Jackline attachments - SailNet Community
post #1 of 14 Old 06-19-2013 Thread Starter
Barquito
Barquito's Avatar
I bought some heavy duty 1" nylon flat webbing for jacklines. Turns out the stuff is really slippery. I can't just use a clove hitch to attach to a cleat. It pulls right out. What kind of attachement should I use on each end? Does it need to be adjustable? Maybe a loop sewn in, a carabiner...?
Valiant 32
Barquito is online now
post #2 of 14 Old 06-19-2013
Asleep at the wheel
jimgo's Avatar
Re: Jackline attachments
At Home Depot, I found a ratcheting tie-down that was sold singularly. I am considering using a loop sewn into one end and the ratchet part of the tie-down to pull that tight. I won't be over-tightening it, but the ratchet should let it be adjustable.
- Jim
Home: Western Philly 'burbs
1980 Allmand 31
1975 Albacore 15
jimgo is offline
post #3 of 14 Old 06-19-2013
It absolutely should be sewn.
You *could* use the ratchet, but I'd probably grab a stainless on from strapworks.com. Not to mention, I'd hate to have that thing banging away on my deck.
tschmidty is offline
post #4 of 14 Old 06-19-2013
I don't discuss my member
zz4gta's Avatar
Clove hitch??? Do you mean cleat hitch? Clove hitch doesn't hold very well even in it's intended use.
I take a full turn on the bow cleat and finish with cleat hitch, no problems so far. Get them as tight as you can. Or you can sew loops into each end. Put one end over the cleat and the other end lash to the other anchor point.
Merit 25 # 764 "Audrey"
zz4gta is offline
post #5 of 14 Old 06-19-2013
Over the years I have noticed that most "jack lines" do have a -heavily- stitched loop in one end. We usually just take the other end to a horn cleat and apply a cleat hitch with some extra added hitches to account for the slipperyness of the material.
(Agreed also that a "clove hitch" is easy to work loose with most any line.)
No matter what hitch or knot you start with, it's ok to add some additional hitches with the free end.... after all, that's what a "hitch" or "knot" does: adds enough layers of friction of line against itself that it does not pull loose, for the given purpose and material.
olson34 is offline
post #6 of 14 Old 06-19-2013
GeorgeB's Avatar
I have sewn loops in one end. The first two photos are my cockpit jackine. I terminate the aft end via a water knot. You can use the water knot to fashion a loop too. The aft ends of my main jacks terminate using a cleat hitch. If they are going to be out for several days, sometimes I chicken out and fasten a plastic cable tie over the finished cleat hitch.
George B
2000 Catalina 34 MkII
Alameda, Ca.
GeorgeB is offline
post #7 of 14 Old 06-20-2013
Remember you're a womble
PaulinVictoria's Avatar
I appear to have jacklines made from coated stainless that are fitted to the toerail using shackles.
Orange Crush
1974 C&C27 MkII
PaulinVictoria is offline
post #8 of 14 Old 06-20-2013
For a loop: Overhand knot on a bight?! Webbing ties easy. End to end: Follow through an overhand knot (also called a tape knot). You can even tie a bowline in webbing!
Joel H. is offline
post #9 of 14 Old 06-20-2013
bigdogandy's Avatar
Dock
I attach the loop end of my jacklines to a cleat at the stern and then use a trucker's hitch at the bow cleat to secure / tension the lines. Works great for me.
Andy
Key Largo
S/V Everlasting Moon
1981 Endeavour 32
Be joyful though you have considered all the facts.
- Wendell Berry
bigdogandy is offline
post #10 of 14 Old 06-20-2013
Battered and Bruised
Silvio's Avatar
Look at some climbing sites for good info on tying webbing. What Joel H. says above is what works for me, bowlines tie well in webbing as well as a "waterman's knot" which may be what Joel H. is describing as a "tape knot?", never heard that term before so I learned something today. Time to quit.
SV S.S.R.I
It's my happy pill
Silvio is offline
Jackline system Joel H. General Discussion (sailing related) 22 05-01-2013 09:50 PM
Jackline Breaking Strength sailak Gear & Maintenance 5 05-27-2009 11:14 PM
Attachments in PMs jackdale Announcements and Suggestions Box 2 12-10-2008 12:41 AM
Trouble with attachments danjarch Announcements and Suggestions Box 8 08-29-2007 11:18 PM
