Pumps KindOfBlue Gear & Maintenance 12 12-14-2008 05:38 PM
Oil Change Pumps scurvy Gear & Maintenance 6 08-02-2007 12:08 AM
