-   -   New Honda 2.3 outboard not running (http://www.sailnet.com/forums/gear-maintenance/100704-new-honda-2-3-outboard-not-running.html)
CaribDream 06-22-2013 08:37 PM
Just got this motor about a month ago. It ran fine the first times out. Today, third use, it will only run half throttle or above on half choke. Even when warm, it now needs full choke to start. It will not idle without immediately stalling on any choke setting. On half choke, half throttle it runs smooth as can be. With the choke off and 1/3 to 1/2 throttle it runs but has oscillating revs.
Any ideas?
dabnis 06-22-2013 08:53 PM
Re: New Honda 2.3 outboard not running
Sounds like it is starving for fuel. Suggest you make sure the tank vent is not plugged. If not, sounds like some debris got into the carb, or the gas evaporated, leaving goo behind. Maybe some carb cleaner at about 50% gas mix. Let it set for a day or two then try gain. If no go, time to clean out the carb, thin wire and compressed air. Suggest you drain the carb if it is not going to be used for a week or so
Paul T
SHNOOL 06-22-2013 08:55 PM
Is it a new outboard, or used?
Sadly a used outboard could be suffering from a lacquered carb bowl. If it's new, then someone would need to eat it!
I won't start anyone on WHY it's lacquered, but lets just say run it dry every time you use it (once it's running well again).
CaribDream 06-22-2013 09:24 PM
Brand new. One month old.
CaribDream 06-22-2013 09:27 PM
Paul T
Exactly what I was thinking - fuel starved. Just can't figure out how something got messed up this early. It's one month old, used 3 times and I always run super instead of regular just like my other boats.
JimsCAL 06-22-2013 11:35 PM
Under warranty then. Use it.
robert@hm 06-24-2013 11:37 AM
Sure sounds like a fuel delivery problem. Today's "modern" ethanol fuels can wreak havoc in small gas engines with carburetors that aren't used every day, and slime/gunk can form quickly, especially in warm weather. Sometimes, a good fuel system clean can solve it. In the worst case, a complete cleaning of the fuel system / carburetor is required. Typically, poor running due to a fuel deterioration issue is not considered a factory defect so isn't covered under warranty. A Honda dealer can still repair it, but at your expense. If you want to DIY, it is not too difficult; a few hand tools, and take your time. Here are a couple of pages from the shop manual; use a good quality carb cleaner a lots of compressed air to clean all the passages...
http://i1277.photobucket.com/albums/...ps2887fb21.jpg
http://i1277.photobucket.com/albums/...psc4145207.jpg
-Robert@Honda
Caveat: I work for Honda, but the preceding is my opinion alone.
CaribDream 06-24-2013 11:50 AM
-Robert@Honda
This engine is only about a month old. Oldest gas would be 2 weeks and all I run is super 93 octane. I could understand if I had fuel that was a month or more old - but that's not the case. If Honda wants to charge me on this, I'll be moving to another brand plain and simple.
Skipper Jer 06-24-2013 11:55 AM
I wouldn't do anything to the engine until the dealer took a look at it. Trying to fix this yourself may void the warranty. Me? I'd dump the gas, put the proper octane rated fuel in the tank and crank her up. Also read the manual to see if there is anything said about ethanol laced gasoline.
CaribDream 06-24-2013 12:01 PM
Couldn't agree with you more. If I pull anything apart they will void the warranty for sure. It had fresh from the pump gas in it when it started doing this.
