Re-Wiring Mast - SailNet Community
post #1 of 6 Old 06-20-2013 Thread Starter
Re-Wiring Mast
Has anyone ever re-wired Cheoy Lee os 40 main mast? I'm just trying to run a new coax cable for VHF and the old cable seems to be retained somewhere along it's length
PaulnNathalie is offline
post #2 of 6 Old 06-20-2013
Dog Ship's Avatar
Re: Re-Wiring Mast
If all you are trying to do is replace this wire and you have not removed anything to help accommodate that, then you would be very fortunate to simply pull a new wire through without any problems.
Your old antenna cable could be wrapped around a multitude of things.
May I suggest removeing all of your halyards and rewire everything in your mast through a length of 1" conduit. By doing this your wires will be protected from halyard shafe.
We have three rules;
No screaming.
No bleeding on the sails.
No slobbering on the charts.
Dog Ship is offline
post #3 of 6 Old 06-20-2013 Thread Starter
Re: Re-Wiring Mast
AHHH But if it were only that easy. I took the base of the mast off hoping that it woud be hollow....no such luck. Yep, the old coax is still in there, but it seems to be retained somehow somewhere along the interior length of the mast. Now this really doesn't make any sense because who would construct a wooden mast around a handful of wires???? It's not a problem of halyards because they're all extenal. I'm kinda hoping that someone has come up against this problem with the offshore 40.
post #4 of 6 Old 06-20-2013
Re: Re-Wiring Mast
Did you try the CL Association forum?
Delphi Forums Login*-*Welcome! Please log in.
SVTatia is offline
post #5 of 6 Old 06-20-2013
overbored's Avatar
Re: Re-Wiring Mast
with external halyards you can just drop in a new wire and leave the old
"GOLD RUSH" PRINDLE 16
overbored is online now
post #6 of 6 Old 06-20-2013
aeventyr60's Avatar
Re: Re-Wiring Mast
When I opened up my wood mast I found that some wires were in fact stapled to the inside. No wonder I could not pull them out! There was a pvc conduit which had the VHF cable, mast head lights and anchor wire. It was tough to pull the last wire(wind speed cable) through. I ended up using some liquid soap to lubricate the wires. Make sure you have a stout messenger line on the end of the wires.
"Your dreams minus your doubts equals your net worth"
Life is a short journey, filled with emptiness and pain. Get all the sailing and booty you can.
aeventyr60 is offline
Where does your mast wiring exit the mast? downeast450 Electrical Systems 0 02-27-2012 08:43 AM
Mast Wiring CLucas Gear & Maintenance 8 08-25-2010 11:06 AM
re wiring mast dorourke Gear & Maintenance 21 03-15-2008 09:34 PM
Mast wiring Wayne25 Gear & Maintenance 6 01-09-2007 11:04 PM
Mast wiring sneuman Gear & Maintenance 2 04-04-2004 02:24 PM
