Trolling motor and lead acid batteries for dingy.. - SailNet Community
post #1 of 5 Old 06-21-2013 Thread Starter
Hi,
I have been experimenting with using a standard electric trolling motor with a deep cycle battery to run my dingy.
I additionally put on a 35W solar panel and controller.
This worked ok... until I got down to georgia, where the tidal currents increased as I traveled south.
Here they are sometimes 3-3.5 knots, and there is just not enough power available.
Should I continue to purchase bigger trolling motors and more and more batteries for my dingy? lol.
-or-
Has this been tried before and someone can let me know where this ends?
(I know of propane motors and lithium ion electric motors.)
groundhog is offline
post #2 of 5 Old 06-21-2013
Siamese's Avatar
Re: Trolling motor and lead acid batteries for dingy..
With all their shortcomings, it's still tough to beat a gasoline outboard. I've considered lead acid, Torqueedo, and propane, but each has its issues. A properly maintained gasoline with fresh fuel is my weapon of choice.
Siamese is offline
post #3 of 5 Old 06-21-2013
poopdeckpappy's Avatar
How big a TM do you have? I have a 40# thrust TM on a 9' dink w/ a 65AH batt. ( no SP ) I can do 5kts on flat water and about 3.5 on crap water for about 90mins
I know Minn-Kotta has a 75# TM that would be killer
1955 Blanchard 51 Custom ( I got a woody )
1974 Ranger 33
Friends don't let friends do stupid things alone
poopdeckpappy is offline
post #4 of 5 Old 06-21-2013 Thread Starter
Its just a basic 30 lb thrust.
So Pappy, sounds like I can do this. Do you have only one lead acid battery?
I was thinking of building a box that would be under a seat that would hold the stuff. The solar panel is a ruggedized type that you can sit on.
post #5 of 5 Old 06-21-2013
I have two 65AH batts but only use one at a time unless we go sightseeing, If I take both it's a 3 hour tour. when I get around to it, I'll put them in a batt box and string them together so I'll have 210AH
I cut the connectors that came with the motor off and replace them with clamps like you'd get with jumper cables only smaller, takes <5 sec to switch batts
Also, each batt (group 24 ) fits neatly inside a Husky ( home depot ) tool bag so they're easy to move around
1974 Ranger 33
AGM batteries with Lead Acid Charger jamiemiller Electrical Systems 20 11-04-2010 02:47 PM
Batteries, gel vs lead acid?? sailnovascotia Gear & Maintenance 10 05-14-2009 09:57 PM
Trolling motor for dingy? Andyman Gear & Maintenance 7 05-20-2008 10:12 AM
trolling motor for the dingy? hertfordnc Gear & Maintenance 0 05-05-2008 09:30 AM
Lead acid, agm, or gel batteries? aroundtheworld Gear & Maintenance 5 03-26-2006 07:57 PM
