Tohatsu help - Page 2 - SailNet Community
 1Likes
post #11 of 19 Old 06-21-2013
Re: Tohatsu help
meboater,
The Tohatsu sounds like an easy fix, per methods described by others above.
The Yamaha is a bit trickier. Beyond the cleanliness of the carb, there are a few tests you can do. The black cylinder sitting atop the carb has two wires. Test this "thermoelectric choke" for resistance with a multimeter; if it reads outside the range of 4.8 - 7.2 ohms it is faulty and will prevent starting altogether (mine read zero but once replaced the 9.9 Yammy fired up perfectly). Another similar test is resistance with the CDI, but you'll need to research the specs. Electromechanical issues like these can be tough to diagnose (I am still learning) but you can do it, sometimes better than the pros.
Michael K is offline
post #12 of 19 Old 06-21-2013
Mechsmith
Re: Tohatsu help
The ethanol dries out and makes a very sticky glue. It will also stick up a float needle and result in a no run at all condition. Do dry out the carb by pulling off fuel line or shutting fuel off to kill when parking. I have had it stick up a float needle over night. Wet (old) fuel makes it worse as etnanol has a certain affinity for water. Fiberglass fuel tanks are also a no-no with ethanol. I have seen it happen with three different motors. (Willy's Jeep, Stihl chainsaw, and Merc 7.5 outboard)
Seafarer 29 KCB
Mechsmith is offline
post #13 of 19 Old 06-21-2013 Thread Starter
Re: Tohatsu help
Originally Posted by MarkSF View Post
When you have finished running the engine, do you always run the carb dry of fuel? If not, you are constantly gumming up the jets, and it's a cumulative effect.
Another good habit is Stabil or similar in the fuel.
A third good habit is NEVER to use fuel that is more than one month old. Dispose of it in your car's gas tank.
Following these 3 habits, or not, can make all the difference, between a nightmare engine and a dependable one.
I use stabilizer, and was actually wondering whether running the carb dry is a good idea. Is it? What about moisture?
I would like to do something different, as I really appreciate a working motor when I need it.
meboater is offline
post #14 of 19 Old 06-21-2013
Re: Tohatsu help
Yes I think it's a very good idea, probably the most important of the 3. Some people say that running it dry is not sufficient, you should drain the bowl too. I don't go that far.
MarkSF is offline
post #15 of 19 Old 06-21-2013
Re: Tohatsu help
Suggest you drain instead of "running dry" as a small amount of fuel is left in the bowl when "running dry".
Paul T
dabnis is offline
post #16 of 19 Old 06-22-2013
Sailor
Gladrags1's Avatar
Re: Tohatsu help
There are some gas stations that sell ethanol free gas. My suggestion is to purchase ethanol free gas and your gum problems will be solved for the future!
Tod
Mandolin
Bayfield 36
Sailing out of Rock Creek, Chesapeake Bay
Gladrags1 is offline
post #17 of 19 Old 06-23-2013 Thread Starter
Re: Tohatsu help
Thanks for all the input.
Removed the carb, took it part way apart. Gently put a thin wire through 4 different little openings, and sprayed the hell out of it with carb cleaner.
It works great.
I did this hanging over the transom, which is nervewracking. Especially as I kept screwing up and actually had to re-install it 3 times.
Sal Paradise likes this.
meboater is offline
post #18 of 19 Old 06-23-2013
Captain Obvious
Sal Paradise's Avatar
Re: Tohatsu help
OK great!
It probably wont happen, but if it plugs up again, take it off and soak it for an hour in that carb cleaner kit. That gets out every little bit of dirt.
Sal Paradise
Senior Researcher - Dunning Kruger
Sal Paradise is offline
post #19 of 19 Old 06-24-2013
Re: Tohatsu help
It works great.
Glad you got it fixed. "Over the transom"? Oh my, If I had done that half the parts would be on the bottom.
Paul T
dabnis is offline
Tohatsu key blank Minnewaska Gear & Maintenance 11 05-03-2013 01:30 PM
6hp Tohatsu for Irwin 25 jrophoff Gear & Maintenance 12 01-14-2013 04:27 PM
tohatsu 3.5 won't run without choking jshep Gear & Maintenance 64 08-04-2012 08:26 AM
Tohatsu 3.5 or 4 HP? galernikus General Discussion (sailing related) 15 10-26-2008 10:08 PM
Tohatsu 6hp 4-stroke? safarisurf Gear & Maintenance 3 07-06-2006 11:43 AM
