Question for Cal29 owners - SailNet Community
 1Likes
  • 1 Post By svHyLyte
post #1 of 5 Old 06-27-2013 Thread Starter
I recently bought a Cal29. The dining table came with a short tube to convert the table to a double bed. My question is, what cushions go there to make up the bed? Not sure if Im missing some cushions.
Sent from my Kindle Fire using Tapatalk 2
BillA98272 is offline
post #2 of 5 Old 06-27-2013
Re: Question for Cal29 owners
On my Cal 25, the cushions on the back of the seat are what cover the table top once it's been converted to a berth.
Dave
Boiler19 is offline
post #3 of 5 Old 06-27-2013
Old as Dirt!
svHyLyte's Avatar
When delivered, the boat included a cushion that fit the table-top when folded open to create the salon berth. When not in use, it was stored in the port quarter-berth. There should also be a row of roughly 3/16" holes along the side of the table that would be on the inboard side with a matching piece of 3/4" x 2" teak rail, the length of the table when folded open, with four pins that plug into the holes in the table top. The rail serves to hold the cushion in place. FWIW, on our (former) boat, I cut a slot in the base of the longer tube that was 90 out from the original slot so that I could turn the table top sideways and use it as a navigation table when we were underway. It worked well.
Good Luck!
BillA98272 likes this.
svHyLyte is offline
The Following User Says Thank You to svHyLyte For This Useful Post:
BillA98272 (06-27-2013)
post #4 of 5 Old 06-27-2013
tommays's Avatar
There is just a rectangle shaped one that fits in pretty nice with the one that stays there
If you have a really full set there is also a filler piece that fits on the step out of the cabin
It is by far the best sleeping spot as the v-berth is a mucho climb out
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #5 of 5 Old 06-28-2013
Old as Dirt!
svHyLyte's Avatar
Yes. Frankly, I forgot about the second cushion that fits under the stair-step to make the salon berth complete but it is important if you choose to use the salon.
As a practical matter we found the V-berth quite usable and comfortable, at least in California where excessive heat was not an issue. In our case we dispensed with the bi-fold louvered door that was fitted on some boats and replaced it with a privacy/blackout curtain that worked quite well. To make entry-exit easier, we fitted a small fold-down step below the entry that could be folded out of the way when not needed. We also installed a grab-rail horizontally across the top of the entry. With that, one could grab the rail with both hands, and step up and swing into the berth quite easily. It also made exiting easier. Lastly we fitted a small mesh lee-cloth about 12" high across the bottom of the entry, held in place with a length of shock-cord through the top to hooks on the inside face of the bulkhead on either side of the entry port. The lee-cloth served as a pillow-stop to keep pillows from going adrift in the night and/or gear that might be stored there when the berth is not in use. A couple of fans, one on either side of the entry, completed the arrangement.
FWIW...
svHyLyte is offline
1970 Cal29 boom outhaul Mike Kohler 1970 Cal29 K9 Cal 2 08-25-2012 06:23 PM
The Cal29 forward hatch rebuild tommays Cal 9 11-07-2010 06:02 PM
My Cal29 paint booth tommays Cal 3 08-08-2010 12:22 PM
baltimore Cal29 ChesapeakeCal29 Chesapeake Bay 1 03-28-2007 04:46 PM
Question for O'day 40 owners jazzmaster2201 O'Day 2 03-27-2007 10:27 PM
