Stuffing box ooze - SailNet Community
post #1 of 7 Old 06-23-2013 Thread Starter
Talking Stuffing box ooze
Hey again, something else niggling my primordial sailors brain... I put some new stuffing in and it seems to not be dripping water like I know it should, but when I loosen it as little as I can, it drips too much. The shaft isn't getting hot after load for up to ten minutes at 3/5 throttle. Also there seems to be a yellowish ooze emmiting where the water should be coming out. could that be from the wax from the new stuffing ? Thanks again .
GaiaOrion is offline
post #2 of 7 Old 06-23-2013
Tartan 27' owner
CalebD's Avatar
Re: Stuffing box ooze
Could be, if you used conventional flax stuffing that is waxed.
Teflon/graphite empregnated stuffing materials will usually leave a gray ooze, if any.
Everybody has one:
CalebD is offline
post #3 of 7 Old 06-23-2013
CapnChuck's Avatar
You say the shaft isn't getting hot, but what about the stuffing box. If something other than water is oozing out your may be melting the packing in the gland. If that has happened, you will need to repack it. Chuck
Our Blogs
CapnChuck is offline
post #4 of 7 Old 06-24-2013
I think if the packing gland doesn't feel hot you can continue running it... give it another 10 or 20 minutes (checking frequently for heat) and by then it should start to drip water. I observed the same thing you describe last time I repacked my stuffing box with traditional packing, and after a little while the oozing stopped and it started to drip while running.
Dave
ps - In my response, I assumed that you repacked the stuffing box (as opposed to adding packing material). If that's not the case, than you should remove and replace all of the old packing.
Pearson 33-2
Western Long Island Sound
davester is offline
post #5 of 7 Old 10-06-2013
Ric35-3's Avatar
I just accepted a 83 Ericson 35-3 . She has been on the hard for a few years. Would you Suggest Replacing the Stuffing? Before i set her back in? Can I do it with her in the water?
What else should I do or inspect?
Ric35-3 is offline
post #6 of 7 Old 10-07-2013
I'd do it now, you won't be fighting the leak during an in water change . . . given you're not familiar with all her idiosyncrasies yet . . .(new to you, on the hard for ? yrs) also check ALL those hoses and through hulls, clamps etc. Now is also the time for any bottom work, zincs . . . .Ericsons were a very high quality build boat enjoy! and don't forget ericsonyachts.org
mikel1 is offline
post #7 of 7 Old 10-07-2013
Noah's Bosun
Cap-Couillon's Avatar
Dave's (Post #4) answer is spot on... Drippage should be checked while shaft is engaged and at normal rpm. One drop every 4-5 seconds is adequate. Just shows gland is full of water and therefor lubricating. As Dave stated giveaway is temp. Cool is good, warm is ok, hot is not.
"If the wind will not serve, lay to the oars"
Cap-Couillon is offline
Stuffing box Nut GaiaOrion Gear & Maintenance 3 08-18-2011 06:03 PM
new stuffing box redhead78 Gear & Maintenance 7 06-09-2010 02:48 PM
Stuffing Box krozet Gear & Maintenance 11 03-16-2010 11:52 PM
About that Stuffing Box preservedkillick Gear & Maintenance 8 05-20-2009 07:20 AM
Stuffing box GBurton Gear & Maintenance 22 08-13-2007 09:35 AM
