Fuel in oil - where to start? - Page 2 - SailNet Community
 3Likes
post #11 of 43 Old 07-01-2013 Thread Starter
Re: Fuel in oil - where to start?
Originally Posted by hellosailor View Post
Look into buying a "major rebuild kit" for your carb, and check out what's involved in the overhaul.
That's the rub...these stupid carbs have been out of production for decades, and parts are getting tight. There are no kits...just random parts/gaskets/etc at varying prices...most coming from Norway or Sweden.
May be worth a shot though...I'm game for trying. Worst case scenario would be sending a box of parts to the carb guy and saying "fix it".
--Skagit out
Skagit is offline
post #12 of 43 Old 07-01-2013
I would try asking Volvo, or asking if some other company actually made the carb, and trying to pin down a kit for it. While there may be none, that also would put you at the mercy of a shop and how well they might or might not match up the bits you need. Unless you've got sterling recommendations to someplace that does great work, in which case, please do share the name.
hellosailor is offline
post #13 of 43 Old 07-01-2013
If you could go on line and find the pressure spec for the original mechanical pump you could compare it with the electric pump, which may be delivering more than the float valve can handle. I put an electric pump on a Ford Engine into a Willys truck. IIRC, it put out about 4 to 5 lbs of pressure, worked great.
It could also be that the float valve tip, generally rubber or Viton? has worn away? Maybe a speed shop or small engine shop might have loose parts like that, if you can get them to talk to you?
Paul T
dabnis is offline
post #14 of 43 Old 07-01-2013
I had a similar issue with my riding mower. Apparently, it is common on mowers. I got a rebuild kit and replaced the gaskets and seats. The float would not close the fuel off when the engine was not running and the bowl would fill and overflow into the cylinder. The local mower store told if the rebuild kit didn't fix it, a fuel shut off vale would do the trick. In my case, the kit worked.
El Rubio is offline
post #15 of 43 Old 07-02-2013
Omatako's Avatar
IMHO its not the carb. If the carb was being so overwhelmed by fuel line pressure that it is contaminating the oil then that engine would run very badly or not at all. It takes very little extra fuel to flood an engine and it takes a huge pressure to overcome a needle and seat and bypass into the full float chamber.
If the needle and seat is dodgy, the engine will also run badly or not at all and the engine would definitely not start if there was enough fuel percolating into the cylinders to run past the rings into the crankcase. That's a really long shot as far as I'm concerned.
If you have a mechanical fuel pump on the side of the engine I would bet a considerable sum on the diaphragm being torn and allowing fuel into the crankcase. Start there take the pump off, open it and closely examine the diaphragm. It will still pump even though it leaks fuel.
Arthur C. Clarke
Omatako is offline
post #16 of 43 Old 07-02-2013
Originally Posted by Omatako View Post
IMHO it’s not the carb. If the carb was being so overwhelmed by fuel line pressure that it is contaminating the oil then that engine would run very badly or not at all. It takes very little extra fuel to flood an engine and it takes a huge pressure to overcome a needle and seat and bypass into the full float chamber.
If you have a mechanical fuel pump on the side of the engine I would bet a considerable sum on the diaphragm being torn and allowing fuel into the crankcase. Start there – take the pump off, open it and closely examine the diaphragm. It will still pump even though it leaks fuel.
From earlier posts:
"Are you running the fuel line thru the old mechanical pump?
I have seen this done and if the pump diaphragm leaks AND the drain is blocked [ painted over ] then fuel finishes up in the sump. "
"No...new fuel line is direct...tank -> pump -> regulator -> carb. "
Another thought, if it is an updraft carb I would think fuel would have a hard time flowing past the float and into the manifold? As Omatako said, if it was getting that much fuel past the float valve it would be running extremely rich and rough?
"Regulator"? maybe not working? Either way, it looks like the fuel is draining into the pan or is being ingested through the carb? Maybe try a gravity fed temporary fuel container directly to the carb, by passing the pump? An outboard gas can with a long hose from the cockpit to the engine should be fairly safe?
Paul T
dabnis is offline
post #17 of 43 Old 07-02-2013
I don't know the MB10A at all, but generally there are only two ways a lot of fuel will get in the oil. The ruptured diaphragm, which you say is out of the loop and can be eliminated. And then, loose rings, allowing fuel to enter from the cylinders.
If the fuel is just "traces" picked up during an oil test, that can just be from short engine runs that don't cook off the normal fuel and condensate accumulations. In which case you just run the engine longer to burn them off.
But if there's gross fuel contamination, I'm come back to looking at the rings. A compression test, and a leak-down test, to see what's really going on. Bad rings, low compression, that would also contribute to "hard to start", so more dots connect up at the same time.
There are only so many places where the oil "spaces" and the fuel can cross into each other.
post #18 of 43 Old 07-02-2013 Thread Starter
Wish I could say the same...
It's officially gross fuel contamination...like recoil from the smell of fuel on the dip stick gross fuel contamination. Compression check came in good...95/105 (factory new is 107).
Another thought I had...I haven't busted out my level, but it appears to me that the carb is lower than the bottom of the fuel tank. I wonder if fuel is slowly flowing through the carb and pooling...gravity wins every time, right? The spark plug threads were wet with fuel when I did the compression test and the engine hadn't run in two weeks.
--Skagit out
_____________________________________________
1975 Irwin 28 - hasn't earned a new name yet, but at this point it might not be flattering.
Skagit is offline
post #19 of 43 Old 07-02-2013
That may be a possibility. Some electric pumps will allow fuel to flow through them when they are not operating. If the manifold is lower than the float bowl
fuel may be seeping past the float valve even when the engine is not running.
If it is running OK the "seepage" may not be enough to notice, but may be enough to accumulate in the pan. You might try installing a fuel shut off valve right at the tank.
Paul T
dabnis is offline
post #20 of 43 Old 07-02-2013
Gravity, yes. If you're going to change the oil anyway, do a simple leakdown test, pull the plugs, fill with kerosene or gasoline, cover (to prevent evaporation) and come back tomorrow. Add a few drops of UV dye if you really want to double-check. Or, just borrow/rent one of the newfangled leakdown test kits that uses air pressure.
Certainly cheaper to check, than to tear into things.
Solid Fuel Stove Fuel HardTAC Gear & Maintenance 24 06-17-2013 09:15 PM
City marina to build self-service fuel station after three years without fuel - Corpu NewsReader News Feeds 0 07-17-2011 12:40 AM
I don't even know where to start. MariaDelMar Introduce Yourself 6 11-05-2009 09:47 AM
Where should I start dryclean General Discussion (sailing related) 5 06-07-2009 03:38 PM
Where to start, what to buy. puntapete Boat Review and Purchase Forum 16 11-05-2006 07:49 PM
