Mooring Cleat Backing Plate Installation - Page 2 - SailNet Community
post #11 of 12 Old 06-20-2013
asdf38's Avatar
Re: Mooring Cleat Backing Plate Installation
Originally Posted by engineer_sailor View Post
Thanks for all of the input.
If the underside surface of the deck isn't too irregular, could one get away with not using epoxy at all?
SloopJonB: The packing tape idea is pretty clever and easier to source than mold wax
BTW, the rationale for the addition of the backing plates is:
1. A bow cleat is loose and I have to remove the v-berth cabinetry anyway
2. Catalina recommends adding backing plates as their 1.5" washers originally used can sometimes cause spider cracking
Josh
By loose do you mean just the hardware was loose or have the holes widened?
If they've widened it would be wise to epoxy fill them and re-drill proper sized holes (this is smart anyway to protect the core). You don't want the hardware rocking around in oversized holes.
asdf38 is offline
post #12 of 12 Old 06-26-2013 Thread Starter
Just loose. As it turns out the holes in my backing plates seem to not match the spacing of my cleat hardware ::. After removing and replacing the cabinetry in the vberth for the second time to reach the bow cleats, I've decided I am going to install access plates in the anchor locker.
engineer_sailor is offline
Backing plate material for stanchions benajah Gear & Maintenance 40 08-09-2011 08:13 PM
Backing plate weephee General Discussion (sailing related) 4 05-17-2010 10:17 AM
Backing plate options WesterlyPageant Gear & Maintenance 6 09-16-2009 04:22 PM
Backing Plate Size? WhatTheFoley Gear & Maintenance 34 07-22-2009 12:01 PM
To backing-plate or not, that is the question brak Gear & Maintenance 5 07-09-2007 08:13 PM
