New Honda 2.3 outboard not running - Page 2 - SailNet Community
 9Likes
post #11 of 42 Old 06-24-2013
Skipper Jer's Avatar
Re: New Honda 2.3 outboard not running
And since this started happening so soon from the factory how do we know there wasn't some sort of manufacturing debris left in the bowl that got sucked up into the carb jets? A little metal spec is enough to clog these carbs.
Nor'sea 27
And the trees are all keep equal by hatchet, axe and saw...RUSH
I invented a new word today, plagiarism.
Skipper Jer is offline
post #12 of 42 Old 06-24-2013
avenger79's Avatar
i would take it back for warranty work, but expect a bill. I was recently looking at a new OB for the boat. same size as yours. first thing they stressed was run it dry everytime. why the bill? because leaving fuel in motor to varnish is generally not covered.
avenger79 is offline
post #13 of 42 Old 06-24-2013 Thread Starter
CaribDream's Avatar
2 week old fuel varnishes? That's a bit extreme no? Out of all the outboards I have ever owned, I have never been required to run them dry, nor does it say that in the manual. It does state in the manual that if you plan to "store" the motor for an "extended period of time" it should be treated. I don't think 2 weeks is "storing" nor "extended".
Go sailing now my brother,
It's later than you think.
CaribDream is offline
post #14 of 42 Old 06-24-2013
no longer reading SailNet
Alex W's Avatar
On the 2hp Honda it is recommended that you run the carb dry, not that you run the whole fuel tank dry.
That is why there is a fuel on/off lever on the starboard side of the engine (at least on my older BF2A). I always do this when I'm not going to be using the motor for a couple of days. It takes a few minutes at idle speed due to the engine's extreme fuel economy. I guess if you were really impatient you could use the carb drain screw, collect the fuel, then dump it back into the tank.
The carb is so small that it is possible for fuel to evaporate and leave behind varnish in a couple of weeks.
I don't think that any other brand of engine will be any better in this respect. They all use small carbs and fuel varnishing is a problem.
Alex W is offline
post #15 of 42 Old 06-24-2013
avenger79's Avatar
while I would wholeheartedly agree with you. I have seen it happen where they tell the customer it is operator error due to varnish. new fuels are terrible for varnishing.
post #16 of 42 Old 06-24-2013 Thread Starter
CaribDream's Avatar
This makes more sense. I wish it would have stated that in the manual.
post #17 of 42 Old 06-24-2013
Alex W's Avatar
It does say that in the storage portion of the manual. Here is a manual for a 2006 BF2D:
http://marine.honda.com/pdf/manuals/31ZW6610.pdf
Look at pages 51-53. Storage for them is not using it for over 15 days, at least as I read the manual.
I haven't looked at the newest manual, but I'm sure it's covered and if anything the storage times would have come down.
Alex W is offline
post #18 of 42 Old 06-24-2013
The warranty can't be "voided." It it technically and legally impossible to do that. Honda has a legal obligation to repair any factory defects, and just because you elect to try and do some repairs does not excuse them from that obligation, period. You can change your own oil, take it to another non-Honda dealer, use non-factory parts, etc. The key caveat is as long as your actions aren't shown to be the cause of any failure or problem with the outboard when you want Honda to pay for warranty repairs.
In short, if your repairs damage or break some part of the outboard and then you expect Honda to pay for it, they will probably decline. If some other original or genuine part of the outboard is broken and it is determine to have a factory defect, Honda will likely pay for the repairs.
If you think there is a genuine factory defect, for sure, have a Honda dealer inspect it. Be sure you communicate with the dealer who is paying for what BEFORE any repairs are made to the motor.
-Robert@Honda
Caveat: I work for Honda, but the preceding is my opinion alone.
robert@hm is offline
post #19 of 42 Old 06-24-2013 Thread Starter
CaribDream's Avatar
You are correct sir... Man, that is lousy! 15 days?!
post #20 of 42 Old 06-24-2013
I forgot to drain the gas from my Honda 2HP. The next spring, no go. The bowl was full of debris, almost like sand? I did two experiments:
1. Let half a coffee can of treated gas evaporate in open air. After a number of months all that was left was a little bit of what looked like 90 weight gear oil, which never went away.
2. In an old carburetor, I left the bowl full of treated gas with the carb assembled. After a month or so, I took it apart. There was absolutely no evidence of any deposits or debris, it was perfectly clean.
Perhaps there is a difference in the gas evaporating in open air and the gas evaporating in an enclose area such as the assembled carb?
In any event, I always drain the carb if it is not going to be used fro a week or so, seems to work, no problems.
Paul T
dabnis is offline
Tags
honda outboard
Honda 8HP outboard to charge 12V i_amcdn Gear & Maintenance 6 08-10-2012 11:19 AM
Honda generator(s) in lieu of running auxiliary tankersteve Gear & Maintenance 66 03-09-2012 08:44 AM
Parts for Honda 100 9.9HP outboard monroe Gear & Maintenance 1 08-16-2006 04:23 AM
Honda 4 stroke outboard mikehoyt Gear & Maintenance 4 05-24-2002 06:08 AM
Honda Outboard GGartin Gear & Maintenance 0 01-14-2001 06:14 PM
