Mast work - SailNet Community
 1Likes
post #1 of 34 Old 06-20-2013 Thread Starter
Mast work
I am hoping to replace the masthead/foredeck light Saturday on my c&c 36. I bought a Harken Deluxe Bosun chair from West marine. My question is the the manual state a max weight of 220 lbs, and I am a bit more then that. How conservative is the manuals weight limit? Also would anyone be available, if the weight is conservative to help my wife take me up and down the mast?
Thanks for any advice and or help you all can give me.
Sent from my DROID RAZR using Tapatalk 2
egent is offline
post #2 of 34 Old 06-20-2013
HANUMAN
RobGallagher's Avatar
Re: Mast work
The weight is probably conservative. However, it will be a work out getting you up the mast.
Do you have self tailers?
Can you hire the crane at your yard to bring you up? For a few bucks it's so much faster, easier and a bit safer.
Use a second halyard as a safety backup.
Pick a very calm day, any movement is magnified by the length of the mast.
HANUMAN
'88 C&C 30 MKII
NOANK, CT
RobGallagher is offline
post #3 of 34 Old 06-20-2013
Re: Mast work
Who was going to hoist you up there??? is your wife willing to go up? If so it would be much easier for you to hoist her up than vice versa.
We usually take the halyard and re-lead it to a primary sheet winch for more power - still it's a bit of a chore esp if the 'liftee' is unable to assist by pulling on a spare line and/or shinnying up the mast a bit on their own.
Also good idea to have a second line connected as a backup, - don't let it get too slack along the way - and remember to ease it as well when coming down.
With help and caution, often the halyard can be led to an anchor windlass for power assist.
As far as the chair/seat itself goes, not sure what to say about that.. I'd expect a decent safety factor and that the language in the manual is lawyer-ese CYA... but of course YMMV and I'd hate to be the one to 'discover' the real limitation.
Faster is offline
post #4 of 34 Old 06-20-2013
MarkofSeaLife's Avatar
Dock
Re: Mast work
I doubt I can wind 220 pounds up the mast.
One guy we put up was about 200 pounds and two macho tough killer gym machines (me and a mate) took it in turns to wind him up. did about 10 feet and switched. BTW thats the good way of doing it... wind like hell and switch without missing a stroke before you get tired.
Find some 10 year old kid off the streets and teach it how to use a drill ...
Sea Life
Notes on a Circumnavigation:
MarkofSeaLife is offline
post #5 of 34 Old 06-20-2013 Thread Starter
Re: Mast work
Well at the moment it would be just the two of us, as we are relatively new to boat ownership, and don't know to many people to help. As to sending her up, this will get me in trouble, that word be even more weight that the chair is supposed to carry. My yard doesn't have a crane, not sure about the other marinas in the area. Any other suggestions for going up the mast other then a Bosuns chair?
egent is offline
post #6 of 34 Old 06-20-2013
"IT"???????
... Any other suggestions for going up the mast other then a Bosuns chair?
A mast tower can provide access, a tall pier at low tide (but you're on a lake??) If you can get alongside an accessible pier I've seen people rent a cherry picker or man-lift for a half a day... apart from the added cost that's a pretty nice way to get up there and feel secure with good access.
Faster is offline
post #7 of 34 Old 06-20-2013 Thread Starter
Re: Mast work
I have thought about trying to get one of the 18-20 year olds from work, but I just don't know if I trust them to do the work right.
Not a lake but upper Chesapeake Bay on the Sassafras River. I'll have to see where the bridge sits next to the mast, maybe able to do it from there.
egent is offline
post #8 of 34 Old 06-20-2013
no longer reading SailNet
Alex W's Avatar
Re: Mast work
In my group of friends we all have a ATN Mast Climber that we use and share. It's so much easier for the person going up the mast to use their legs to get up there.
The Mast Climber is expensive, but building a self climbing system myself wasn't going to be that much cheaper (maybe saving $100).
I don't know what ATN's weight limit is. We also back up the Mast Climber with a second halyard and someone tailing it on a winch just in case.
Alex W is offline
post #9 of 34 Old 06-20-2013
Re: Mast work
I can hoist my wife up the mast. But I'm to heavy for her to hoist me (even using the genoa winch). So I have had to send her up the mast several times
I have been looking for a solution to get up the mast without hiring a winch gorilla.
I made this device from a old piece of plywood, a camcleat, two eye straps and some bolts.
It's movable step that I put on a dyneema halyard (dyneema so it wont stretch to much when climbing), the end of the hallyard are attached to the mast ring and winched tight.
I use a bosuns chair attached to another hallyard.
Standing on the step the hallyard on the bosuns chair gets tightend, then I lift the climber with my foots while sitting in the bosuns char. Repeat x times.
By using this device my wife only has to take the slack on the halyard.
Going down I release the cam cleat and bring the step down with me.
Faster likes this.
knuterikt is offline
post #10 of 34 Old 06-20-2013
rbrasi's Avatar
Re: Mast work
How much purchase do you have on the chair rig? I only have 2-1, and my 16 year old son hoisted me sans winches (using cam cleats). I weigh about 190. I think the load would be lessened quite a bit with a 3 or 4 to 1 block setup.
1968 Cal 2-30
Sandpiper 2
MDR
rbrasi is offline
The last 3ft (mast work) deniseO30 Gear & Maintenance 21 03-11-2013 12:46 AM
Tape under mast track to separate stainless from aluminum mast preservedkillick Gear & Maintenance 1 05-12-2012 01:37 PM
tool recommendations for fiberglass, mast work LookingForCruiser Gear & Maintenance 2 06-10-2009 10:56 PM
How to secure steaming light to mast with halyards inside mast. Eihli Gear & Maintenance 7 04-14-2009 03:11 PM
How does self a raising mast work danjarch General Discussion (sailing related) 3 08-13-2007 10:42 AM
