Interior Redesign - Page 2 - SailNet Community
post #11 of 20 Old 06-28-2013
sailing soon
mark2gmtrans's Avatar
Send a message via Yahoo to mark2gmtrans
Re: Interior Redesign
Whilst you have it all apart is the best time to run brand new wiring, for everything. Trust me, it will be cheaper and much easier to do, and you can make up a wiring diagram from the start and know just where everything is on your boat. That will come in handy if you ever have to do any work fifteen years from now for some reason.
Congratulations on getting it and good luck with all the work.
It is good to learn from your mistakes, but much better to learn from the mistakes of others...
mark2gmtrans is offline
post #12 of 20 Old 06-28-2013
Sea Sprite 23 #110 (20)
mad_machine's Avatar
good idea Mark.
Most boats have questionable wiring from new. Add to that mix some owners who didn't quite know now to properly add a radio or other electronics, plus a few years around seawater... it is a recipe for a serious migrane or two as you try to track down any issues
Art Haberland
In the end all that matters is how fully you loved, how gently you lived, and how gracefully you let go of things that did not belong to you -Buddha
mad_machine is offline
post #13 of 20 Old 06-28-2013
Seņor Member
PorFin's Avatar
OS,
Congrats on the windfall -- I reckon you're gonna come out well ahead value wise.
As for the fasteners, like others have said 18-8/304 will be more than suitable as long as they will not come into contact with any aluminum parts of the boat. Like you probably know, SS and AL don't play nice together if moisture gets into the mix.
+1 on what others have recommended about investing the time/money on a rewire while you've got everything peeled apart now. You also may want to think about plumbing, ventilation, and other systems that usually get tucked into very hard to reach areas.
Have fun with the project.
________
'85 BYB Vagabond 39
PorFin is offline
post #14 of 20 Old 06-28-2013
sailing soon
Originally Posted by mad_machine View Post
good idea Mark.
Been there done that haha, I have purchased a few boats from insurance companies and wished they had the interior removed completely by the time I got done fixing the wiring. One of them I ended up doing just that, it had more shorts and intermittent outages than it had good wires.
I am not sure I want someone to give me a boat, but if the outside looks that good then I would go for it...
post #15 of 20 Old 06-28-2013
Originally Posted by PorFin View Post
OS,
Why SS at all for the fasteners.. why not bronze or brass screws? Heck, it's only interior.. you could even use Aluminum
Art Haberland
post #16 of 20 Old 06-28-2013
mitiempo's Avatar
304 stainless fasteners are inexpensive and stronger than aluminum or bronze, as well as more readily available.
The wiring of a metal boat is unlike a wood or fiberglass boat though. Everything must be isolated from the hull, especially watch items like motors of pumps that are case grounded. Best practice would be double pole breakers on all Dc loads so when it is off, it is really off with no chance of leakage. Engine isolation is tougher but the easiest solution I have heard is a switch in the negative to the engine that is open except when it is running. This can be wired through a relay so it switches with the ignition.
Pretty boat and for free as well! Good luck.
Brian
mitiempo is online now
post #17 of 20 Old 06-29-2013 Thread Starter
Thanks for all the comments and good advice!
I plan to tackle this project in three phases. The first being interior redesign, doing any structural work and cosmetic finishing work necessary on the inside. The second is redoing the entire electrical system. I have already more or less redesigned the entire electrical system which is going to implemented in phases. After doing the interior and leaving provisions for wiring, phase two will be to redo all the wiring run new wires throughout as well as setup a new power distribution system, battery bank etc. The third phase of the project would be to get all the electronics hooked up as well as solar panels, plumbing etc. I'm going to do the interior in such a way that any areas needing wiring or piping are always accessible using removable panels instead of fixed panels. This will be helpful for phases 2 and 3 as well as in the long run when I need to fix/maintain systems.
I know it seems backwards to do the interior work and cosmetic stuff before finalizing wiring and piping but I plan to do this project spread out over 1.5 years with the end goal of being able to live aboard at the end. So it is more important for me to be able to get the boat in good shape with basic amenities and then incrementally add to the electrical and plumbing systems while living aboard. Also I have fully planned out the wiring etc. so it will not be very hard to leave provisions while redoing the interior.
OpenSeas is offline
post #18 of 20 Old 06-29-2013
sailing soon
If you intend to do the final electrical wiring after you finish the interior work I would suggest you at least run any main runs that will be covered by the interior wood or other stuff that is going to cover the main runs and make them hard to get at.
I can see the logic in doing it in stages, just be intelligent in the stages you do it in and all should be great.
post #19 of 20 Old 06-29-2013
Senior Moment Member
SloopJonB's Avatar
I'd install plastic conduit up under the hull/deck area. That way you can fish wires any time you want and they are in a dry area.
SloopJonB is online now
post #20 of 20 Old 06-29-2013
sailing soon
That is what I was getting at, pull your main run conduit or the wiring in the conduit prior to buttoning it back up under a bunch of stuff or when the time comes you will be kicking yourself for not doing it when it was way cheaper and way easier.
Tags
interior design , project , remodel
Interior retrofit sailingonu Gear & Maintenance 5 01-06-2013 05:30 PM
Questions about closed cell foam panels and interior redesign.. PPPPPP42 Sailboat Design and Construction 7 07-25-2012 05:54 AM
Simple redesign would have been better - Coast Reporter NewsReader News Feeds 0 03-09-2012 08:20 AM
Interior LEDs paul323 Gear & Maintenance 11 09-26-2010 10:25 AM
E29 - Head Redesign maccauley123 Ericson 10 06-01-2009 09:12 AM
