Floating Dock protection - SailNet Community
 1Likes
  • 1 Post By svHyLyte
post #1 of 6 Old 06-22-2013 Thread Starter
davidpm's Avatar
Every year I get a new victim to let me use their boat for the season.
This year I have a bristol 32 at a floating dock.
This boat with a full keel is the least maneuverable boat I've ever shared for a season. The slip is subject to strong currents.
The end of the finger pier has a piling. The end of the dock instead of the half round pipe to capture the piling has a 2" square rectangular steel box section with extremely sharp corners.
I will be docking and de-docking by myself and would like a little protection.
I can buy some commercial rubbing material and/or fenders for the dock.
What else would work that might me just as effective but cheaper.
How do I protect the sharp corner of the steel box section?
davidpm is offline
post #2 of 6 Old 06-22-2013
Sailor
Gladrags1's Avatar
Re: Floating Dock protection
West Marine sells these Taylor Made Corner Guards. Find a source for large, thick electric ties to go around the metal bar and the corner guard to secure the guard to that area. I would put holes in the edges of the guard for the electric ties to pass through so they don't work themselves free, dropping the guard. The uv will eventually eat the ties but they should last a season or two before replacing.
Tod
Mandolin
Bayfield 36
Sailing out of Rock Creek, Chesapeake Bay
Gladrags1 is offline
post #3 of 6 Old 06-22-2013
Old as Dirt!
svHyLyte's Avatar
Corner rollers attached with U-Bolts:
See Dock Rollers - Motivation | Marine Supplies 1-877-811-3625
Faster likes this.
svHyLyte is offline
post #4 of 6 Old 06-22-2013
RocketScience's Avatar
...What else would work that might me just as effective but cheaper.
A used small compact car, or motorcycle tire cut in half? Zip-tied to the piling cage....?
Synthetic Rigged Wauquiez Pretorien 35
RocketScience is offline
post #5 of 6 Old 06-23-2013
Old as Dirt!
svHyLyte's Avatar
Having once had to lay against black (discarded) tire "fenders" on a commercial pier, I can attest that the (skid) marks they can/will leave on your hull can take hours/days to remove unless the tires are covered with some type of fabric or fleece.
FWIW
svHyLyte is offline
post #6 of 6 Old 06-23-2013
FWIW
No doubt, but my suggestion was for a cheap protection device, not to lay against. Your idea of covering the tire with fabric, etc. is a good one tho.
Cheap floating dock -- how to build? wsprague General Discussion (sailing related) 20 02-09-2013 09:58 AM
Best way to clean scuffs from floating dock on your hull? luken7 General Discussion (sailing related) 2 08-07-2011 12:04 PM
Anchoring a floating dock to the shore zedboy Gear & Maintenance 11 01-22-2011 06:33 AM
I'll take a floating dock.... administrator General Discussion (sailing related) 0 07-10-2006 07:55 AM
