Cost to Replace Chainplates? Should I Walk Away? - Page 6 - SailNet Community
 19Likes
post #51 of 65 Old 07-01-2013
Captain S/V Triumph
DougSabbag's Avatar
Re: Cost to Replace Chainplates? Should I Walk Away?
Originally Posted by Harborless View Post
I did not say REPLACE, I simply said inspect- my chainplate broke in a small craft advisory on the St. Johns from a fracture between the deck and underside so my visual inspection was worthless- you had to PULL THE CHAINPLATE to be able to see it. So after three years you SHOULD pull the chainplates and inspect- BOTH SIDES!!!!! I only pulled the starboard side and it was so nice looking I skipped port. Port was the one that snapped in 25 knots risking mast collapse.
Also- Circumnavigating is WAY different than occasional sailing. The CONSTANT stress and loads, salt corrosion, and constant use warrant a COMPLETE CHECK UP after said circum navigation INCLUDING chainplates titanium or not. I said a rig is good for 10- yes it can make 20 but come 15 Im replacing unless Im in fresh water. Your standing rigging is only trumped by your seacocks. Standing rigging includes chainplates. So unless your going titanium shrouds and turn buckles too I REALLY dont see the point in the expense of titanium over 306.
Unless your chainplates are installed on the outside of your hull, (unlike mine), they are generally installed in such places that corrosion can more easily get to them than to your exposed turnbuckles, etc., which again, you can much more easily clean up.
So, there is a big difference in the full spectrum of stresses which the plates will be exposed to vs. the rest of the rig. Titanium will NOT rust.
And, as I mentioned, in reality I am only going to change these once. So, I will use the best material available for those, and then I won't have to take apart my cabin interior to "inspect" them. Which unless you are going to do the dye test, or an Xray, just looking at them doesn't really tell you jack.
Why fight using the best especially for such a deeply nested, hard to replace, and important part(s), which statistically speaking, you are only going to replace once, per boat you own.
Fair winds....
Doug
DougSabbag is offline
post #52 of 65 Old 07-01-2013
Captain S/V Triumph
DougSabbag's Avatar
Originally Posted by mark2gmtrans View Post
Though my ancestors were from Spain and Germany I often suspect a frugal Scottish ancestor in there somewhere, because I am cheap as all get out, but then the German kicks in once I start working on something and it has to be done right or not at all. The fight between Scotland and Germany must rage at times in my DNA, because the frugal side knows better than to start a repair project because once started all that cheapheartedness has to be pushed aside.
Well, besides ancestry, age and experience has taught me that in the long run, quite frequently, using / buying the best, actually saves me money.
And on top of all that, my ancestry must have someone who was lazy, because I'd much rather only tackle something as difficult as changing my chainplates, (or pulling my motor), once, if at all possible.
So, when I do pull my motor, I also balance it by grinding the outside of the shank of each connecting rod until the entire piston assemblies all weigh the same, within a fraction of a gram. Makes for a very smooth running motor, but more importantly it will LAST A LONG TIME.
Sadly, I beleive we spend around 80% of our "sailing time" maintaining our boats, and 20% sailing if we are very, very lucky. Use Titanium. :-)
post #53 of 65 Old 07-01-2013
overbored's Avatar
first it is 316 stainless that is preferred for corrosion resistance not 306. there is no 306 stainless steel. not many people will pull chainplates to check every three years, you my be the only one. checking chain plates, and checking rigging are two different things. if I am going around the world and changing the plates first it would be Titanium for sure. why go to all that work and not do it so you do not have to ever worry about it again. the cost difference is only in the material not the labor which would be the same. another good material is Nitronic 50 which is what rod rigging is made out of. and the chainplates on my boat are made out of aluminum and 25 years old but they are in the cabin
"GOLD RUSH" PRINDLE 16
overbored is online now
post #54 of 65 Old 07-01-2013
Mark, you'll know the German has kicked in when you feel the compulsion to replace every screw and bolt on the boat with something that has a recessed metric Allen (hex) head instead of any other fastener. Preferably in at least two dozen different sizes, so two dozen specialty tools will be required to service them all.
Oh wait, "dozen" isn't metric, that's gonna be another problem isn't it?
Proper German engineering would produce outstanding chain plates, but you'd need to remove three access panels (at least one of which requires a new gasket and seal kit to be used when replacing it) with six special tools to reach them, and you'd void the warranty on the boat for having an unauthorized independent source touch them, instead of the factory trained mechanic. You may be German, but you're not authorized.
hellosailor is offline
post #55 of 65 Old 07-01-2013
Blue Horizons
Harborless's Avatar
Fine- You go Titanium Ill stay 316. Ill sell my boat in 3 to 5 and save the grand for a vacation to costa rica next fall.
Each their own.
Out.
Harborless is offline
post #56 of 65 Old 07-01-2013
12"x36" of 1/4" Titanium plate, unspecified alloy, $800+.
Four bars of 316SS, 3"x 36", $220.
Without shopping around or trying to factor in the harder machine work...Not so bad, an extra $600--700 for chainplates that simply COULD NOT experience that failure on a 30-40' boat.
Not that the difference is chump change, but if access is a problem and someone plans to keep a boat long long term...it might even be a good selling point for the next owner. One less thing they have to worry about as well.
Of course if you have titanium chainplates, they should be bolted external to the hull, and finished in those wonderful irredescent colors that only titanium has, just to make sure everyone knows it. (VBG)
post #57 of 65 Old 07-04-2013 Thread Starter
Uh, CA sales tax is 8%. You buy in CA and you are legally bound to simply cut that check for 8% of book value of your new boat and drop it in the mail to CA BOE. Forget to do it? They'll have you and your boat. They are merciless. AND they'll charge you late fees, interest and penalties.
Washington allows a cruising permit for 6 mos. There are other states to sail to. My atty will file the correct papers with CA to prove yacht was not in CA. If you are buying a boat of any consequence you need to do your due diligence.
I don't want to tip my hat if any of the bad guys monitor this board.
BUT, I pay a hell of a lot of taxes. I follow the law and support my country. Tax avoidance IS A RIGHT. Tax evasion is illegal and should be punished accordingly.
CheckedOutRob is offline
post #58 of 65 Old 07-04-2013 Thread Starter
As the OP on this thread I should follow up on the title of this post.
I just did walk away from the Passport 40 this week. Long flight to WA to check it out. Needed new teak deck, engine oil in bilge, chainplates looked bad, leaks from saloon windows, ugliest mast I've ever seen -painted brown, mainsail shot, several diesel leaks, smelly head, dodger shot, rig had issues etc, etc.
BUT fantastic news!!!! I'm closing on an amazingly good shape Nordic 44 next week.
post #59 of 65 Old 07-04-2013
sailing soon
mark2gmtrans's Avatar
Send a message via Yahoo to mark2gmtrans
This is a summary of the current (everchanging) California state tax code as it applies to the purchase of vessels in California. If you have any questions you should take it up with a Maritime Tax Law firm like Weil & Associates,
http://www.weilmaritime.com/practice-yachting-sales.php
who come very highly recommended. I have purchased boats, semi trucks, and heavy machinery in California for resale or use outside the state of California. A USCG registered vessel would definitely qualify under this law as exempt if you meet the condition of the exemption. Please not the exemption for taking it out of the state applies even if you have the boat in a marina for repairs or refitting. I hope this helps clear up any questions on this issue.
The State of California will assess sales tax (for new vessels) or use tax (for used vessels) if the boat was (1) purchased in California; OR (2) purchased for "use" in California. California's territorial boundary extends three miles into the ocean, so if the purchase can be structured to close more than three miles offshore (an "Offshore Delivery"), the buyer will satisfy the first prong of the test. The second prong involves a subjective analysis of the buyer's intended use at the time of the purchase, which is a little more complicated.
A buyer's true "intent" is impossible to determine through any objective test, so a "presumptive test" was established, where a buyer who could prove that the boat was used outside of California for a particular time period after the purchase was presumed to have purchased it for use outside of California. For many years, the required time period was 90 days. Under that test, a buyer who could prove that he or she used the boat outside of California for more than 90 days during their first six months of ownership was "presumed" to have purchased the boat for use outside of California.
Over the years, it became very common - almost expected - that the buyer of a boat in Southern California that cost more than $100,000.00 would take advantage of this procedure and spend three months in Ensenada after the purchase. California taxpayers took exception to the use of Ensenada as a "90 day yacht club," and in 2004 the legislature enacted Senate Bill 1100 as a part of that year's state budget.
SB 1100 increased the 90 day period to one year, though it did offer several strategies for reducing that time period. The bill also included a "sunset provision," and when the law expired in 2007 the 90 day rule was reinstated. But in 2008, the budget negotiations took immediate aim at this perceived loophole, and we have now officially returned to the one-year rule.
We should note that this waffling back and forth on the time period has no effect on the basic structure of the law. The State will continue to assess sales or use tax if the boat is purchased (1) in California or (2) for "use" in California. The varying factor is the presumptive test for evaluating the buyer's intended use at the time of purchase.
We should also note that this is not a black and white test, and the "presumption" can be defeated. It was - and is - possible for a buyer to comply with the calendar test and nonetheless be subject to the tax, if the California Board of Equalization discovers facts that indicate that the buyer actually intended to use the boat in California.
The approach to the one-year requirement in 2008 differs from the 2004 approach in two ways. First, the new law has no "sunset" provision, and the new rules are therefore theoretically "permanent." Second, unlike the approach used in 2004 which provided a two month phase-in period before the law became effective, the 2008 modification to the law was effective immediately. Anyone who entered into a purchase contract after September 30, 2008, was subject to the one-year rule.
The highlights of the one-year rule provide that a buyer will be presumed to have purchased the boat in California, and thus be subject to assessment of sales or use tax, if:
For California residents, where the buyer brings the boat into California within one year of purchase;
For non-residents, where the buyer keeps the boat in California for more than six months during the first one year after the purchase;
For anyone, if the vessel is subject to the assessment of personal property tax at the county level during the first year after purchase.
There is one significant exception to the one year timetable. An owner may keep the boat in California during a repair, retrofit, or modification project, without affecting the one year analysis, so long as the boat logs less than 25 hours underway while it is in California.
It is good to learn from your mistakes, but much better to learn from the mistakes of others...
mark2gmtrans is offline
post #60 of 65 Old 07-05-2013
JeffBurright's Avatar
As far as DIY yards, I recommend the Ilwaco boat yard at the mouth of the Columbia River. We hauled out our 30' boat there, had a bottom wash and did a month's worth of heavy work on her - electricity and all - for around $450. It's the best deal we've come across, and the people there are very nice. Bellingham also has a pretty inexpensive DIY yard (at least it was DIY in 2008) with lots of good contractors on hand. I can't remember the name though, sorry.
Good luck!
JeffBurright is offline
Tags
chainplates , passport 40
Prop Walk davidpm General Discussion (sailing related) 13 08-31-2010 12:49 PM
C30 walk thru models capt.stu Catalina 1 06-05-2007 03:38 PM
when to walk away? jbarros Boat Review and Purchase Forum 5 02-03-2004 03:58 PM
