yanmar smokes when accelerating.... - SailNet Community
 1Likes
  • 1 Post By PBzeer
post #1 of 10 Old 06-23-2013 Thread Starter
Red face yanmar smokes when accelerating....
Hi all,
the single lunger seems to smoke and emit some black oil just when I accelerate . then it seems to be fine.... are there rings in a diesel that could be going ? I get about 5.5 knots at 80 % throttle in calm air, so it seems to have lots of power (compression)??.
Thanks in advance.
Mike
GaiaOrion is offline
post #2 of 10 Old 06-23-2013
MarkofSeaLife's Avatar
Dock
Re: yanmar smokes when accelerating....
Hi Mike
It will most likely be a dirty prop.
You need to dive on the propeller and scrape the barnacles off.
Please take my advice and scrape the prop and then take the boat out BEFORE you spend money on a mechanic etc. Folks have spent thousands and thousands on their engines and the problem still continues till the prop is clean.
I know it sounds too simple.
Mark
PS Do it yourself Divers cost a lot. I just use my snorkel and mask and gloves Cheap gardening gloves are good
Sea Life
Notes on a Circumnavigation:
MarkofSeaLife is offline
post #3 of 10 Old 06-23-2013
Dog Ship's Avatar
Check the air filtre.
We have three rules;
No screaming.
No bleeding on the sails.
No slobbering on the charts.
Dog Ship is offline
post #4 of 10 Old 06-23-2013
+1 what Mark said.
The black smoke is unburned fuel.
In my case cleaning the prop made no improvement, but the problem was still the prop. I ended up having to take the prop off and had it re "tuned" (not sure what the proper term is), but the prop specialist heated the prop and adjusted the pitch of the blades. After that, all good!
Last edited by Goldfinger; 06-23-2013 at 09:57 PM. Reason: Bad smelling... er spelling
Goldfinger is offline
post #5 of 10 Old 06-23-2013
SchockT's Avatar
I agree, black smoke usually means the engine is starving for air.
1979 Santana 30 Tall Rig
Hull#101
SchockT is offline
post #6 of 10 Old 06-24-2013
chef2sail's Avatar
Usually dirty prop. Rev it in neutral, if no black smoke its the prop. If black smoke check to make sure oil is not overfilled. If not then take of air filter, then start looking deeper.
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is online now
post #7 of 10 Old 06-24-2013
SchockT's Avatar
The dirty prop diagnosis is interesting. To me it seems counter-intuitive. If prop blades are fouled, they are going to be less efficient due to cavitation. A cavitating prop is going to result in LESS load on the engine, not more! While it is true that an overloaded engine produces black smoke, i can't see how a dirty prop could cause that unless the prop was fouled with a piece of rope that creates more friction? I suppose a severely fouled prop would have so much mass in growth that its own inertia resists the acceleration, but you would think in a severe case like that it would have trouble getting the boat moving at all.
Hull#101
SchockT is offline
post #8 of 10 Old 06-24-2013
Wandering Aimlessly
PBzeer's Avatar
It's the load (usually in combination with a foul bottom).
chef2sail likes this.
John
Ontario 32 - Aria
Free, is the heart, that lives not, in fear.
Full, is the spirit, that thinks not, of falling.
True, is the soul, that hesitates not, to give.
Alive, is the one, that believes, in love.
JCP
- Website & Blog
PBzeer is offline
post #9 of 10 Old 06-24-2013
thinking of this...
JSL3's Avatar
Originally Posted by GaiaOrion View Post
Hi all,
Thanks in advance.
Mike
I had the same problem awhile back. Here's the whole thread on Sailnet.
Here's what my problem turned out to be.
~Jim
Ramble On
1986 Pearson 28-2
JSL3 is offline
post #10 of 10 Old 06-24-2013
SchockT's Avatar
Wow! How the heck were you even able tp get anywhere with that much growth!
Hull#101
SchockT is offline
Cheap Classic Plastic smokes the fleet in 2013 Down the Bay Race jameswilson29 General Discussion (sailing related) 65 06-04-2013 02:52 PM
Value of a Used Yanmar? mrybas Diesel 7 11-17-2009 10:53 AM
Yanmar 2GM nereussailor Gear & Maintenance 6 08-12-2009 01:03 AM
Looking for a Yanmar 2GM knotslo General Discussion (sailing related) 4 03-04-2009 07:12 PM
Accelerating the learning curve crewing and loosing the fear of heeling over! Lancer28 Learning to Sail 7 10-17-2007 01:27 PM
