Using brush instead of spray for gel - SailNet Community
 2Likes
  • 1 Post By overbored
  • 1 Post By PorFin
post #1 of 5 Old 06-23-2013 Thread Starter
For covering up some flaws in the hull, has anyone used a brush rather than a spray for applying gelkote? More sanding would be needed, but it should sand down rather easy would be my guess? A picture of the hull that needs work is attached.
lancelot9898 is offline
post #2 of 5 Old 06-23-2013
overbored's Avatar
Re: Using brush instead of spray for gel
you can use a brush for small touch up and on horizontal surface but on vertical surface no way, it just does noes not work well. if you want to spray on a small area it is best to use a Preval sprayer.
Preval ? Preval Sprayer Products.
these work great for gelcoat and you don't need a compressor
Rhapsody-NS27 likes this.
"GOLD RUSH" PRINDLE 16
overbored is online now
post #3 of 5 Old 06-23-2013
Seņor Member
PorFin's Avatar
Yes, you can use a brush.
The challenge on vertical surfaces is keeping the gel from running/sagging. If you use a piece of acetate over the top of the repair, you can keep it in check. Tape all the way across the bottom first, apply the gel, then roll the acetate up over the repair. Use a plastic squeegee or body filler spreader to work it relatively flat. Tape the top, then tape the sides. The good thing about the acetate is that it will leave you with a pretty fair surface. The bad thing is that with the molded planking, you're gonna have to reestablish all those grooves.
I've tried to get a Preval sprayer to work with gel, but have had little success. The problem is that the you need to thin the gelcoat considerably to get it to spray well. A couple of suggestions if you decide to go this route:
- Pull the strainer off of the pick-up tube on the sprayer.
- Thin the gel with Styrene only. Acetone will work, but it flashes really quickly.
- Adjust your mix before you add any catalyst. Spray onto a piece of glass, and add styrene until you get a coat that covers smoothly but doesn't sag/run.
- Add the amount of catalyst needed for the volume of the total gel & added styrene in the bottle. If you only add enough catalyst for the gel you started with, then the gel won't dry fast enough.
Good luck which ever method you choose.
jimgo likes this.
________
'85 BYB Vagabond 39
PorFin is offline
post #4 of 5 Old 06-23-2013 Thread Starter
There is a youtube presentation by TAP Plastics that shows what looks like a disposable glue brush being used to apply gel to a vertical surface. I thought that it would remove a couple of steps from going the preval sprayer route. Plus I would not have to thin with the styrene if I go that route. A small foam brush might also be an option. Apparently the demonstration used a non wax gel in that it showed three ways to get it to cure. One being applying heat via either a hair dryer or sun, two via the standard PVA? spray and thee via a celephane sheet to block the air so that it fully cures. It does not mention the wax gel which does not require any of those steps, but someone suggested that the wax gel is a pain to work with. Also I really don't want to fill in those grouves and I'm just trying to cover the small pimples thinking that a thin coat of gel will hide those flaws.
post #5 of 5 Old 06-23-2013
Seņor Member
PorFin's Avatar
Just be careful with the glue/acid brush -- they shed bristles very, very easily. Nothing worse than trying to dig bristles out of wet paint/gelcoat.
A foam brush will work, but I really prefer the control you get with a real bristled brush. If you're willing to part with a couple of bucks, grab an artist's brush at Michael's or some other hobby store.
I never found waxed gelcoat a problem on it's own, but given a choice I'd go with unwaxed. You can air inhibit it with PVA or plastic, or if you know you're going to be building up a couple of coats you can just let it set and apply your second coat without having to scrub and sand.
________
'85 BYB Vagabond 39
PorFin is offline
looking for a chain scrubbing brush Lin and Larry Gear & Maintenance 12 12-29-2013 01:51 PM
Tip with Foam or Bristle brush Finallybuyingaboat Gear & Maintenance 12 06-14-2009 11:24 AM
Bronze prop, SS brush trantor12020 Gear & Maintenance 1 05-26-2009 05:39 PM
Medical Lessons from a Brush with Death William Mahaffy Seamanship Articles 0 11-24-1998 07:00 PM
Medical Lessons from a Brush with Death William Mahaffy Gear and Maintenance Articles 0 11-24-1998 07:00 PM
