1GM10 cooling problem.... again! - SailNet Community
post #1 of 9 Old 06-25-2013 Thread Starter
Smile 1GM10 cooling problem.... again!
Hi All,
I'm new to the site and new to diesel trouble shooting and maintenance also.
My 1GM10 is run on fresh water and has been perfectly behaved since 2008.
It gets few hours use each season... sails up - off we go!
Now the engine is alarming after 4 or 5 minutes.
There is little or no water out at low revs, some at mid revs and almost none at high revs.
I changed the impeller, old was broken. I retrieved some of the pieces but there may be a little still at large ...?
I checked the thermostat... not functioning so replacement is ordered asap.
I ran the engine with no thermostat and still no water out.
There is water coming to the impeller.
There is a drip of water from behind the impeller unit, not from gasket.
Could this indicate something?
All water pipes look as new.
By the way...is it normal that the impeller pin is slightly off centre?
All suggestions welcome,
Captain Aubrey
Captain Aubrey is offline
post #2 of 9 Old 06-25-2013
bljones's Avatar
Re: 1GM10 cooling problem.... again!
Sounds like your pump may be pooched.
Can you wiggle the pump shaft with the impeller out?
It's 5 o'clock somewhere:
bljones is offline
post #3 of 9 Old 06-25-2013
overbored's Avatar
when you say fresh water do you have a heat exchanger or are you sailing in fresh water. first check the pump by removing the discharge hose and pump into a bucket. run engine just long enough to confirm pumping or not. if it pumps you have a clog in the engine. first is to check the exhaust elbow by running the engine with the exhaust cooling hose removed. the drip behind the pump means the shaft seal needs replacing. also did you put the impeller in so the vanes go in the correct direction.
"GOLD RUSH" PRINDLE 16
overbored is online now
post #4 of 9 Old 06-25-2013
Tartan 27' owner
CalebD's Avatar
I assume you mean "raw water" cooled (which is fresh water if you sail on a lake).
Yes, first check that pump is actually pumping.
If the pump works then you likely have a clog from bits of the old impeller. Check all cooling water lines after the pump, especially elbows.
Once flow is restored consider running 1 gallon of white vinegar into the engine with the thermostat removed, let it sit overnight before restarting engine. This can help clean out your cooling passages in the block.
Go sailing.
Everybody has one:
CalebD is offline
post #5 of 9 Old 06-25-2013
Your impeller shaft isn't actually off center, I don't think, but there's a 'shoe/cam' in the body to isolate inlet from outlet and allow the vanes to push the water through.
I'd say your exhaust elbow is the first candidate, if you've changed an impeller recently and the old one was not intact, then there may be rubber bits blocking things. Easier to find these if you've got a heat exchanger...
Faster is online now
post #6 of 9 Old 06-25-2013 Thread Starter
Thank you bljones and overbored,
Yes, we sail on fresh water so raw water cooling.
I will fit a shaft seal next opportunity and dismantle pipes from pump onwards.
There is no wiggle in the pump pin.
I will report progress as soon as i can.
Thanks again everyone.
post #7 of 9 Old 06-25-2013
Senior Slacker
SlowButSteady's Avatar
Sounds like carbon/scale build-up in the exhaust elbow. Drain the cooling system. Then take the hose off of the "out" side of the pump and blow into it. If there is more than slightest resistance the mixing/exhaust elbow is probably clogged right where the cooling water enters (usually via a much smaller elbow fitting). The same thing happened to my 2gm20 a while back. I changed it since it also had about 10 or 15 years of saltwater corrosion. Since your boat is in fresh water, you may be able to just clean it out.
It could also be a stray bit of the old impeller. If so it's probably stuck in the smaller elbow fitting. Either way you'll have to take off the mixing elbow and clean it out, or just replace it.
Never forget them. Do something to prevent it from happening again.
Charlotte Bacon, Daniel Barden, Rachel Davino, Olivia Josephine Gay, Ana M. Marquez-Greene, Dylan Hockley, Dawn Hochsprung, Madeleine F. Hsu, Catherine V. Hubbard, Chase Kowalski, Jesse Lewis, James Mattioli , Grace McDonnell, Anne Marie Murphy, Emilie Parker, Jack Pinto, Noah Pozner, Caroline Previdi, Jessica Rekos, Avielle Richman, Lauren Rousseau, Mary Sherlach, Victoria Soto, Benjamin Wheeler, Allison N. Wyatt
SlowButSteady is offline
post #8 of 9 Old 06-25-2013
bljones's Avatar
If no wiggle in the pump shaft, then disregard the pump itself as the culprit. I agree with everyone else- elbows and hoses.
bljones is offline
post #9 of 9 Old 06-25-2013
larrytwo's Avatar
Had a similar problem with my 1gm10. Pulled the pump cover off and found broken impeller. I replaced but still had a problem. then pulled the thermostat and found broken rubber from the impellor restricting water flow. Problem solved.. Something you might check... Cheers.
B.C. coast videos.
Member, Canadian Coast Guard aux, unit 55. 1980/1998
larrytwo is offline
Yanmar raw water cooling problem noreault Diesel 18 04-15-2014 07:37 PM
Low rpm 1gm10 akbucki Diesel 20 08-09-2012 11:42 PM
Yanmar 1GM10 Overheating BayLAzr Diesel 8 07-29-2011 02:40 PM
Yanmar 1GM10 cooling system, needs a good cleaning. SVDistantStar Gear & Maintenance 4 01-13-2008 03:14 PM
1GM10 questions rperret Gear & Maintenance 7 06-17-2007 07:51 PM
