Recommendation for running rigging lines - Page 4 - SailNet Community
post #31 of 38 Old 07-04-2013
no longer reading SailNet
Alex W's Avatar
Re: Recommendation for running rigging lines
Originally Posted by QuickMick View Post
Thanks for the heads up. Here is a link to the comps... looks fair:
Cajun XLE CAD
In those "comps" they leave out stretch, which is one of the most important factors. Compare the actual stretch numbers, XLE is pretty terrible.
Look up Novatech XLE, that is what Cajun is selling.
It's a good price and suitable for lines where stretch is not a major concern. There aren't too many of those in my running rigging.
Alex W is offline
post #32 of 38 Old 07-04-2013
Pretty sure Cajun either has or does go by another name as well, which is considered a low end rope. I strongly considered it on price, but passed. For some of our sailing needs, we all probably get too hung up on this. There are people cruising with the stuff other cruisers threw out!
In the end, I think you generally get what you pay for. You just need to know what you want.
Jeanneau 54DS
Minnewaska is offline
post #33 of 38 Old 07-04-2013
I don't discuss my member
zz4gta's Avatar
Oddly, zz4gta you posted in the thread I mentioned
Why is this odd? I mentioned it was stretchy. Not something you'd typically want on a sailboat. It would work, so would nylon.
"Might want to look into a single braid for the main sheet. Salsa, Apex, Bzzz line, are all good choices. Run easily, and very easy on the hands.
Merit 25 # 764 "Audrey"
And it seems you mention VPC, SALSA, APEX, BZZZ all of which are NE products with no mention of affiliation.
I became a NER dealer the beginning of this year. And before making accusations, please check your facts. Apex is a SAMSON product, which I used for 2 years on my own boat.
Did you have an experience that would change your mind?
Yes, I saw more specific data on the stretch characteristics of the line.
Maybe you didn't have an affiliation with NE at the time but I must say it seems odd that you would recommend at least 4 NE products and now are a sales guy.
I can understand the confusion. I don't mean to come off like a salesman but I have more access than most about NER products. And to be honest, the more I learn the more I like the line. They make good products. I feel the same way about Samson line. There are pro's and con's to each, and too much detail will bore all involved and that's getting pretty specific from product to product.
zz4gta is offline
post #34 of 38 Old 07-04-2013
RocketScience's Avatar
Originally Posted by Alex W View Post
I talked about the fairly crappy line that they sell in post #12 of this thread.
I have used Samson and NE ropes in the past, from their various yacht braids (XLS, Sta-Set, etc.), to their high end lines on racing boats (MFP, Poly-TecH, etc.), all good line.
Six years ago I re-rigged with Cajun (Nova) line on my cruising sailboat, and have absolutely no complaints (so far). It's strong, wears well, splices easily, feels good in the hand, and for those cosmetic conscious, appears to hold its color well. [Edit: I have no affiliation with Cajun]
For those who do not seriously compete with their boat and site its (listed) higher than average stretch as an argument against, might I suggest you pay a bit more attention to your AWA and sheet trim, as it will have a far greater effect on your SOG than any negligible stretch.
Synthetic Rigged Wauquiez Pretorien 35
RocketScience is offline
post #35 of 38 Old 07-09-2013
Alex W's Avatar
I pay a lot of attention to my AWA and sheet trim, why would you suggest otherwise? That won't do anything to get proper luff tension on my headsail (which matters for controlling draft position) when my halyard is stretching 4".
There are lines where stretch doesn't matter that much and Cajun/Novabraid XLE is fine. There just aren't that many of them, and they aren't the longest lines on a sailboat that cost money to replace anyway.
Alex W is offline
post #36 of 38 Old 07-20-2013
I pay a lot of attention to my AWA and sheet trim, why would you suggest otherwise? That won't do anything to get proper luff tension on my headsail (which matters for controlling draft position) when my halyard is stretching 4"...
Whatever inherent stretch there may be in a halyard, much of it is winched-out anyway. I'm guessing by as much as 50% depending on tension. So, in your case, 4" now becomes 2".
My point is, is that when it comes to SOG, this negligible stretch in your halyard will mean nothing compared to the slightest inattention to the sheets or helm, dirty air, or a sudden shift in wind direction for that matter. But hey, if this stretch, and its infinitesimal effect on your SOG bothers you on your recreational boat, I can handle that.
post #37 of 38 Old 07-20-2013
Alex W's Avatar
It isn't winched out evenly. When a puff comes along load and stretch go up, you luff tension goes down, the draft moves back and the sail gets baggier. Its not much different than using old sails. That increases heel and overpowers the boat. This isn't a good thing.
If you want inexpensive low stretch halyards and can handle some work buy 3/8" XLE and splice it to 3/16" Amsteel. The working portion will all be dyneema and the XLE is relegated to piling up where it has no load and stretch doesn't matter.
The splice is easy and is shown on l-36.com.
I also use this splice for spinnaker topping lift and downhaul, reefing lines, and jib sheets.
Alex W is offline
post #38 of 38 Old 07-21-2013
It isn't winched out evenly. When a puff comes along load and stretch go up, you luff tension goes down, the draft moves back and the sail gets baggier...
We're ultimately talking SOG here, aren't we??
I guess I just don't "get" your pursuit of ultimate luff tension on a recreational sailboat. Again, I seriously doubt 4" of stretch in a halyard can be measured in knots of speed to the negative, especially when you consider all the other factors (previously stated) that can more easily contribute, but that's just me. Additionally, luff tension via a halyard isn't the best way to control draft anyway, as it adversely effects roach and sail twist. If luff tension is a serious issue for you, your draft would be best controlled by the use of a cunningham instead.
...If you want inexpensive low stretch halyards and can handle some work buy 3/8" XLE and splice it to 3/16" Amsteel. The working portion will all be dyneema and the XLE is relegated to piling up where it has no load and stretch doesn't matter...
I'm familiar with this technique, but IMO it's very little juice for the squeeze...
Perhaps I may have misrepresented my original post with regards to Cajun Line (Novabraid). Don't get me wrong, I'm not advocating a cheaply made or inexpensive product. Heck, I'm currently in the process of rerigging with synthetic (Dynex Dux) standing rigging, which makes me far from the frugal refitter. Novabraid, from personal experience, appears to be a great line suitable for the cruising or recreational yacht. On the other hand, for those concerned about a negative (point) .10 kt in boat speed on a recreational sailboat, it probably isn't for you.
Running lines to cockpit nolasailor Racing 6 04-24-2016 11:54 AM
Running lines aft on Bristol 38.8 kestrel299 Bristol 3 05-03-2011 01:27 PM
Running all lines to cockpit jetdrvr393 Gear & Maintenance 14 11-08-2010 09:33 PM
running all deck lines diverdad69 Gear & Maintenance 2 06-07-2009 09:26 PM
Running lines aft Columbia 26? Mandofish General Discussion (sailing related) 0 12-03-2008 08:50 PM
