Solenoid switch does not shut off propane - Page 3 - SailNet Community
 4Likes
post #21 of 23 Old 06-30-2013
ebs001's Avatar
Re: Solenoid switch does not shut off propane
The other possibility is that one or both of the Quick connect jumpers 2 & 3 have been removed. Page 4.
ebs001 is offline
post #22 of 23 Old 06-30-2013 Thread Starter
Jiminri's Avatar
Thanks Ebs. I'll check that too.
Nonsuch 30 Ultra #343 1986
West River, MD
Jiminri is offline
post #23 of 23 Old 01-09-2016
Hi
I work a lot with solenoid switches , there are some and you can look at it on the switch itself , that are NC normally close ,and other NO normally open ,
that means NC is close all the time , when powered it will open and the same for NO open all the time and when peered it will close .
the one for propane should be NC so when you need the propane you turn on the with and the valve should open
this valve open when the power create a magnetic field , (Electic magnet , and the magnet move a piece a metal inside the valve ,
first make sure there is power at both side of your switch, if yes look at the 2 wires that connect you solenoid , if yes , the solenoid is probable defect , take it off the propane line , and bring it inside ,look at it , maybe duty , there is lots of sulfur in propane , for the smell, (safety in case of leak ) , sometimes it can block the valve
Good luck , Happy wind
rioux.lm@bell.net is offline
Propane solenoid questions Gene T Gear & Maintenance 6 01-14-2010 07:45 PM
A/B switch for removing shut from battery circuit patrickstickler Gear & Maintenance 14 10-11-2009 12:22 PM
Is a propane Solenoid supposed to be hot ??? Sailormann Gear & Maintenance 15 05-27-2009 11:31 AM
Propane problem: solenoid or regulator? cleepq Gear & Maintenance 6 02-12-2009 08:07 PM
Propane solenoid control Shortman Gear & Maintenance 3 08-03-2008 09:49 AM
