Pigtail Adapter: 30A to household 15a plug - SailNet Community
 3Likes
post #1 of 17 Old 06-22-2013 Thread Starter
s/v Tiger Lily
dvuyxx's Avatar
Does anyone have any experience using a 30 amp to 125v standard plug pigtail adapter ... To plug into a regular household extension cord. I frequent a family member's dock that does not have standard marina-grade shorepower. Any caveats?
Severna Park, MD
Pearson 35 - s/v Tiger Lily
dvuyxx is offline
post #2 of 17 Old 06-22-2013
overbored's Avatar
Re: Pigtail Adapter: 30A to household 15a plug
if it is a 30 amp circuit and you plug in a 15 amp cord you take a chance of burning up the cord before the 30 breaker will trip. yes I know it is done but that does not make it safe. breakers are to protect the wires. so if the breaker is 30 amps then the wire should be able to take 30 amps. you could have a portable 15 amp breaker box that plugs into the 30 receptacle before the 15 amp cord.
"GOLD RUSH" PRINDLE 16
overbored is online now
The Following User Says Thank You to overbored For This Useful Post:
dvuyxx (06-22-2013)
post #3 of 17 Old 06-22-2013
I'd also suggest using a test light and confirming the ground (especially) on the family wiring. An awful lot of casual "extending" on home wiring is done without ground, or with hot and neutral reversed. It might be worthwhile adding a box to your pigtail, with a GFI, 15 amp breaker, etc. so you've got a robust adapter that can be used anywhere. Or not, as suits your time and wallet.
hellosailor is offline
The Following User Says Thank You to hellosailor For This Useful Post:
dvuyxx (06-22-2013)
post #4 of 17 Old 06-22-2013
Is this what you're looking for? I have used one when the boat was hauled.
MARINCO EEL-Style Shore Power Straight Adapter, 15A M-30A F, 1Piece at West Marine
adki110 is offline
The Following User Says Thank You to adki110 For This Useful Post:
dvuyxx (06-22-2013)
post #5 of 17 Old 06-22-2013
Sea Sprite 23 #110 (20)
mad_machine's Avatar
I think I see what you are saying. Your boat has the 30a shore power receptical, but the only thing availible at the dock is 15a house power?
I think I would be more tempted to run off of the batteries and use the house power to keep them charged
Art Haberland
In the end all that matters is how fully you loved, how gently you lived, and how gracefully you let go of things that did not belong to you -Buddha
mad_machine is offline
The Following User Says Thank You to mad_machine For This Useful Post:
dvuyxx (06-22-2013)
post #6 of 17 Old 06-22-2013
Sailor
Gladrags1's Avatar
I don't think you will have a problem. You won't be able to run a/c while plugged in and you may have a problem running a microwave, especially if the battery charger is on. What would happen in that case is the breaker in the house will click off and need to be reset. No big problem, just a hassle. If you find that a problem, convince the family to install a proper 30 amp service if they want your company!
Tod
dvuyxx likes this.
Mandolin
Bayfield 36
Sailing out of Rock Creek, Chesapeake Bay
Gladrags1 is offline
The Following User Says Thank You to Gladrags1 For This Useful Post:
dvuyxx (06-22-2013)
post #7 of 17 Old 06-22-2013
I used a 125V to 30A pigtail to plug in my power cord every spring on the hard in Rock Hall as the majority of electrical service in the "boat parking" area was of the 125V type. Of course the 125V outlet was protected by a 20amp breaker. Common stuff from what I've seen.
chef2sail likes this.
Seaduction is offline
The Following User Says Thank You to Seaduction For This Useful Post:
dvuyxx (06-22-2013)
post #8 of 17 Old 06-22-2013
We have a solid plug adaptor (not a pigtail) to plug our 30A shore power cord into a 120V AC outlet... Only issue is that its a bit long and may prevent the box from closing - sometimes we have to support the cord with some lashing or it pulls itself out.
Just remember your load limitations...
Faster is online now
The Following User Says Thank You to Faster For This Useful Post:
dvuyxx (06-22-2013)
post #9 of 17 Old 06-22-2013
I don't discuss my member
Fstbttms's Avatar
I go the other way 'round. Every day I plug my 110-volt, 10.5 amp, 1.25 hp air compressor into 30 amp shorepower using a 16-gauge extension cord. Have done for almost 19 years. Never a problem.
Fstbttms is offline
The Following User Says Thank You to Fstbttms For This Useful Post:
dvuyxx (06-22-2013)
post #10 of 17 Old 06-22-2013 Thread Starter
s/v Tiger Lily
dvuyxx's Avatar
Correct. My boat is pretty modest load wise. No a/c or microwaves etc. I mostly want to keep my batteries topped off and run some small power tools. I have a smart charger on board.
Severna Park, MD
dvuyxx is offline
Tags
30 amp , extension cord , pigtail , power , shorepower
Propane tank adapter THEFRENCHA Gear & Maintenance 12 03-13-2013 12:30 AM
CNG refil adapter + ??'s degreeoff General Discussion (sailing related) 3 01-20-2013 10:34 PM
want to buy wheel adapter for windvane wotata General Discussion (sailing related) 2 11-28-2012 02:44 PM
15/20 amp to 30 amp adapter itsaboat Electrical Systems 1 12-27-2011 11:46 PM
generator adapter gsyversen Gear & Maintenance 11 06-30-2008 07:32 PM
