Gelkote thickness with Preval sprayer - SailNet Community
post #1 of 2 Old 06-27-2013 Thread Starter
I'm concerned that I will not be able to get an adequate thickness when using the preval sprayer. The problem is that the gel that I will be using contains the wax and letting it set up will require that each layer has to be sanded before another coat is applied. I would prefer going to the non wax gel and just use PVA on the final coat, however the gel that I'm interested in has a good color match and is only available with the wax. I've been told that applying spray with a minute or two between passes is possible allowing for build up of the gel. I may be able to make 5 passes this way and get an adequate thickness. Thoughts?
lancelot9898 is offline
post #2 of 2 Old 06-27-2013
Battered and Bruised
Silvio's Avatar
Re: Gelkote thickness with Preval sprayer
Spray in layers to build up. If it is a substantial thickness that you need, maybe you should build it up first with gelcoat thickened with colloidal silica.
SV S.S.R.I
It's my happy pill
Silvio is offline
Help me choose sprayer for Interprotect gallilaw Gear & Maintenance 6 04-26-2011 09:59 PM
Evercoat Gelkote-Was a mistake to use! saurav16 Gear & Maintenance 12 12-17-2008 05:36 PM
Gelkote question grinfax Gear & Maintenance 3 09-24-2008 08:54 AM
Roller vs Sprayer Hyperion Gear & Maintenance 14 07-18-2007 01:08 PM
Painting with electric airless sprayer? mmccoy Gear & Maintenance 5 07-26-2004 03:33 PM
