Pumps do not do what you think - SailNet Community
 4Likes
post #1 of 22 Old 06-19-2013 Thread Starter
vtsailguy's Avatar
Question Pumps do not do what you think
So I did some real world tests and calculations on my pumps.
Four pumps will net me about 160GPH
A one inch hole lets in 2,400GPH
Nowhere near enough for even a relatively small hole. Basically all pumps are useful for is open windows and children's dribble?
I made a video, the math is at the end, can this be right?
That Sinking Feeling | Sailing With Kids
Three mini-pirates scour the Caribbean Seas with stops for ice cream and legos
Latest blog post:
vtsailguy is offline
post #2 of 22 Old 06-19-2013
One of None
deniseO30's Avatar
Re: Pumps do not do what you think
bilge pumps are almost never big enough to "save" a boat.
My last project!
deniseO30 is offline
post #3 of 22 Old 06-19-2013
Dog Ship's Avatar
That's funny.
I did the exact same math with my boat shortly after we bought it and discovered that the gunnel would be underwater in less than 17 minutes with a 1 1/2" hole.
I wanted to have an idea of how much time I would have to abandon ship in the event that was unable to keep up with a leak.
We have three rules;
No screaming.
No bleeding on the sails.
No slobbering on the charts.
Dog Ship is offline
post #4 of 22 Old 06-19-2013
Asleep at the wheel
jimgo's Avatar
I think that's where the beezwax toilet ring and similar "stuff" can come in VERY handy. Staunch the flow, then use the pump to start getting rid of what's already come aboard or to deal with what little continues to come in.
Yachting Monthly did an interesting set of tests that might be helpful as you think this through:
JimMcGee likes this.
- Jim
Home: Western Philly 'burbs
1980 Allmand 31
1975 Albacore 15
jimgo is offline
post #5 of 22 Old 06-19-2013
Chastened
Ajax_MD's Avatar
Your best bet is to reduce the "head" that the pump has to push through, as much as possible, and have simple damage control equipment onboard that can quickly reduce a 1.5 inch hole to a trickle that the pumps can keep up with.
In addition to various wooden and foam plugs, I recommned Marine-Tex underwater putty and creating a 1'X1' heavy duty plastic or vinyl mat with grommet holes around the perimeter to act as a "belly band" for large holes.
Slap it on, tie it in place around the hull, and you can also put Marine Tex around the perimeter to seal things up.
This is all extreme, worst case of course. 99% of us will never need anything other than a wooden or foam plug.
chef2sail and bljones like this.
Alacrity, 1981 Tartan 33 #168
Ajax_MD is online now
post #6 of 22 Old 06-19-2013
Dog Ship's Avatar
I have an appropriate sized wooden plug for each through hull. I hope I never have to use any of them.
No screaming.
Dog Ship is offline
post #7 of 22 Old 06-19-2013
Jim, that was a great video! But I wonder how calm anyone would be without the boat hanging in the slings. Especially if you consider all the ways a boat could get holed - usually in unfavorable conditions. All the various methods demonstrated in the video would be much more difficult to execute in a pitching seaway. Just finding the source of the leak can be a challenge in itself.
Michael K is offline
post #8 of 22 Old 06-19-2013
Tim R.'s Avatar
I am hoping my setup would buy me some time. I have a 500GPH and a 2000GPH pump in the bilge along with a hand operated pump from the cockpit. I also have a valve that is upstream of the engine raw water intake seacock that would allow my engine to pump bilge water. In a pinch I could also plumb the fresh water pump and the wash-down pump for temporary duty.
A big problem that is often discovered when it is too late is that the bilges in many boats have debris that clogs pumps when you need them the most.
Tim R.
Our Carina is for sale
1997 Caliber 40LRC
Tim R. is offline
post #9 of 22 Old 06-19-2013
Learning a bit every day
FinallySailing's Avatar
I've developed a slight obsession with bilge pumps ever since I've managed to flood my boat on hard the first winter we've had her . So I've got three electric pumps (2400 gph x2, 500gph gx1) and the hand operated whale gulper that I've modified so that I can basically now reach any place inside with a hose to suck it dry. I know, it's sheer OCD ... What I never understood, though, is, why in the name of safety do we drill new holes into the sides of our boats for through hulls that will potentially fail and flood the boat. Shouldn't the pumps let out on the highest possible point, i.e. on deck ? I yet have to find a reasonably "standard" bilge pump, that can provide enough lift/head to allow that.
FinallySailing is offline
post #10 of 22 Old 06-19-2013
Stu Jackson's Avatar
Commercially available "bilge" pumps won't, but if you want to continue your OCD then buy a pump like the ones the Coast Guard uses when they go to rescue folks.
Stu Jackson, Catalina 34, 1986, M25 engine, Rocna 10 (22#), Maple Bay, BC, Canada
Stu Jackson is offline
Bildge Pumps KindOfBlue Gear & Maintenance 12 12-14-2008 04:38 PM
Oil Change Pumps scurvy Gear & Maintenance 6 08-01-2007 11:08 PM
